September 21, 2026, 22:43:28 pm
| | |-+  Grelland's Ghia
Pages: 1 ... 17 18 [19] 20 Print
Author Topic: Grelland's Ghia  (Read 372692 times)
Grelland
« Reply #540 on: March 22, 2010, 22:26:51 pm »
OK, I wanted to have a closer look at the wheels on the car, and also take it for a test drive, so first the good news:
There is rain on the car, so there is the proof that it runs and I took it for a spin around the block:
« Last Edit: March 23, 2010, 08:04:39 am by Grelland » Logged
___________________
Roy
Grelland
« Reply #541 on: March 22, 2010, 22:27:59 pm »
The wheel sits rather nicely in the opening, ok?
Then to the other side:
Approx same angle and distance from the wheel:
___________________
Roy
Grelland
« Reply #542 on: March 22, 2010, 22:29:03 pm »
What the heck?Huh
Where did the rhs wheel go?
I am currently investigating what happened here, and will be back with an update later.
All good ideas are welcomed Smiley
___________________
Roy
Rocket Ron
It's old school for a reason
« Reply #543 on: March 22, 2010, 22:40:22 pm »
did you only narrow one side HuhHuh? Undecided
13.12 @ 101.84
Grooving out on life
Grelland
« Reply #544 on: March 22, 2010, 22:42:15 pm »
this is an original front beam...
___________________
Roy
Grelland
« Reply #545 on: March 22, 2010, 22:43:35 pm »
ok, I did some measurements, and first I did the same before I removed the old narrowed beam, and here are these measurements:
___________________
Roy
Grelland
« Reply #546 on: March 22, 2010, 22:44:55 pm »
this indicates that with the old beam, dropped spindles and EMPI wheels, I am within 3-4 mm side to side. Not too shabby.
Then todays measurement:
« Last Edit: March 23, 2010, 00:06:45 am by Grelland » Logged
___________________
Roy
Grelland
« Reply #547 on: March 22, 2010, 22:48:13 pm »
a little hard to read, but it seams that there is some 30mm difference. I took this measurement close to the center of the wheel, since the camber probably is way off.
I checked a couple of things, and that was the offset of the wheels, and the distance to the brake disc, and all checked out.
So I will simply have to work my way inwards, as there is a number of things that can have ended up misaligned, icluding the beam itself, the blade springs, the trailing arms, and the spindles. Maybe some of the set screws didnt quite align up with the indents in the springs.
___________________
Roy
« Reply #548 on: March 23, 2010, 00:50:15 am »
Hi Roy Try Measuring from the Frame head out  you could have Bent Trailing arms on the right side (pass/Side Grin)
Grelland
« Reply #549 on: March 23, 2010, 08:07:01 am »
That's an option, I will do the measurement, but I used the same trailing arms as with the EMPI wheels, and then everything was ok...
___________________
Roy
Grelland
« Reply #550 on: March 25, 2010, 22:58:46 pm »
I managed to get some measurements done, and it seems that the beam is quite centered on the framehead, and trailing arms also checked out ok.
As suspectedm the camber angles were way off, and with a couple of other adjustments, I managed to get the tho ssides within some +/6-7 mm, so I think that by maybe trying to move the beam over a couple of mms and maybe also loosen the body-chassis bolts and adjust the body vs the floorpan, I will get close enoughh. I have had a couple of friends point out that this is not worse than most other cars anyways...
___________________
Roy
Grelland
« Reply #551 on: March 25, 2010, 23:00:47 pm »
On the right hand side, the rear tyre just barely cleared the fender, so I took a couple of shot of the 7" wheel in its final location, maybe the car need to be raised a little in the back though:
___________________
Roy
Grelland
« Reply #552 on: March 25, 2010, 23:02:49 pm »
and a full view of the car. The front height is about right, but it's a bit too low in the back.
Also the side mouldings are about to be mounted one of the coming days, and it needs a thorough cleaning Smiley
As you can see, the snow is gone at least from my driveway Cheesy
___________________
Roy
JS
« Reply #553 on: March 26, 2010, 06:50:21 am »
Those rear wheels sure look nice!  Grin
Signature.
« Reply #554 on: March 26, 2010, 06:54:38 am »
yep they do!
« Reply #555 on: March 26, 2010, 14:35:59 pm »
hello Roy,
as a reference: i have late 6 fuchs with 195/70 or 80? and have about 1.5 - 2 cm space between tyre and arch,
The irs is not narrowed.
I would take a tyre like that on your fuchs; heres a pic of my car
Grelland
« Reply #556 on: March 26, 2010, 19:16:57 pm »
nice Smiley
do you know the offset/backspacing of that wheel?
___________________
Roy
« Reply #557 on: March 26, 2010, 19:31:49 pm »
Here you go Smiley
Grelland
« Reply #558 on: March 26, 2010, 19:46:49 pm »
excellent
flat and deep 6 have the same offset then. interesting
thank you
___________________
Roy
57Drag
« Reply #559 on: March 29, 2010, 19:38:02 pm »
Nice work so far.Going to try and run 15 x 6 and 15 x 7 Phone dials on my ghia.Going to be tight.
Grelland
« Reply #560 on: April 03, 2010, 21:31:10 pm »
That will be tight indeed Wink
Easter ie here, and some work has been done, including starting the long dreaded job of drilling holes for the side moldings..
I also mounted tyres on the front wheels, and I must say I like the looks of this Smiley
___________________
Roy
Grelland
« Reply #561 on: April 26, 2010, 20:40:15 pm »
today I got a job done that I hve feared for the last 2 years; I drilled the holes for the side moldings....
Seems ok, but I am a nerve-wreck now...
___________________
Roy
Wout
« Reply #562 on: April 26, 2010, 22:56:42 pm »
Looks more then perfect to me!!!
Awesome ghia!!!
gr
Wout
Aircooled vw's for life!
« Reply #563 on: April 26, 2010, 23:56:24 pm »
Looks perfect Roy! Now have a rest Wink
Grelland
« Reply #564 on: April 27, 2010, 06:48:19 am »
thanks, guys.
one more side to go...
___________________
Roy
Grelland
« Reply #565 on: April 28, 2010, 20:46:20 pm »
now also with fuchs in the rear.
I need to raise it an inch or two in the rear, it seems
___________________
Roy
thehanz DVK
« Reply #566 on: April 30, 2010, 16:01:13 pm »
almost time to enjoy man.....the result of hard work and a good turn out, i like this ghia...
Grelland
« Reply #567 on: May 08, 2010, 23:19:17 pm »
Thanks,
one more shot in the sunshine.
I cant wait to get the plates on it now. Norwegian bureaucracy is a bit slow at times...
___________________
Roy
Grelland
« Reply #568 on: May 20, 2010, 22:15:42 pm »
I got the response I wanted from the road authorities, that the engine, brakes, lowering and wheels are approved, so I am a happy camper at the moment.
I also raised it one notch at the rear:
« Last Edit: May 20, 2010, 22:18:02 pm by Grelland » Logged
___________________
Roy
Wout
« Reply #569 on: May 21, 2010, 20:05:14 pm »
Love your ghia! Really nice!
Hope one day mine looks as good as yours  Roll Eyes.
Have fun with it!
gr
Wout
