October 12, 2026, 11:30:04 am
| | |-+  Re: crazy frog beef up the engine
Pages: 1 2 3 [4] 5 6 ... 8 Print
Author Topic: Re: crazy frog beef up the engine  (Read 176676 times)
mr horsepower
« Reply #90 on: January 15, 2011, 14:50:31 pm »
Hi loungers here s a little update,i redisigned the rearframe for the auto trans and make some brackets to hook it up
i also rebuilded the autotrans and modifid it.
Everything sits in place now it was a lot of cutting and grinding.
The converter is send to a partner  he is going to rebuild it for higher stall speed about 4000 rpm s
Next to do is install the shifter and rebuild the brain of the box and install a transbrake .
Therefore i am going to use a linelock solonoid .
I hope you enjoy the pics.
gr Henri
« Last Edit: January 15, 2011, 14:52:56 pm by mr horsepower » Logged
mr horsepower
« Reply #91 on: January 22, 2011, 19:39:10 pm »
Hi today i was realy happy i recieved my 2 kirkey racing seats and interior parts and droped them right in .
my goal is to build a pro street racing interior.
I also modified the rollcage this week to fit the second seat .
the most of the cutting is done now its going to look like a car again i am happy with the result so far and this is just the begin .
and i still like my 1966 buick wildcat steeringwheel
I hope i can cruise on the streets again this year.
enyoy the pics
gr Henri
« Last Edit: January 22, 2011, 19:54:35 pm by mr horsepower » Logged
mr horsepower
« Reply #92 on: February 16, 2011, 22:57:23 pm »
So an update again for who s interested.
I picked up an old beetle and kut out the rear end of the body.
Then y started to drill all the fucking spotwelds out .
Then i sandblasted the rusty section of the body parts and welded the rotten spots.
And then i welded the left inner fender back in the car and connected the rollcage to the body.
thats all for tonight dudes.
gr henri
« Reply #93 on: February 17, 2011, 00:30:32 am »
Holy crap, BRAVE MAN !
fredy66
« Reply #94 on: February 17, 2011, 01:21:46 am »
Way cool man
arabia slugs
mr horsepower
« Reply #95 on: February 20, 2011, 18:30:19 pm »
Hello today i was working on the car again did some welding grinding and cutting Angry Angry
But finally i was there to fit the engine and autotrans in to the car and ,It fits!!!!!! Grin
I placed the fender and decklid and it closed like it was original ,.
Next to do is to finish it of.
Its going to look like a bad ass streetcar
I also got hold of a original 1960 cadillac brake pedal from a customer who s trans i rebuilded he had a spare nice!
I am a happy man .
enjoy the pics.
Gr Henri
« Last Edit: February 20, 2011, 18:48:08 pm by mr horsepower » Logged
mr horsepower
« Reply #96 on: March 04, 2011, 17:34:27 pm »
So today i made an rpm pick up bracket and installed the tooth disc aswel.
This week i did some shoping for al the electric for the engine managment system .
Its getting there.
gr henri
mr horsepower
« Reply #97 on: March 06, 2011, 14:44:56 pm »
Hi today i did some mock up for the altenator and trottle system ,i am pleased with it
The engine is realy gona look like a bommer .
gr henri
Airspeed
« Reply #98 on: March 06, 2011, 16:14:14 pm »
So today i made an rpm pick up bracket ...
Good progress Henri!
I would however try to fixate the bracket on 2 points instead of only one it now seems to be. These brackets must be super stable or you may get errors on the sensor.
mr horsepower
« Reply #99 on: March 06, 2011, 16:52:17 pm »
Hey Walter there is second fixation connected to the oil pump  but you cant see it in the pic .
its stable enough do .
I am trying to get everything right , and i am not in a hurry but it wil run this summer.
my goal is that when i drive it out of my ched it has to work , i want to drive and not wrenching this summer.
I am getting there
gr henri
« Reply #100 on: March 06, 2011, 17:54:45 pm »
that's a crazy ride, henri!  Wink
mymedusa
« Reply #101 on: March 10, 2011, 09:43:48 am »
damn, i can't see how that trans will perform.
but one question, you really want go blow through with that supercharger and is there a reason for that?
wishes
from germnay
chris
mr horsepower
« Reply #102 on: March 10, 2011, 20:09:47 pm »
Yes the reason is that when its pull trough the mixture will be beaten by the blender effect of the worm wheels and separate the fuel form the oxygen ,and thats bad for engine performance and engine life .
Intercooled efi is the way to go for me.
And i like the fast boost reaction of the charger ,it wil go on boost as soon as i hit the trottle.
So no spooling the turbo up anymore as i have a small engine 1.9 this is the best for me.
i am gaining for a 300 hp at the crank but its a long way ,the torque wil be a more great issue because its there as i blimp the pedal.
gr henri
wishes
from germnay
chris
mymedusa
« Reply #103 on: March 11, 2011, 16:07:04 pm »
thats not that bad, the heat will vaporise the fuel and the mix is good as well.
but in a efi you have no fuel there. and boost respons is also 1:1 with gaspedal in a draw through.
why i ask:
in blow you will need a huge blow by system and the supercharger has alot of parasitic when going from the throttle that will make alot more heat.
draw through with bypass is the best way to go with supercharger. but on the stripe it doesn't matter. on the road it will run colder. what ind of bypass want you use? a sec. throttle like g40 g60 engines or a vacuum tin style?
but definitly yes to the all time torque...i love my daily driver 30ps engine. 150nm from 1700-3000rpm and 70hp at 3900rpm out of close to stock 30hp heads with 1200cc that is torque like a stock 2.0 typ4 . i bet you will have alooooot of  torque down below.
have fun
chris from germany
jamiep_jamiep
« Reply #104 on: March 16, 2011, 08:49:31 am »
Great work on this Henri, a really interesting read. Smiley
dave greiner
« Reply #105 on: March 17, 2011, 20:00:09 pm »
Here is a video of a 10 sec. turbo car with a bus automatic trans.
(the green "67)
<a href="http://www.youtube.com/v/gTWgf9AhJWo" target="_blank">http://www.youtube.com/v/gTWgf9AhJWo</a>
Here is an in-car shot
<a href="http://www.youtube.com/v/SlHjhOx9xLI" target="_blank">http://www.youtube.com/v/SlHjhOx9xLI</a>
« Last Edit: March 17, 2011, 20:17:05 pm by dave greiner » Logged
mr horsepower
« Reply #106 on: May 28, 2011, 16:12:31 pm »
I recieved my new shifter today and it rocks!!
And i need to do some mods on the valvebody for the autobox to make the transbrake work .
Cant wait to make my first burn out muscle car style.
gr henri
« Last Edit: May 29, 2011, 19:06:29 pm by mr horsepower » Logged
mr horsepower
« Reply #107 on: July 09, 2011, 20:10:54 pm »
Hey today i  worked on the hurst pistol grip shifter for the car .
i soon finded out that the geometrie of both the roosters waren t equal .
so i made a test stand and recalbrated the shifter cable and the roosters .
then wen that was working i figurde out how to make the brackets for the cables and holders .
and this is the result .
it shifts like a real pro.
and the neutral lock out is on the right spot
enjoy gr henri
« Last Edit: July 09, 2011, 20:14:27 pm by mr horsepower » Logged
mr horsepower
« Reply #108 on: July 16, 2011, 15:14:26 pm »
Hey today i worked on the brake pedal set up for the autobox.
I must say i am happy that i don t have to work in that little corner again but i am happy with the result
enjoy
hr henri
« Reply #109 on: July 16, 2011, 16:46:56 pm »
nice!
mr horsepower
« Reply #110 on: July 16, 2011, 18:10:23 pm »
Hey i also made a new battery box for my optima batery  in the nose of the car .
yeah no more emty battery s for me and lots of crancking power
The list of things to do is getting shorter i hope in the winter to get to the finish and detailing parts i can t wait.
enjoy gr henri
« Last Edit: July 16, 2011, 18:13:12 pm by mr horsepower » Logged
mr horsepower
« Reply #111 on: September 27, 2011, 21:30:28 pm »
So time for an update of my little green race car.
today  i finaly got the supercharger fixed on the engine and the belt in line we made alloy brackets to hold it in place  the result is good the blower sits perfectly.
Next to do is to fit the manifold and weld the pipes in place ,and work on the belt tension system ,
and then fix the altenator brackets .
And finaly make everything nice and shiny ,polishing al the aloy brackets  Grin
I took some pics today enjoy
Gr Henri
« Last Edit: September 27, 2011, 22:14:54 pm by mr horsepower » Logged
Black Sheep
less is more
« Reply #112 on: September 28, 2011, 11:14:49 am »
Nice work Henri , that looks hard as nails  Cool
 I really like guy's who go their own way , can't wait to see all this come together and put a quick time down .
13.03 @ 98mph
« Reply #113 on: September 29, 2011, 13:30:59 pm »
X2
mr horsepower
« Reply #114 on: October 11, 2011, 21:01:44 pm »
Hi guys  today i worked on the dash i decieded to by myself some new autometer gauges like.
Engine oil press
engine temp
Transmission oil press
Transmission oil temp
I needed space to build them in and so i can have a good look to it
I decieded to use a original black dash cover and i most say it looks good as the whole interieur is going to be black
that looks good in a daily/strip car
the work for today is mock up so its not ready yet
I am happy with the trans gauges so i can monitor what the trans press is doing vs trans temp.
I took some pics enjoy
« Last Edit: October 11, 2011, 21:04:51 pm by mr horsepower » Logged
mr horsepower
« Reply #115 on: October 20, 2011, 22:00:19 pm »
Hi today i worked on the trottle linkage and manifols and belt tension system .
the linkage is working now and finished.
 i had to make some tubes of alloy on the lath to fit in the manifold to suport it when the bolts are torqed its a nice tight shiny fit but you never see it but its al in the details.
the belt tensioner is also ready now i can order a belt,
next to do is welding the alloy pipes from the manifold to the tbi s.
enjoy the pics
its getting there .
tomorow i am recieving my last autometer gauges an can i fit them
gr henri
« Reply #116 on: October 21, 2011, 16:03:35 pm »
Henri, you spend a lot of money on the Optima. Keep it charged all the time or it will die soon. Get yourself a CTEK battery charger.You will not regret it.
Just my 2 cents.
« Last Edit: October 21, 2011, 16:11:31 pm by Harry/FDK » Logged
mr horsepower
« Reply #117 on: October 21, 2011, 20:53:27 pm »
Hi Hary ii have two opima s that are on low volts  the are from the same used batch as the two good ones .
can recharge them with that charger?
gr henri
mr horsepower
« Reply #118 on: November 22, 2011, 20:10:50 pm »
Hey i did some work today .
Ill changed an old autometer shiftlight to a oilpress warning light.
I noticed that many race car engines have a to slow working oil press sender and when an engine comes in the shop .
With all the bearings eaten out the costumer says ,but the light didn t come on!
Its important to have a quick working oil warning light
And a customers project went on the dyno this week we did the tranny engine and rear axle.
It pulled 381 rwhp and loads of torque .
Hit the throttle at 50 kmh and you can buy new rear tyres
just wanted to share the project because i think its a realy nice restored 65 gto
pics
gr henri
« Last Edit: November 22, 2011, 20:25:42 pm by mr horsepower » Logged
« Reply #119 on: November 23, 2011, 12:09:46 pm »
gr henri
Yes, these chargers are perfect just for that. (killing the crystals in the batteries). If Optimas hate on thing, it's being sitting unused on the shelf.
Groetjes,
Harry
