November 04, 2026, 16:04:49 pm
| | |-+  A bit confused.... 2017cc
Author Topic: A bit confused.... 2017cc  (Read 7999 times)
FDK/mrpedrini
« on: April 01, 2009, 12:48:11 pm »
 Hey guys and girls.....
I' scratching some parts together to build a 2017cc stroker engine. I managed to build some stock stroke engines.... but to build this stroker is a bigger chalange for me..... I got almost al parts together, but the more i read the more i lose my confidence in the parts i've bought... The idea of wrong purchases is killing me...
So, I've got two issues at the moment...
1: Í've purchased A cilinders and pistons... can i get away with the use of a 78.4 stroker crank?
2: I've got some Berg pushrods (GB 425- 11000 long) laying around... Do i need longer ones?
« Last Edit: April 01, 2009, 12:55:56 pm by FDK/mrpedrini » Logged
« Reply #1 on: April 01, 2009, 13:59:32 pm »
the answer to your 1st question would be yes (if you use 5.5 rods) if stock then you'll need to either flycut the heads or the barrels.
67worshipper
« Reply #2 on: April 01, 2009, 14:21:15 pm »
what cam are using? pushrods arent that expensive so if you have to replace them then do so.are the pushrods already cut to length?
vw hot rod heaven
Jesse/DVK
'64 2176cc
« Reply #3 on: April 01, 2009, 14:31:29 pm »
Are you sure? Especially with a 5.5 rod he will need B pistons.
FDK/mrpedrini
« Reply #4 on: April 01, 2009, 18:02:40 pm »
I'm using a Webcam W 218, possably with 1.25 rockers. Pushrods are not cut at length, are stock length (like original 1600).
Today i did fit one cylinder,  And i could get away with a 4.5 (and some more) shim, but 'if i was using "B"type cilinders and pistons i wouldn't need such a big shim....Huh?? Or am i wrong??
The rods are 5.4 CB performance H beams (that's also stock length)....Already thank you for the replies!!!! Regards Dennis....
dirk zeyen
« Reply #5 on: April 01, 2009, 22:14:39 pm »
hello dennis,
take B-pistons.
A-pistons will work, but you have to use spacers and maybe the engine tin won't fit anymore, maybe you have to clear A-pistons for the longer stroke. A-pistons are heavier.
dirk zeyen
back again!!!
Bewitched666
Bewitched
« Reply #6 on: April 02, 2009, 07:11:55 am »
I agree with dirk as using spacers to get the cr you want can be a pain in the butt.
Fast vw beetle's rule
« Reply #7 on: April 02, 2009, 09:22:11 am »
Sorry to hi-jack this tread guys,but my technical background ain't that good,
so here comes my question:what are "A" and "B"cilinders?
Help me out.
Peter  Wink
Jesse/DVK
'64 2176cc
« Reply #8 on: April 02, 2009, 09:24:32 am »
The difference between A and B pistons is the height of the piston pen in the piston. In the B pistons the piston pen is higher in piston. A pistons are for stock stroke and B pistons for 78 and higher strokes
« Reply #9 on: April 02, 2009, 09:58:06 am »
Thanks Jesse,now it's clear.
Peter  Wink
« Reply #10 on: April 02, 2009, 16:52:33 pm »
sorry i meant that... you are right. that is what i would get anyway. 5.5's and B pistons.  Embarrassed
FDK/mrpedrini
« Reply #11 on: April 03, 2009, 11:11:31 am »
Thanks for help guys...... I can continue the job now..
there is also more usefull info in the 2276 internet engine kitchen build tread...
regards, Dennis..
Bewitched666
Bewitched
« Reply #12 on: April 04, 2009, 15:42:17 pm »
Its not a rule but you can use A type pistons for strokers up to 82mm.
The things is that the sideload is more severe on a type pistons especially with stocklenght rods but it can be done Cool
