September 22, 2026, 11:28:43 am
| | |-+  Auto Meter tach wiring...oil light.
Author Topic: Auto Meter tach wiring...oil light.  (Read 6298 times)
bugnut68
« on: April 03, 2009, 23:51:44 pm »
I got the wiring diagram/instructions off the AutoMeter site for the tach and shift light, just wanted to know how to hook up the oil light?  Is one wire a ground and the other go to the sending unit?   Electrical is not my forte... my directions don't indicate anything about an oil light.
Kaferdog
« Reply #1 on: April 04, 2009, 00:25:02 am »
Yes one is ground and one taps off the oil light on the speedo..that's how I did mine
bugnut68
« Reply #2 on: April 04, 2009, 01:07:50 am »
Sweet!  First time my instincts were correct on anything electrical!   Grin
Gary Justus
« Reply #3 on: May 15, 2009, 18:50:21 pm »
Can/Do you use the stock sender?
JS
« Reply #4 on: May 15, 2009, 19:47:31 pm »
Yes, at least I do.
Signature.
JS
« Reply #5 on: May 15, 2009, 19:50:36 pm »
Yep, the wire going to the og oil light is +. The og oil pressure light sender short circuits when there is NO pressure, thereby completes the circuit and the light goes on.  Smiley
Signature.
Gary Justus
« Reply #6 on: May 15, 2009, 20:22:20 pm »
Thanks! Just what I needed.
