September 23, 2026, 09:20:44 am
| |-+  For sale!
| | |-+  2276cc engine kit
Author Topic: 2276cc engine kit  (Read 18134 times)
airstuff
« on: April 06, 2009, 13:55:56 pm »
Hmm,I hate to say this,but I have to sell my 2276cc engine parts.It's all due to economy crisis and harder times coming  Sad
Engine parts are:
82mm  counterweighted 4340 chromoly crank(it has the strongest 11/32" dowel pins speccialy machined in when bought by my request)balanced,nitrited,micropolished
Balanced along with
12.5 lbs balanced and lightened flywheel,11/32" dowels
Kennedy Stage II pressure plate(balanced with flywheel)
Scat 5.4 I beam rods, 3/8 ARP rod bolts
BrothersVW AS 41 New magnesium case,machined for full flow,all oil gallery tapped&plugged,sleeved lifter bores(silicone bronze),stroker clearenced,bored for 94 cylinders,cut for sand seal,deburred
Engle FK-10
Manton chromoly pushrods
Bugpack straight cut cam gears
Mahle 94mm piston&cylinder set
 doghouse oil cooler with seals
26mm schadek oil pump,with full flow cover(pump is blueprinted and plugged for full flow),scat sump
CB Performance 30mm Lightweight lifters
CB Performance new 1.4 rockers with everything
CB Racing big mouth pushrod tubes
2.5 LB Equalizer pulley,black with white numbers,cut for sand seal(machine in),sand seal included
Steve Tims Stage 2 043 casting cylinder heads, 42x37.5 ss valves,double springs,chromoly retainers&keepers(matched ported big beef IDF manifolds)
all bearings,cam bearings(mahle)main&rod bearings KS
Cylinder deflectors new
8mm chromoly cylinder stud kit-CB Performance
Bugpack exaust nuts
end play shims
All parts are 100% new,not even bolted together.
if I forgot anything I will add later :)and pictures also
I would like to sell it as a kit,to someone who will give life to this engine
I am located in Croatia.
Price for the whole lot is 2300 Euros or around $3000. Lips Sealed
« Last Edit: April 06, 2010, 16:33:02 pm by cal-look » Logged
dirk zeyen
« Reply #1 on: April 06, 2009, 19:38:45 pm »
 Cry Cry Cry
very bad news.
dirk zeyen
back again!!!
peach_
« Reply #2 on: April 06, 2009, 20:09:44 pm »
would you be interested in spliting?
If so how much for the cank and rockers?
cheers
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
airstuff
« Reply #3 on: April 06, 2009, 22:12:41 pm »
cheers
hello peach,
thank you for you interest,but at the moment I wouldn't like to split this kit Undecided
Rocket Ron
It's old school for a reason
« Reply #4 on: April 07, 2009, 02:11:06 am »
any idea on price?
13.12 @ 101.84
Grooving out on life
airstuff
« Reply #5 on: April 07, 2009, 11:44:27 am »
some more pics
« Last Edit: April 06, 2010, 16:37:36 pm by cal-look » Logged
airstuff
« Reply #6 on: April 07, 2009, 15:40:40 pm »
I don't have everything pictured,but I will try to make one group pic of all items listed.But for now you get the idea that everything is new Smiley
airstuff
« Reply #7 on: April 07, 2009, 16:07:40 pm »
Cry Cry Cry
very bad news.
dirk zeyen
yes my friend,that is how it is now Undecided
airstuff
« Reply #8 on: April 07, 2009, 20:15:54 pm »
does 2300 Euro sound reasonable for the combo ::)I think it does.
« Last Edit: April 06, 2010, 16:35:51 pm by cal-look » Logged
peach_
« Reply #9 on: April 07, 2009, 21:44:32 pm »
Ok no worries,  if you do end up splitting can i take 1st call on the crank and rockers? Grin
cheers Wink
#CALLOOKDRAGS
airstuff
« Reply #10 on: April 08, 2009, 12:21:27 pm »
cheers Wink
if it happens you can count on it Smiley
airstuff
« Reply #11 on: April 08, 2009, 12:21:59 pm »
bump
beetlemic
« Reply #12 on: April 08, 2009, 21:20:14 pm »
Hi Zvon,
It's to bad, feeling so sorry for you Cry
But if it helps i might also be interested if splitting engine.
starting to build up for another 2332cc, need case cylinders and barrels so if you decide to split send me an pm.
Michael
airstuff
« Reply #13 on: April 06, 2010, 16:14:40 pm »
up for sale again
for the price,look at the first post
« Last Edit: April 06, 2010, 19:28:04 pm by cal-look » Logged
Wünderwolff
aka Dr. Jeckill
« Reply #14 on: April 06, 2010, 21:03:08 pm »
Had I not bought my big bad engine from Dez (I mean bad in the Michael Jackson kind of way, don't misunderstand me) I would have invested in this lot. This is a lot of kit for relatively little money!
Cheers,
Tim
Wünderwaffe are Go!
airstuff
« Reply #15 on: April 07, 2010, 07:58:55 am »
Cheers,
Tim
I understand Tim.
Thanks for helping promote this Smiley
airstuff
« Reply #16 on: April 07, 2010, 11:59:14 am »
there is always a possibility to drive this parts somwhere,lets say austria as the furthest possible half away if anyone from around europe would be interested
« Reply #17 on: April 07, 2010, 15:37:30 pm »
Zvonimir, thats sad to hear. I´d be interested in equalizer pulley as I need one more for my EDIS conversion if you decide to split the kit. My best advice is..store it in the cellar and get back to it when times get better.
funy123
« Reply #18 on: April 10, 2010, 04:10:40 am »
I'll need to sell some things myself to pay for it. let me know how to get it from you.
curb your enthusiasm 1-7
Sebcox
« Reply #19 on: April 15, 2010, 17:54:13 pm »
you've got pm !
early-air
« Reply #20 on: April 26, 2010, 23:05:29 pm »
has this sold?
JG54 greenhearts
Sebcox
« Reply #21 on: May 03, 2010, 21:03:03 pm »
hi,
if you can't send the parts anywhere in europe or worldwide, i don't know how you can sell them !!!
i'm interested by the parts but i live in France. if you have any solution for the shipping, send me pm !
seb
Doktor
« Reply #22 on: May 04, 2010, 16:14:20 pm »
Just for info - engine parts aren't for sale anymore...
My friend took my advice - he will wait some time to collect all the parts and he has a car for the engine - a perfectly original Yugoslavian bug with very little original miles... Cool
That car will receive Cal-Look treatment  Cool Cool Cool
dr.aircooled
airstuff
« Reply #23 on: June 07, 2010, 11:36:51 am »
no,it still is for sale
« Reply #24 on: June 11, 2010, 15:27:19 pm »
PM sent
airstuff
« Reply #25 on: July 18, 2010, 16:53:34 pm »
SOLD and will be put to better use and abuse,than I could have done with it  Smiley
Please lock  Wink
