September 22, 2026, 01:38:59 am
| | |-+  Grelland's Ghia
Pages: 1 ... 10 11 [12] 13 14 ... 20 Print
Author Topic: Grelland's Ghia  (Read 373205 times)
Grelland
« Reply #330 on: April 28, 2008, 21:57:27 pm »
and the engine bay has received the same treatment
___________________
Roy
Rune
SCC Crew
Screwdrivers #7
« Reply #331 on: April 28, 2008, 22:40:25 pm »
Great work Roy, can't wait to see the car in real life... As for the oil filter I like to have them mounted horizontaly. It makes for easier filter changes without getting oil on your hands..
Grelland
« Reply #332 on: May 10, 2008, 22:18:22 pm »
Thanks, Rune, I will hava a closer look at this when the car is back from paint.
Something tells me there will be a rush to get all these issues solved before SCC...
Back to the progress:
I have replaced the problem area on the RHS front fender, the area aroud where the fuel filler flap once was welded shut. Now, there is a genuine non-fuel-flap piece of steel here:
___________________
Roy
Grelland
« Reply #333 on: May 10, 2008, 22:20:38 pm »
Then I spent sonme evenings cleaning up the underside of the front fenders, and after grinding down the welds, removing surface rust and also some sand-blastingm the underside of the fenders got a layer of the 2-k epoxy primer:
___________________
Roy
Grelland
« Reply #334 on: May 10, 2008, 22:23:47 pm »
and after applying body sealant in all joints and welds, I applied a generous layer of s product called "Body 5000" from wurth. This becomes semi-hard and is over-paintable:
___________________
Roy
Grelland
« Reply #335 on: May 10, 2008, 22:24:38 pm »
Next thing now is a layer of paint before the car is sent off to the painter :-)
___________________
Roy
Grelland
« Reply #336 on: May 14, 2008, 18:35:05 pm »
but before i can paint, I also added a layer of the damping material to the luggage compartment in the front:
___________________
Roy
Grelland
« Reply #337 on: May 14, 2008, 18:36:10 pm »
And I screwed up by braking this molded piece that takes the heated air into the passenger cabin...
___________________
Roy
Grelland
« Reply #338 on: May 14, 2008, 19:12:21 pm »
Last night I mounted the shelves next to the rear seat, after finalising the heater tubes (I know some of you wonder why bother with all this heater stuff, but I live in Norway, and intend to use the car more than 3 weeks in the summer...)
___________________
Roy
Grelland
« Reply #339 on: May 14, 2008, 19:13:40 pm »
This area is almost ready for primer and paint now, and I am also prepping the front firewall in order to cover that area with the damping material also:
___________________
Roy
roland
lates are the new splits...
« Reply #340 on: May 14, 2008, 22:38:34 pm »
MArathon resto! nice work grelland, as usual...
« Reply #341 on: May 15, 2008, 15:29:39 pm »
Even us just 25 km's to the south of you are wondering!!  Wink
Grelland
« Reply #342 on: May 15, 2008, 17:22:17 pm »
but then your slogan cut from the top of this page is "- It’s a Cal Look thing – you wouldn’t understand”, so I am not going to try to explain it to you
 Grin
« Last Edit: May 16, 2008, 07:40:52 am by Grelland » Logged
___________________
Roy
« Reply #343 on: May 16, 2008, 11:50:02 am »
True, I would never understand...
Grelland
« Reply #344 on: May 20, 2008, 22:34:19 pm »
Now for an update:
The inside and underside of the car is now painted:
___________________
Roy
Grelland
« Reply #345 on: May 20, 2008, 22:35:57 pm »
And the car is loaded on the trailer, and will be at the paintshop by 0700 tomorrow morning  Cool
btw the pics are taken at about 10:00 PM tonight, and as you can see, the spring is here.
Life is good....
___________________
Roy
« Reply #346 on: May 21, 2008, 01:52:35 am »
You've got to be feeling good about that!
When did you start this project??
Grelland
« Reply #347 on: May 21, 2008, 05:56:25 am »
Oh yes this is a good feeling, I started the project in 1998....  but I didnt start really working on it until about 3 years ago
___________________
Roy
jamiep_jamiep
« Reply #348 on: May 26, 2008, 14:28:27 pm »
looks great grelland, whens it coming back from the painters?
Glauco
« Reply #349 on: May 27, 2008, 20:58:54 pm »
congratiulations on the work
all the respect isn't good enough  Grin
glauco
empicolector
EMPI RULES
« Reply #350 on: May 28, 2008, 15:49:51 pm »
nice work
Grelland
« Reply #351 on: May 28, 2008, 18:53:50 pm »
Thank you all, but I am afraid I have some bad news....
The car is back in my garage, and will be there until August...
The painter underestimated the amuount of work his panel-beater had to do, so the panel-beater didnt have time to finish it up before his summer vacation...
So now I will have time to finish and install the engine, and hopefully even fire it up before it goes back to the paint-shop.
I was a TAD disaappointed and sick of the whole thing for a few days here, but now I am back with more inspiration :-)
SCC 2008 is out of the question, though  Embarrassed (unless some of you guys out there know of a GOOD painter that can do this now.
___________________
Roy
Mags
2,2L 577Hk.
« Reply #352 on: May 28, 2008, 19:05:42 pm »
Roy,
You can ask Larvik Billakksenter,Hegdalsveien 76
Magne
« Reply #353 on: May 28, 2008, 22:40:29 pm »
This sucks Roy, I'll call you tomorrow...
Grelland
« Reply #354 on: May 28, 2008, 23:09:12 pm »
please do Wink
and yes it sucks...
big time
___________________
Roy
Grelland
« Reply #355 on: June 04, 2008, 01:04:33 am »
Now that I am waiting for the panel beater to find time in his schedule, I am working on all the other bits and pieces that need to be finished anyways, and the last few days i have accomplished the following
- Steering axle and wheel reconditioned and mounted
- Front brake calippers and brake hoses fitted
- Gearbox lowered about half an inch in the rear in order for the engine to fit the sealing perfectly
- Injector bungs welded in the other intake runner
I had set myself a target before the painter threw in the towel, and that was to attend the SCC event on August 15th. This may still happen, but if so, the car will be in primer and not paint, and it might actually be a good idea to trial mout everything before paint, as drilling and cutting a newly painted car is no fun...  And yes I have paid the starting fee for the drag-race...
Next on the list now is to finish up some the details in the engine, including a new fuel line, but I have to go to the UK for a business trip end of this week, so progress will be slow for a few days again...
___________________
Roy
Grelland
« Reply #356 on: June 10, 2008, 23:08:53 pm »
So I am finally back from my trip, and have startet on my long list aiming for the dragstrip at SCC.
The car will then be in primer, but that is the least of my worries at the moment.
I put the engine back in the car, and first of all, I mounted the runners to verify that the plenum now clears the firewall, and it does:
___________________
Roy
Grelland
« Reply #357 on: June 10, 2008, 23:13:26 pm »
then I needed to find a way to connect the right hand side pedal with the plenum, and came up with a solution using a wire-extention kit intended for dune buggies. I made a bracket, and I think this will work, I just need to check for clearance with the fan shroud
___________________
Roy
Grelland
« Reply #358 on: June 10, 2008, 23:16:21 pm »
I also made a holder fror the injectors, but forgot to take a picture...
Next on the list was to weld in the bung for the WB O2 sensor on the collector, and it is a tight fit, but it fits...
___________________
Roy
Grelland
« Reply #359 on: June 10, 2008, 23:18:43 pm »
And finally a shot of the engine height: I wolud still want the engine to sit a cm or so lower, but now the seal will work, so that is the main issue for now:
___________________
Roy
