July 01, 2026, 17:42:20 pm
bigsiembowski
Grelland's Ghia
6
7
8
9
20
Topic: Grelland's Ghia (Read 344743 times)
Grelland
Re: Grelland's Ghia
Reply #180 on:
October 23, 2007, 18:44:34 pm »
Then I spent some time cleaning up a pair if IRS arms that have been narrowed about an inch in order to make my EMPI 8-spokes fit inside the fenders:
Last Edit: October 23, 2007, 18:49:23 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #181 on:
October 23, 2007, 18:46:44 pm »
And then finally, last week, I spent one evening helping en old friend picking up an EXTREMELY nice '60 T1. The original rear lights came with the car. The funny thing is that this car was located about 5 minuted from my house... I am glad my friend bought it, since I would have had to buy it, and I would end up with another explaination problem towards the Wife... ;-)
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #182 on:
October 23, 2007, 18:47:58 pm »
And the last one for now, here's one of the reasons why progress has been slow lately, as I was ordered to finish this up before the snow comes:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #183 on:
October 23, 2007, 18:48:50 pm »
Later this week, I plan one taking a day off work to really have some progress on the car, and I cant wait :-)
Stay tuned for more updates.
___________________
Roy
yvre
Der Autobahn Scrapers
Re: Grelland's Ghia
Reply #184 on:
October 24, 2007, 23:04:38 pm »
Man, when do you sleep???
Grelland
Re: Grelland's Ghia
Reply #185 on:
October 24, 2007, 23:12:37 pm »
Now it is just over midningt, and I just returned from work, as I had to finish something up before taking tomorrow off.
So NOW I will sleep :-)
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #186 on:
October 25, 2007, 22:00:00 pm »
And apart from a handful of phonecalls, did I actually manage to take the day off, and spend the entire day in the garage :-)
I started out by welding in the wedge at the bottom of the front fender, and I also finished the arc against the door, so that the two now actually follow the same curve...
Then I welded up the edge facing the wheel well, and the fender now has the same shape as the heater channel along the entire length of the car.
I actually had to cut another wedge along the opening towards the door, in order to make the opening even all the way down.
Last Edit: October 25, 2007, 22:11:29 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #187 on:
October 25, 2007, 22:02:49 pm »
Then I covered all areas to be welded with a welding primer, and added body sealer wherever possible to ensure no rust in the future, and then I finally mounted the fender for the last time, and started welding it in place. I went wery easy with the welder, in order to avoid the metal to warp. I also used a hammer and dolly to get all gaps perfect prior to welding
Last Edit: October 25, 2007, 22:07:22 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #188 on:
October 25, 2007, 22:03:35 pm »
The area around the nostril was also fixed up, and here I have to make a small piece in order to fill in the void:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #189 on:
October 25, 2007, 22:06:00 pm »
Now the fender is in its final location, but there is still some work to do before the thing is finished.
I also mounted the bumper again to make sure all still fits.
I have lost count of how many times I have taken the doors, bumpers etc on and off this car...
But now it at least starts to resemble a car again...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #190 on:
October 25, 2007, 22:10:54 pm »
I had to break for lunch, and then I took a trip to a local hardware-store that has a wide selection of hard-to-find parts. this is a place where grey-haired men in gray frocks work behind a counter, and when you ask for a hard-to-find part, they say "hmmm, let me see", then they disappear into the back room, and after a while they come back, "is this what you are looking for?". This time they came back with some clips for mounting the splash panels and locking nuts for my Spyder Mag wheels. I love that place...
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #191 on:
November 02, 2007, 08:09:23 am »
A short update from the cold north...
I have managed to finish up the welding on the front fender:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #192 on:
November 02, 2007, 08:11:16 am »
And I aslo laid down a layer of 2k epoxy primer behind the dash and in the luggage compartment. Now the welds arfe more or less invisible :-)
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #193 on:
November 05, 2007, 00:42:45 am »
Sunday night is garage nigth, so I started on the other front fender, and first I had to make something to attach the fender to.
The lower half of this part was gone, so I had to make it from scratch
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #194 on:
November 05, 2007, 00:43:51 am »
Looks ugly for the moment, the black messy stuff is a welding Primer I use to ensure no rust in the future, so I will clean the area up before I apply some 2k epoxy primer
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #195 on:
November 05, 2007, 00:45:22 am »
Then I welded on the lower part of the fender, and the rearmost lip folds around the part I just made, so I mounted the door and fender tree times to ensure a good fit
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #196 on:
November 05, 2007, 00:46:48 am »
next on the agenda now is to weld on the front part of the fender, and fix a section of the wheel opening, where one of the PO's have made some repairs...
It is coming together now :-)
Last Edit: November 05, 2007, 00:52:36 am by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #197 on:
November 08, 2007, 22:46:49 pm »
and after a night of sandblasting and cleaning up the area, the a-pillar now looks like this:
___________________
Roy
Re: Grelland's Ghia
Reply #198 on:
November 08, 2007, 22:48:23 pm »
great job ray
Grelland
Re: Grelland's Ghia
Reply #199 on:
November 08, 2007, 22:52:10 pm »
And then I started on the front fender. I started out by taking a lot of measurements, as I would like this side to be equal to the other side (...), so I measured a lot, then started by tack-welding the front part of the fender on. This is an NOS part, so at least the shape of this should be right.
I can't stand a Ghia where the bumpers are not straight and parallel to the ground, so I also mounted this in order to ensure that all is well.
All the measurements on positioning the headlights, nostrils and bumper are now within 1-2mm, so I feel I can move on and mount this fender permanently now.
It starts looking like a car now, doesn't it?
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #200 on:
November 08, 2007, 22:53:33 pm »
Quote from: speedwell on November 08, 2007, 22:48:23 pm
great job ray
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #201 on:
November 16, 2007, 17:51:48 pm »
Things are slowly going in the right direction.
I have trial mounted some of the instruments and stuff thant goes on the dash, and I still have to figurte out how to mount the 356 tach
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #202 on:
November 16, 2007, 17:54:09 pm »
Then earlier this week I started working on the left front fender, and as was the case on the other side, do I have a gap between the fresh metal in the NOS front section of the fender, and fresh metal in the fender itself, so I started out by making small tabs in order to locate the parts correctly, then I filled in the gap with pathes:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #203 on:
November 16, 2007, 17:55:20 pm »
And after another evening in the cold garage (it is getting time to turn on the heated floors, as the temperature is below the freezing point here now..) The fender looks like this:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #204 on:
November 16, 2007, 17:57:49 pm »
I am trying to make sure the ridge on top of the fender follows the original look, as I have seen quite a few Ghias where this ridge disappears long before it reaches the headlight.
Here you can see that you can at least see the ridge, now I just have to make sure it is straight, so a little work with the hammer and dolly, and this will be fine
___________________
Roy
Re: Grelland's Ghia
Reply #205 on:
November 16, 2007, 18:07:01 pm »
I cant imagine tackling a job of this magnitute. You are doing a great job, keep it up!
Re: Grelland's Ghia
Reply #206 on:
November 16, 2007, 21:47:06 pm »
Quote from: Zach Gomulka on November 16, 2007, 18:07:01 pm
No kidding. I've cut up better cars.
Grelland
Re: Grelland's Ghia
Reply #207 on:
November 23, 2007, 22:52:12 pm »
Thanks for the feedback, guys :-)
I have been quite eager to test out the art of applying body solder, so I started out with the easy part; namely a horisontal area on top of the right front fender:
Last Edit: November 23, 2007, 22:53:56 pm by Grelland
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #208 on:
November 23, 2007, 22:56:37 pm »
The last picture shows a surprice I discovered when I tried to melt some of the solder that was already there.
So now I needed one of these, to even this out:
___________________
Roy
Grelland
Re: Grelland's Ghia
Reply #209 on:
November 23, 2007, 23:00:09 pm »
And after a trip around town, I found one of these body files in a well-assorted HW store, so I could move on.
I started out with cutting out the rusted area, welded in a patch, and added more solder to that area.
Then I started the tedious work of filing down the solder, and here's a few shots of the result of a couple of hours work:
___________________
Roy
6
7
8
9
20
