September 22, 2026, 04:05:09 am
| | |-+  Re: crazy frog beef up the engine
Pages: [1] 2 3 ... 8 Print
Author Topic: Re: crazy frog beef up the engine  (Read 174075 times)
mr horsepower
« on: March 20, 2009, 20:10:13 pm »
Hello guys finally a new season is here and i hope to get my car done in time
the goal is to drive as much races as possible in 2009
hp is not an issue i ll wil loan the car to my friends that want to feel the thrill of racing
the riecept is a 1.9 wbx
magnacharger jaguar xkr v8
ported heads
engle tcs 20 cam
merged header
renault un 1 tranny
ballanced rot kit
holley carb
nitrous oxygen
1.1  needle bearing rockerarm bridge
scat valve springs
custom intake
and lots of fun
LETS GO FOR IT !!!!!
GR Henri
« Last Edit: March 05, 2015, 22:04:51 pm by mr horsepower » Logged
fahrvergnugen
« Reply #1 on: March 20, 2009, 20:41:26 pm »
Cool Henri,
Looking good, looking for drivers? Cool
Paul.
« Last Edit: March 20, 2009, 20:44:43 pm by fahrvergnugen » Logged
mr horsepower
« Reply #2 on: March 20, 2009, 20:55:02 pm »
trying to upload.
« Last Edit: March 20, 2009, 21:49:23 pm by mr horsepower » Logged
mr horsepower
« Reply #3 on: March 20, 2009, 21:13:16 pm »
so i got the uploading under control i will post new pics tomorow.
Henri
« Last Edit: March 22, 2009, 11:59:55 am by mr horsepower » Logged
tikimadness
« Reply #4 on: March 21, 2009, 20:42:27 pm »
Cool you decided to start on the engine for this year.Hope to get side by side on the track. Wink
Michael
NIDGAFWYT
mr horsepower
« Reply #5 on: March 22, 2009, 11:31:19 am »
Helllo yesterday we have being working on the engine case and closed it now the work on the heads is taking place i hope to have the engine running in 2 weeks and hear the sound of the supercharger wyne.
Henri.
mr horsepower
« Reply #6 on: March 22, 2009, 11:58:07 am »
Working on the rockerarm geometry valvelift and measure ring end gap .
Henri.
mr horsepower
« Reply #7 on: March 22, 2009, 16:34:08 pm »
We started the engine mok up today HELL YEA!!!
Henri
mr horsepower
« Reply #8 on: March 22, 2009, 18:03:37 pm »
Measuring the valvespring install presure i am going to work whith a single spring set up i notice that there was a lot off tension on the aftermarket valve springs  for me they are way overdone so if you replace youre springs check them properly before install.
Henri.
JeePee/DVK
« Reply #9 on: March 22, 2009, 18:49:46 pm »
Nice work dude. Cool
Sander/DVK
« Reply #10 on: March 22, 2009, 21:51:18 pm »
Nice work indeed, but why do you use a distributor for an 8 cilinder engine?
Airspeed
« Reply #11 on: March 22, 2009, 22:52:53 pm »
Which single springs will you use then Henri?
tikimadness
« Reply #12 on: March 23, 2009, 14:31:54 pm »
It has been modified to work as a 4 cilinder distributor. ;)I am using the same as Henri.
Michael
NIDGAFWYT
Sander/DVK
« Reply #13 on: March 23, 2009, 16:09:15 pm »
What's the advance to use a modified 8 cil. dizzy?
ottobros
« Reply #14 on: March 25, 2009, 22:24:49 pm »
Hey Gekke henri
Ben je nouw toch maar opnieuw begonnen aan je crasy frog,is het al wat beter met de stres?Huh
ziet er wel leuk uit die update van je motor
Groetjes lenard
mr horsepower
« Reply #15 on: March 25, 2009, 22:28:52 pm »
Hey Gekke henri
Groetjes lenard
geen stress meer pik alleen maar coniferen Wink
ottobros
« Reply #16 on: March 31, 2009, 20:15:39 pm »
goed te horen dat alles goed gaat hahahaha,en wanneer zie ik je ?? bug in of zo
groetjes uit gent lenard
mr horsepower
« Reply #17 on: March 31, 2009, 20:17:43 pm »
Chilling with my girls !!!
mr horsepower
« Reply #18 on: March 31, 2009, 20:23:39 pm »
Echt wel. Wink
tikimadness
« Reply #19 on: March 31, 2009, 21:51:07 pm »
You should learn them how to drive the Frog Grin
michael
NIDGAFWYT
Bewitched666
Bewitched
« Reply #20 on: April 01, 2009, 07:23:33 am »
Project looks sick Cool
Fast vw beetle's rule
jamiep_jamiep
« Reply #21 on: April 01, 2009, 08:39:26 am »
Awesome project, nice to see a diifferent approach on the engine front. Will you be retaining the liquid cooling system or with it being a racer just running no cooling? I noticed you blanked off the connections on the case to the cooling system but ran hoses to them...
Love the kiddy-bike burnout! Cheesy
mr horsepower
« Reply #22 on: April 26, 2009, 17:32:51 pm »
Ill finaly got some time to work on the engine again.
« Last Edit: April 26, 2009, 17:35:37 pm by mr horsepower » Logged
« Reply #23 on: April 26, 2009, 23:18:46 pm »
Henri.
One of the big reasons for running dual (or triple) springs is that they are designed to cut out the harmonics found in a single spring which can lead to valve float at high rpm. It is, in my opinion, unlikely that you will be able to sustain high rpm using just a single valve spring set-up. It is not just a question of valve spring pressure...
mr horsepower
« Reply #24 on: May 10, 2009, 18:15:21 pm »
Prepearing the car for the coming season
JeePee/DVK
« Reply #25 on: May 10, 2009, 18:30:20 pm »
Looking good Henry.
Are you gone race in Lelystad?(KCD)
Grtz:JeePee.
mr horsepower
« Reply #26 on: May 10, 2009, 18:32:18 pm »
Fuel pressure gauge
« Reply #27 on: May 10, 2009, 19:40:38 pm »
Nice car Henri,are you also @ Budel?
mr horsepower
« Reply #28 on: July 26, 2009, 16:04:47 pm »
So i was working on the transmission and build it in the car again .
i also worked on the engine to get it finished for bitburg .
i step to a turbo draw trouhg set up while the supercharger setup still under construction is
i quit like this kind of turbo set ups the are the american way .
i saw mr webbs old engine on ebi with the same set up and i was impressed of its performance
so theres not so much differend in an efi or carb setup if it is propperly tuned so i hope myn runs well on the carter carb.
GR Henri
jamiep_jamiep
« Reply #29 on: July 27, 2009, 09:54:21 am »
Looks cool henri! What turbo you running?
