September 22, 2026, 04:04:30 am
| | |-+  Re: crazy frog beef up the engine
Pages: 1 ... 5 6 [7] 8 Print
Author Topic: Re: crazy frog beef up the engine  (Read 174073 times)
« Reply #180 on: March 02, 2015, 22:07:54 pm »
What brand of piston? usually they tell you what clearance to run with the pistons and every manufacturer has its own specs
mr horsepower
« Reply #181 on: March 02, 2015, 22:22:24 pm »
AA richie and no card involving tolerance .
Never used this ones before
Gr
« Reply #182 on: March 02, 2015, 22:51:38 pm »
If you email Ron barrett at AA I am sure he will help, he is very good like that Smiley
mr horsepower
« Reply #183 on: March 02, 2015, 23:01:59 pm »
Will do that
Thanks.
gr
The Fugitive
« Reply #184 on: March 04, 2015, 00:44:45 am »
Hi henri,
I think you can use some more clearance for the pistons.
on my 103mm bore with SRP pistons, I will run a 0.10mm clearance  Wink
Grt from MR turbo encabulator
mr horsepower
« Reply #185 on: March 04, 2015, 16:37:59 pm »
Yesterday i brought my torque converter to te converter shop to have it set up  for my application.
Hoping to get 4500 rpm stall speed out of it.
will be ready next week .
No i am going to open the engine for a piston and longer cranck  transplant.
I am happy that i decided to go back to turbo
Got my motivation back .
hopefully i got a running car this season..
gr
mr horsepower
« Reply #186 on: March 05, 2015, 21:26:38 pm »
Ok today i pased the point of no return
I opend up the engine and it looks nice
only black oil due the rich mixture hone grooves are gone but i discard the old sleeves annyway
Making a few mods and then putting it back together
gr
« Last Edit: March 05, 2015, 22:03:38 pm by mr horsepower » Logged
mr horsepower
« Reply #187 on: March 05, 2015, 21:58:40 pm »
Tommorow i will wash the engine in my hot tank.
gr
« Last Edit: March 05, 2015, 22:03:12 pm by mr horsepower » Logged
mr horsepower
« Reply #188 on: March 22, 2015, 21:32:25 pm »
After finish my friends type 4 1.7 engine and its a nice engine.
The engine stand is free for my own engine and going on with the build.
First i did the oil ring mod on the pump.
As the press was not wat it ment to be when hot
placed an oil ring from a ford dsg tranny .
The ring is verry soft and had a good seal .se if it helps.
gr Henri
« Last Edit: March 22, 2015, 21:35:35 pm by mr horsepower » Logged
mr horsepower
« Reply #189 on: May 04, 2015, 21:48:11 pm »
I have found some time to work on the car again
i put the longer stroke cranck in the engine .
Sealed the oilpump and lots more .
I made an torque plate to stresshone the cilinders for more wall clearance.
when i have them back comming week i can finish the engine and build it in the car Next step is to get the plumbing for the
Turbo lines and charge cooler.
A friend is comming to help me out with the wiring for the engine manegment system
So hopfully i have a running car this season.
gr henri
« Last Edit: May 04, 2015, 21:52:44 pm by mr horsepower » Logged
The Fugitive
« Reply #190 on: May 06, 2015, 22:24:07 pm »
Post en Dros ? Grin
mr horsepower
« Reply #191 on: May 27, 2015, 20:07:14 pm »
Hi guys Went to the local engine rebuild shop to hone the new cilinders .
and then it was time to build the engine and also make al the fittings and sensors for the efi
I got hold of a set 600 cc injectors that wil feed the engine
i have to make a custom fuelrails for it that i am working on right now
So when thats finish i can put the engine back in the car and hopefully get my mot
The first few hundered km or so i will drive it whitout the turbo
Just N/a to see if everything is working correct .
gr henri
« Last Edit: May 27, 2015, 20:23:41 pm by mr horsepower » Logged
mr horsepower
« Reply #192 on: May 30, 2015, 20:32:38 pm »
Yes today the engine is ready to go into the car
I put the injectors and sensors for efi in
i hope i can fire it up soon
And the autobox will like it
gr henri
mr horsepower
« Reply #193 on: June 06, 2015, 22:05:36 pm »
Hi I got my modified torque converter back .
and i hope that the stalspeed is around 4000 rpm now
Stallspeed wil say that i canput the enginebrake on and load the engine till 4000 on launch
and not much happend until i let go the launch  button
Then the engine rpm wil rise and above the 4000 the converter will hook on and
passing its multible torque to the gearbox factor 2:1  Shocked
Thats why it can be verry effective
Inside my torque converter are manny parts that are upgraded and midified from a porsche unit
Like needle bearings welded and hardened vanes polished and machined stator and  turbine and an enlarged on way clutch
And its also made lighter .
The engine is also back in the car and it al fits wel til now
lets see i can let this baby launch hard in the future .
Thats the first goal ,speed is a later issue.
Converter stall is also termided by engine torque as i dont know the engine torque yet
it will be a gues now .
If its way of we have to open it again and do some mods until its rigth on the spot.
so no charge yet.
till now
gr Henri
« Last Edit: June 06, 2015, 22:48:25 pm by mr horsepower » Logged
mr horsepower
« Reply #194 on: June 06, 2015, 23:03:29 pm »
https://www.youtube.com/watch?v=pTfipsejqS0
if your interested How it works and part of my ocupation.
Have fun.
gr henri
« Last Edit: June 06, 2015, 23:07:35 pm by mr horsepower » Logged
mr horsepower
« Reply #195 on: June 21, 2015, 19:34:13 pm »
Hi i got the engine fired up this weekend .
I hooked up an old weber at the efi intake and made an downflow fueltank that i put on the roof .
put a point distrubitor in it .
and it fired right up .
It runs nice no more smoke and no funny noises and good oil pressure ,the converter is working to .
A buddy of my picked up the ecu he is gonna do the wiring and in 3 weeks its finished.
Now i can realy get it finished ,got a running car at last
if everything goes wel i wil bring it to bitburg this year to do some test runs
Just to see if its getting of the line and run straigth.
and ofcourse to make it reliable so that i can run it all day long in normal traffic.
gr henri
mychatype3
« Reply #196 on: June 24, 2015, 12:36:33 pm »
Nice mate, keep up the good work
Greetings Mycha
1968 fastback "in resto"
1970 Westfalia from the States
mr horsepower
« Reply #197 on: November 21, 2015, 15:45:42 pm »
Got my throttle linkage right now
Gr
mr horsepower
« Reply #198 on: November 21, 2015, 15:46:53 pm »
How can i post a pic from my phone
Who knows ?
Gr
« Reply #199 on: November 21, 2015, 23:47:58 pm »
Hello!
All I know is that I have to host the picture on Photobucket and then post the link on here.
 There are many but I have am stuck with Photobucket.
You can do it from the phone too.
Need more help? Just PM me or write on fredrik.reichel@tetrapak.com
andy198712
« Reply #200 on: November 22, 2015, 14:35:14 pm »
Amazing work!
so does the clutch hook up at 4k rpm? meaning anything less is slips? how does that work out with normal driving?
mr horsepower
« Reply #201 on: November 25, 2015, 17:08:39 pm »
Hi Andy
In theory it will hook at that rpm range
But it isnt freewheeling also .
It wil push the car forward thats why it wil need a transbrake
That stops the input and output shaft  from turning
And the engine needs to be strong enough to overcome the resistant of the tc
So it has more slip than stock
But still good street drivebilety  i hope .
Gr henri
Gr
« Reply #202 on: November 26, 2015, 07:14:26 am »
I had a beetle with turbo engine and automatic.
The Munsinger torque converter would lock up at above 5000 rpm.
It sounded sick when drag racing. People told me something was wrong. But no. Fully normal for that setup.
On the street, it was smooth and nice.
Fuel economy.....not that I noticed but I guess she was pretty thirsty.
andy198712
« Reply #203 on: November 27, 2015, 20:05:35 pm »
Hi Andy
Gr henri
Gr
ahhh i got it, so in theory when you floor it from the line with a brake on it should be fully engaged till 4k. sounds cool!
« Reply #204 on: November 28, 2015, 01:15:39 am »
Here you go Andy, a really quick run-down on the different options.......
http://allfast.com.au/HighPerformance/HiStalls/tabid/860/Default.aspx
......and in addition to a blown Doorslammer with a converter and auto, Gonzo also has a 14sec yellow buggy that he insists on abusing the crap out of for over 20 years, so it's even legal on a VW forum!  Wink
mr horsepower
« Reply #205 on: December 05, 2015, 19:32:34 pm »
Yess the car started up on its own efi tonight
And it sounded verry nice and crispy
Close to mot now
Gr
morkrieger
« Reply #206 on: December 25, 2015, 16:24:28 pm »
morkrieger
« Reply #207 on: December 25, 2015, 16:25:34 pm »
morkrieger
« Reply #208 on: December 25, 2015, 16:27:21 pm »
morkrieger
« Reply #209 on: December 25, 2015, 16:32:26 pm »
 Grin there you go
