September 01, 2026, 20:30:46 pm
Grelland's Ghia
5
6
7
8
20
Topic: Grelland's Ghia (Read 369725 times)
Grelland
Re: Grelland's Ghia
Reply #150 on:
August 30, 2007, 18:36:21 pm »
You ever heard the saying measure twice, cut once... ?
I was trying to fit the quarter panel the other day, and no matter how I tried, the holes in the inner fender and the outer skin, for the rear torsion bar, simply would not line up...
So I did this:
Last Edit: August 30, 2007, 18:39:34 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #151 on:
August 30, 2007, 18:36:59 pm »
and then this:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #152 on:
August 30, 2007, 18:39:17 pm »
NOW the holes line up, and I will also probably be able to pull the torsion tubes out through the hole
I also trimmed the wheel arch and quarter panel, and treated the inside with some anti-rust stuff before it is time to finish up this fender all togehther:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #153 on:
September 04, 2007, 22:52:08 pm »
After seeing all the bugs at SCC last weekend, I thought I better hurry up in order to at least double the amount of Ghias next year, so I got out of my coach tonight and got the quarter panel mounted.
See, shubee2, I told you I would have that done tonight ;-)
Last Edit: September 27, 2007, 23:13:09 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #154 on:
September 04, 2007, 22:53:59 pm »
This turned out to be a real PITA, as the shape of the foremost part did in no way fit the shape of the door, so I had to cut some wedges and make it fit...
Just remains to mount the wheel arch now, and this corner is about done :-)
Last Edit: September 04, 2007, 22:59:41 pm by Grelland
___________________
Roy
Re: Grelland's Ghia
Reply #155 on:
September 05, 2007, 04:50:32 am »
Quote from: Grelland on September 04, 2007, 22:52:08 pm
After seeing all the bugs at SCC last weekend, I thought I better hurry up in order to at least double tyhe amount of Ghias next year, so I got out of my coach tonight and got the quarter panel mountet.
LOL Good Job Roy Way to Go!! Get-R-Done
Grelland
Re: Grelland's Ghia
Reply #156 on:
September 12, 2007, 23:16:25 pm »
And now the wheelarch is mounted:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #157 on:
September 12, 2007, 23:18:09 pm »
But I was somewhat over-eager on the MIG, and the entire fender ended up with a large dent after I heard a loud popping noise...
Ah-well one of my best friends is a panel-beater, so I guess I have to invite him over one evening...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #158 on:
September 12, 2007, 23:21:18 pm »
Ok on to somehing nicer.
I was browsing through my pictures the other nigth, and it seems that my wife not only took care of the hot-dogs stand at the local show I set up a few weeks ago; she also snuck around with my camera, and here's a couple of the images she produced:
Last Edit: September 27, 2007, 23:13:54 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #159 on:
September 27, 2007, 23:01:25 pm »
progress is slow, but not completely stopped...
So I have finished welding up the rear fender, and that is a milestone!
Then I started to prepare for doing the final mounting of the front fender, and the first thing I noticed was that the shape of the lower part of the fender that meet the heater channel, pointed inwards compared to the heater channel, so I cut of the lower part of the fender again, and on the second pic you can see what I mean:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #160 on:
September 27, 2007, 23:04:01 pm »
Part of the problem is that the curvature of the repro fender part does not match the curvature of the repro heater channel. I dont know which is correct...
But in order to remedy that, I made some cuts to the lip in the wheel opening, and made this part fit the curvature of the heater channel:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #161 on:
September 27, 2007, 23:04:46 pm »
Then I made a couple of brackets to mount the splash guards to:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #162 on:
September 27, 2007, 23:06:42 pm »
And once the fit of the lower part of the fender was getting ok, I realized that the gap to the front side of the door was not right, so I made some cuts there also, in order to rectify that.
You just got to love repro parts (they weren't even cheap...)
Here you can also see that sandblasting the door revealed some more work...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #163 on:
September 27, 2007, 23:08:38 pm »
Then I made sure the gap at the rear end of the door was good, by making a cut along the gap, and welding in a wedge. It turned out ok:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #164 on:
September 27, 2007, 23:12:22 pm »
I am planning on using body solder to straighten out the imperfections after all the welding and cutting, and I am afraid I have to prepare for a significant weight gain to the poor Ghia before it is done.
I just have to compensate for that by building an even bigger engine, so I have started collecting parts for a 2276 to replace the 1835 EFI engine that I am working on at the moment.
So this car will keep me warm and busy through this winter too, I guess...
Stay tuned
Last Edit: September 27, 2007, 23:15:45 pm by Grelland
___________________
Roy
Re: Grelland's Ghia
Reply #165 on:
September 28, 2007, 00:09:21 am »
Looking Good Roy How Many Hours in it now??
Grelland
Re: Grelland's Ghia
Reply #166 on:
September 29, 2007, 22:09:45 pm »
I have no idea how many hours I have put into this car, and I am not that interested in that either, as I do this for two purposes: Build a car to have fun in, and have fun while building it :-)
Today I actually managed to put in a few hours during the day, and I started by mounting, priming and applying seam sealer to the mounting brackets for the splash guards:
Last Edit: October 01, 2007, 22:17:26 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #167 on:
September 29, 2007, 22:12:19 pm »
Then I fixed the gap towards the door. I still need some adjustment before I weld this up
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #168 on:
September 29, 2007, 22:14:08 pm »
Then I made sure the lower part of the front fender lined up with the heater channel, and then mounted the rest of the fender, and here you can see that I welded this part on wrong the first time, as I need to add some 10mm more steel here:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #169 on:
September 29, 2007, 22:14:41 pm »
and then the alignment is vastly improved
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #170 on:
September 29, 2007, 22:16:45 pm »
In between I aslo made myself some clips to hold the panels as I do butt-welding. I have seen these for sale, but it took me about 15 min to make these out of various stuff I had lying aroung.
I need these for when I am to weld the front febder back on, as I dont have wise-grips that are long enough...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #171 on:
October 01, 2007, 22:08:28 pm »
ok so I worked a few hours this weekend, but I had to stop last night and head for the ER after testing the sharpness of the angle grinder blade...
Last Edit: October 01, 2007, 22:12:54 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #172 on:
October 01, 2007, 22:14:04 pm »
But before that little incident, I managet to cut out the dash in order to prepare for mounting my period correct one. Lots of air...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #173 on:
October 01, 2007, 22:15:32 pm »
An added bonus is that the access to the back side of the inner fenders is improved, so that I can clean up this area and grind the welds that were done from the outside.
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #174 on:
October 01, 2007, 22:16:32 pm »
and here you can see how I used my new clips for the final trial mounting of the front fender. It is all coming together now :-)
___________________
Roy
Re: Grelland's Ghia
Reply #175 on:
October 02, 2007, 13:29:58 pm »
I've got a set of those clamps - absolutely superb things! I love 'em!
Grelland
Re: Grelland's Ghia
Reply #176 on:
October 23, 2007, 18:35:33 pm »
Progress is slow these days, work is taking too much time
But after my finger grew back together I managed to get a few things done.
First some cleaning up of welds behind the dash:
Last Edit: October 23, 2007, 18:38:17 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #177 on:
October 23, 2007, 18:39:47 pm »
Good to know that this area that will NEVER be visible again is looking good....
Then I cleaned up the area around where the dogleg meets the firewall:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #178 on:
October 23, 2007, 18:41:16 pm »
Then I cleaned up some old welds in the rear inner fender, and also trial mounted the shelf next to the rear seat, to verify the fit:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #179 on:
October 23, 2007, 18:43:08 pm »
I also removed all the cross-bars internally in the car, since the heater channels are now securely fastened, and the car is supposed to have gained its old rigidity back:
___________________
Roy
5
6
7
8
20
