July 15, 2026, 21:34:11 pm
Late Looker (type 4)
7
8
Topic: Late Looker (type 4) (Read 482686 times)
Re: Late Looker (type 4)
Reply #210 on:
February 07, 2026, 09:02:50 am »
Still working on my goal.
But think it will happen now.
Got the remelle heads fitted with valves by JPM.
Also JPM made me a custom cam, so going to spilt the case and install the new stuff.
And a bit of test fitting.
Type 1 Wasp on a type 4 engine
Garrick Clark
Reply #211 on:
June 10, 2026, 18:29:39 pm »
Any up date.
Air cooled Engine builder
Reply #212 on:
June 15, 2026, 07:56:28 am »
Yes, it is in and running.
wanted it to be ready for EBI, but missed the dyno time.
Working on small leaks, which is a bit more time consuming then I want.
And everything needs adjusting, nothing for type 4 in beetle fits well, so a lot off time consuming adjustments.
But it is running and sounds great.
Hope I get it ready in time, fingers crossed.
Last Edit: June 15, 2026, 09:48:45 am by Eddie DVK
BossHogg76
Reply #213 on:
June 18, 2026, 11:20:41 am »
Good Luck Eddie, hope to see it and you at EBI.
Reply #214 on:
June 19, 2026, 09:01:07 am »
Quote from: BossHogg76 on June 18, 2026, 11:20:41 am
Off course I see you there Rob, but don t think I will be with the Beetle.
Will bring a suprise car (aircooled).
Garrick Clark
Reply #215 on:
June 20, 2026, 20:15:53 pm »
Good stuff.
I'm having to re build my type 4 turbo, because someone on here lign bored the case wrong, so as there are no 1 mm case bearings available, I'm having to start over with a standard case. I think it's bad that us type 4 guys are have to take a big risk on a case that's standard,going to 0.50, which if done wrong, renders the case scrap until bearings are available, which might be never.
Reply #216 on:
June 22, 2026, 08:49:21 am »
Quote from: Garrick Clark on June 20, 2026, 20:15:53 pm
Good stuff.
Well I know the problem.
But if I see case bearing sold, I always order a few. (from him
http://cal-look.no/lounge/index.php/topic,32466.0.html
Well, I always go to germany for line boring. It is only 1,5 hour drive for me.
Regards Eddie
Garrick Clark
Reply #217 on:
June 22, 2026, 10:17:47 am »
Cool thanks.
7
8
