September 14, 2026, 22:14:12 pm
Latest Member: Bad Habit
| | |-+  The Berg's '67 tribute
Pages: 1 [2] Print
Author Topic: The Berg's '67 tribute  (Read 57343 times)
quik6six
« Reply #30 on: April 02, 2009, 07:49:21 am »
Your eyes are better than mine Fred cause I didnt see that till you mentioned it.
Frank LUX
Back...Soon...hopefully!!!
« Reply #31 on: April 02, 2009, 08:41:39 am »
Okay... I don't mean to be weird, but why does the left rear fender have the overrider hole (plugged) and the right side does not? Forgive me if I'm not seeing it. I AM old and my eyes are like that of a person 50 years older than me. Sorry in advance, if I'm wrong.
Maybe it's for that Moroso "ON/OFF" Switch.... Wink Huh
Frank
NAO
« Reply #32 on: April 02, 2009, 09:15:33 am »
Good eye!! Fred
Left rear is fitted with plug which I hate. I wanted to use stock gromet and left the hole open like front apron. Right side fender came as no hole and I was going to make a hole but it was 3am on Saturday night. I arleady made enough bung sound and I can not go on and on...my neighbor will kill me for that.
So, I just use plug on left fender.
Moroso kill switch will be mounted on right side of rear quarter panel.
To: Bewitched
Herrod Helper I used is old staff and I do not know who has one now.....
For the record, Herrod Helper's stands positioned oposit...I know.   Grin
« Reply #33 on: April 02, 2009, 09:56:32 am »
Nao,great car man.I like it a lot.(more pics please)  Wink
charlie
« Reply #34 on: April 02, 2009, 10:03:20 am »
This engine was once intalled on the white '67 of XXXXXXX and can be seen on Hot VWs magazine. Guess who?
However, the heads need to be re-welded and fix. Need new guide and seats.
So .
- Small displacement with high compression
- White '67  (with blue lettering on the side )
Hummmm ... i vote for :  Mike Smith
Fritter
« Reply #35 on: April 03, 2009, 00:08:52 am »
Nice job Nao!!  The Berg black car is timeless.
Mike F.
'64 Indigo Blue sunroof Bug
NAO
« Reply #36 on: April 03, 2009, 11:00:17 am »
Charlie
Nice guess! Indeed it's ex Mike Smith engine and spec goes like this.
69mm crank wedgemated to stock weight flywheel
88mm P/C w/deel valve pockets
Carrillo's(I need to measure them for the length)
Engle FK-89
Welded VW Heads (42mmx37.5mm? I have to re-check)
etc.etc.
I have to take it out from the car this weeked and check everything!!
It should be fun engine to deal with!
For the event to show it, I changed it's linkage to old original EMPI IDA linkage and use MOONEYES Breeather box which looks so cool!! and I did not have Stinger ignition system in hand and I just put Vertex magneto. I will take some photo and post later
charlie
« Reply #37 on: April 03, 2009, 11:37:04 am »
Charlie
Engle FK-89
etc.etc.
Hi .
42/37.5 for 88 the int valves are very close to wall cylinder .
Eric Ballard (Erco) use 40 int. for this small engine NHRA record.
Thanks to share this new project .
Gunter
« Reply #38 on: April 17, 2009, 07:31:21 am »
Hey Nao
good luck this weekend for the race
keep us informed about times
Gunter
NAO
« Reply #39 on: April 17, 2009, 12:04:26 pm »
Sorry for late replay....
Charlie, Valve is indeed 42 x 37.5mm !!
I do not have a picture with me to up..sorry!! But I will do so...
Now the engine is done and installed last night. All the electric is done also and everything work so far!!
So, I will bring the car to the truck tomorrow!! So, let's see what this small engine can do!!
 Smiley
MacRavens
« Reply #40 on: April 18, 2009, 23:05:55 pm »
Hé, Nao,
With this kind of Berg tribute you must wear some plaid shirts, cloth hat, Vans shoes and make some skateboard actions ! Wink Wink
you can choose what you want in this display Wink
« Last Edit: April 18, 2009, 23:08:56 pm by MacRavens » Logged
NAO
« Reply #41 on: April 20, 2009, 07:04:59 am »
YES, I like that brown one on the shelf....is that GB ....XL ?? Grin
Pages: 1 [2] Print
