September 23, 2026, 20:14:12 pm
Wanted
4 lug type3 rear hubs - I need a pair please :)
Topic: 4 lug type3 rear hubs - I need a pair please :) (Read 21008 times)
April 11, 2009, 23:43:01 pm »
Hey Guys as the title says I am looking for a PAIR of 4 lug rear hub flanges for late 4 lug type3 rear drums - Does anyone know where I can find some
Dave Rosique
nobodyouno
Re: 4 lug type3 rear hubs - I need a pair please :)
April 12, 2009, 02:21:39 am »
PM sent.
~DR.
April 12, 2009, 02:35:01 am »
Pm Sent
April 13, 2009, 20:07:03 pm »
i can get some if you want...
April 13, 2009, 20:53:18 pm »
Quote from: nicolas on April 13, 2009, 20:07:03 pm
Thanks dude - but dave has already sorted me a pair - and hes getting them redrilled and studed for me
April 14, 2009, 20:02:14 pm »
Quote from: monkiboy on April 13, 2009, 20:53:18 pm
no problem. if you ever need some. you can call me.
April 14, 2009, 21:58:47 pm »
Quote from: nicolas on April 14, 2009, 20:02:14 pm
Thanks Honey
PIMPPRIDE
April 15, 2009, 00:10:01 am »
does anyone of my fellow lounge / Type 3 drum brake users have interest in some nice chromoly race strength rear hubs???
I'm thinking of making some, as the stock German ones on my Type 3 are starting to go... I have a little bit of play on the axle splines and its only a matter of time until they completely spin...
the ones I am thinking of making would be chromoly, extra thick, available in 4x130 & 5x130 for use with 14mm stock lugs with a 2nd set of holes left unthreaded, with the backside spot faced ready for press in studs, available in long or short axle for around $150 a pair
to get tooling & costs down I would have to make 20 sets to make it a reality, these also would have a slight diameter undercut on the overall circumference of the hub for those that want to make their own rear disc brake kits using a 914 rear rotor and fab up a caliper mount...
Anthony / ISP WEST
April 15, 2009, 00:25:53 am »
Quote from: PIMPPRIDE on April 15, 2009, 00:10:01 am
Anthony / ISP WEST
Hmmm interesting idea dude - I might take a pair
Dave Rosique
nobodyouno
April 15, 2009, 04:39:31 am »
Anthony / ISP WEST
Interesting idea Anthony.
Original, forged genuine VW hubs in good shape are starting to dry up a bit, and I really don't care for the cast hubs.
Anyway, by the time you take a good used set of hubs, have them drilled, studded and cut the nose to fit a short axle you have at least $150 or more in them. I think there is probably a market, but as you very well know the rear disc brake kits are so inexpensive these days it's mostly us oldschool guys that seek out the type III rears.
Whatever you do, keep us posted...
While your at it, how about a GOOD quality aftermarket wide five type III rear drum
Dave
PIMPPRIDE
April 15, 2009, 20:44:30 pm »
yes, we are also working on a new wide 5 rear drum, high quality, strong and with a little extra trick i'm not going to let out of the bag just yet
Anthony / ISP WEST
April 15, 2009, 22:12:27 pm »
Just a quick question guys - when you redrill/restud 4 lug drums for Porsche 5x130 Can you still use the original "4 lug" holes - I mean if you fancy a change of Rims
You see I'm thinkin 6"+7" fuchs to begin with then after a year or so 14/15" Empi 8's
PIMPPRIDE
April 15, 2009, 22:35:30 pm »
on the stock hubs, when drilling to Porsche 5 x 130 it uses one of the 4 x 130 holes, but the way they are made is with screw in studs so technically yes you could go back and use the 4 x 130 lug pattern
if you go the press in route, its allot more work for a little bit more strength as the hubs then get spot faced on the backside before the stud can be pressed in, making a thinner area for each stud and losing the 4 lug pattern use all together...
this is where the hubs I want to make will come in allot better & stronger
Anthony / ISP WEST
Gunter
April 16, 2009, 06:57:24 am »
Dave
[/quote]
CSP has them
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=detail&artnr=20879
this is the type III and 34 rear drum 64-65
ask Type III Detectives on quality as he uses a lot of them
oh and they are NO Brasil but Good European ones
Gunter
Dave Rosique
nobodyouno
April 16, 2009, 23:17:00 pm »
Thanks Gunter,
That's good to know...
~DR.
PIMPPRIDE
April 16, 2009, 23:32:19 pm »
yes those 5 lug denmark drums are available here in
" the states "
also... for about $80 each
Anthony / ISP WEST
April 17, 2009, 01:11:09 am »
Thankyou Dave and FAT Performance, I Should be able to post this pic in the "What did you get in the mail today" thread soon
Critter1
April 25, 2009, 22:55:54 pm »
Anthony / ISP WEST
Put me down for a set Anthony. You know I'm good for it.
Here is the alternative I guess
http://www.cbperformance.com/catalog.asp?ProductID=1172
Pricey though...
Justin / Sacramento
PIMPPRIDE
July 13, 2009, 19:37:10 pm »
Anthony / ISP WEST
here are a few update photos of the progress on the type 3 rear hubs, they are now out for broaching, then final anodizing...
these are race strength... in lug patterns 5x130 and 4x130 short & long axle
Anthony / ISP WEST
Last Edit: July 13, 2009, 19:39:40 pm by PIMPPRIDE
PIMPPRIDE
August 25, 2009, 23:53:59 pm »
ok hubs are done... long and short axle... porsche 5x130 & vw 4x130 patterns... 4130 chromoly heat treated,black oxide coated ect... nothing but the good stuff... $250 gets you a pair
( cost more then I expected but if you ever machined chromoly then you know its expensive and takes twice as long then aluminum )
wholesale inquires welcome
Anthony / ISP WEST
PIMPPRIDE
August 26, 2009, 00:09:30 am »
ohh yea... an these will take a 9/16 press in studs... swayaway...willwood... arp... ect...
Anthony / ISP WEST
PIMPPRIDE
February 18, 2012, 01:09:28 am »
thread update :
as per request of some customers / racers w/different non vw / porsche wheel lug patterns, we made a limited amount of blanks short & long on our 2nd run of these hubs... again use these with type 3 rear drums or 944 vented rotors to makeup some nice rear disc brakes
Anthony / ISP WEST
