October 13, 2026, 02:49:44 am
| | |-+  Muffler temp ?
Author Topic: Muffler temp ?  (Read 8702 times)
Brown-nose
« on: March 23, 2009, 19:28:56 pm »
Anyone ever pointed a temperature gun at a turbo muffler ? How hot can they get ?
Tony M
« Reply #1 on: March 23, 2009, 20:52:38 pm »
Higher than the gun goes
Brown-nose
« Reply #2 on: March 23, 2009, 22:58:39 pm »
hotter than 400 C (750 F)  Huh
« Reply #3 on: March 24, 2009, 10:05:31 am »
I know that they're hot enough to burn your leg and leave a nice patch of skin on the muffler... Shocked
Brown-nose
« Reply #4 on: March 24, 2009, 10:19:08 am »
I see Eastwoods do header paint that goes up to 650 C but muffler paint (not for headers,manifolds etc) that withstands up to 150 C
I'm not planning on using either of those but do you guys think those figures are accurate ?
Hotrodvw
« Reply #5 on: March 25, 2009, 06:13:24 am »
On the muffler or the head pipe?  I can see the head pipe being up there.......
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Brown-nose
« Reply #6 on: March 25, 2009, 08:44:31 am »
up where though...?  Huh
i don't have a temp gun or a running car. could someone with both give it a try ? thanks
Tony M
« Reply #7 on: March 26, 2009, 22:14:21 pm »
At the head pipe over 600 deg - at the muffler it will depend on if your at idle or at speed - 350-400 at idle - after running for some time - and hot ,hot,hot when under full throttle
Brown-nose
« Reply #8 on: March 26, 2009, 22:32:44 pm »
thanks for the reply...
when you say head pipe do you mean the header or the pipe that goes into the muffler ?
is this temps you have seen ?
i would have thought temps would drop a lot more at speed due to air-flow under the car reaching the muffler ?
Brown-nose
« Reply #9 on: March 30, 2009, 16:52:55 pm »
so i borrowed an IR gun today. after 30 mins at 70 mph + i stopped and took some readings. then i went for a long (45 min) slow drive at 40-50 mph with some traffic stops and some idling. the header (1 3/4 stainless) temp was 200-250 C max and the muffler a bit below that. the hottest part of the muffler was the flange. even the pipe into the muffler box was 200 C or under
this was just pulling over and reading it with the car idling.
