October 04, 2026, 05:30:19 am
48 IDF Idle problems
Topic: 48 IDF Idle problems (Read 6181 times)
karmann77
April 05, 2009, 21:13:10 pm »
When the motor gets warm it tends to idle at about just under 2000 revs, what could the problem be?
Re: 48 IDF Idle problems
April 06, 2009, 01:14:43 am »
Check your distributor's advance mechanism. It could be sticking in an advanced position.
karmann77
April 06, 2009, 13:15:46 pm »
we swoped the dizzy over and the problem is still there
Roman
April 06, 2009, 18:51:24 pm »
What do you mean with it tends to idle just under 2000? Does it mean that the idle increases to just under 2000 or don't the engine run under 2000 rpm?
dirk zeyen
April 06, 2009, 19:36:25 pm »
maybe a sealing problem, only when the engine is hot. if it can get more air, the mixture is getting leaner and the idle speed goes up.
dirk zeyen
back again!!!
