September 22, 2026, 00:44:37 am
Grelland's Ghia
19
20
Topic: Grelland's Ghia (Read 373100 times)
Re: Grelland's Ghia
Reply #570 on:
May 23, 2010, 19:23:43 pm »
Wow nice looking Ghia !
Grelland
Re: Grelland's Ghia
Reply #571 on:
June 01, 2010, 22:51:18 pm »
I took it out for a spin today, to check that things are oke before the road authorities will go through it, and I also managed to get some tuning done. It started out on the lean side, but after a few minutes in autotune mode, I saw the AFR values normalise, and it ran better and better. Pure magic...
I will have to go through the maps to smooth things out a bit, but I would say it is 90% in tune after 1 hr on the road.
I took a shot of the car during one of my pit stops
Temp looks good (180-200°F), pressure looks fine 12-15 psi at tickover, 20 psi around 2k.
But I need to have the front end aligned, as it was all over the place at speed, but that will be done professionally the next few days.
___________________
Roy
Re: Grelland's Ghia
Reply #572 on:
June 02, 2010, 01:42:20 am »
Looking good. So was all that hard work worth it?
Re: Grelland's Ghia
Reply #573 on:
June 02, 2010, 06:52:40 am »
Congratulations Roy! What's another hour of adjusting in the big picture?? Nothing!
Keep on driving... soon you will be driving of the island to!
Grelland
Re: Grelland's Ghia
Reply #574 on:
June 02, 2010, 14:59:56 pm »
Quote from: louisb on June 02, 2010, 01:42:20 am
ooooooohhh yes
___________________
Roy
Re: Grelland's Ghia
Reply #575 on:
June 02, 2010, 15:13:32 pm »
cool, must be rewarding!!
make sure to post some pics now that you're out in the daylight with no snow around
DVK ~
Grelland
Re: Grelland's Ghia
Reply #576 on:
June 04, 2010, 20:29:16 pm »
Sure, as soon as the plates are on, I will shoot some more pics
___________________
Roy
Wout
Re: Grelland's Ghia
Reply #577 on:
June 04, 2010, 21:39:49 pm »
Verry nice!
Hurry and make some more foto's before 'BP' goes down
gr
Wout
Aircooled vw's for life!
Grelland
Re: Grelland's Ghia
Reply #578 on:
June 04, 2010, 21:44:47 pm »
hehe, that gas station is not operating any more, it's a local car club that resrtored it.
but I do realise that BP is probably not the hottest brand around these days....
Last Edit: June 04, 2010, 23:37:10 pm by Grelland
___________________
Roy
Re: Grelland's Ghia
Reply #579 on:
June 05, 2010, 22:18:58 pm »
Nice !
Re: Grelland's Ghia
Reply #580 on:
June 17, 2010, 10:21:25 am »
Quote from: Grelland on June 04, 2010, 21:44:47 pm
I've just been told about a new type of car that runs on water...
Unfortunately it's only water from the gulf of Mexico!
Looks awesome Roy! I was a little concerned when you started talking about Fuchs instead of the Empi's, but when they look that good it all makes sense!
Grelland
Re: Grelland's Ghia
Reply #581 on:
November 01, 2010, 20:14:23 pm »
WOW, time flies,
Since the last update, I have managed to drive the car a little, kill the enginge, then rebuild it by line-boring the case, and put in an original 69mm crank, and last but not least, the car FINALLY passed all the applicable tests last week, so now the car is officially legal, including lowering, the wheels and the engine.
Now, the bad part, is that it is November now, and statistically, we should have a foot or two of snow, but thankfully the temperature is still above the freezing point, and the roads are dry, so I drive the car as much as I can.
Here are a couple of shots from when I drove it to work today, and the latest version of the engine:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #582 on:
November 01, 2010, 20:22:14 pm »
The to-do list for the winter is long, and includes the following
-detailling and fitting the deep-6 flat-4s at the rear
-replacing plastic VW fuel rails with alu ones
-mount VR trigger behind pulley
-mount dual throttle bodies on intakes, and decide whether I should mount them or not..
-clean up wiring and plumbing
-start building my next engine
Last Edit: November 01, 2010, 20:24:03 pm by Grelland
___________________
Roy
bathing ape
Re: Grelland's Ghia
Reply #583 on:
November 14, 2010, 14:34:34 pm »
been a while since i looked,the ghia has turned out really nice
Grelland
Re: Grelland's Ghia
Reply #584 on:
November 14, 2010, 19:01:20 pm »
thanks,
here's a short video from today, where one fellow VW fan wanted to hear what the csp exhaust sounds like:
http://www.youtube.com/v/Jayy8VQ6Jfc
Last Edit: November 19, 2010, 08:43:11 am by Grelland
___________________
Roy
BossHogg76
Re: Grelland's Ghia
Reply #585 on:
November 18, 2010, 16:45:41 pm »
It's taken me a couple of hours to read this thread and it is epic, truely an inspirational read.
Grelland
Re: Grelland's Ghia
Reply #586 on:
November 19, 2010, 08:45:14 am »
Thanks, truly inspiring to have such feedbacks
I have had some comments on the video I posted, with people wondering whether I have a diesel engine as I didn't rev it higher than about 4500 rpm, so if the roads are free from ice this weekend, I will try again, to see if I dare taking it further
___________________
Roy
Re: Grelland's Ghia
Reply #587 on:
March 07, 2011, 23:07:03 pm »
Roy, i'm going to detail my 17" Fuchs reps. for my T4 bus the way you did them. Did you already detail your centercaps ? Any pics ?
Harry
Grelland
Re: Grelland's Ghia
Reply #588 on:
March 08, 2011, 08:55:52 am »
sorry, haven't touched the center caps yet
___________________
Roy
19
20
