October 07, 2026, 04:21:06 am
Chakalives
Cal Look Engine Combos and HP
Topic: Cal Look Engine Combos and HP (Read 91237 times)
Steve DKK
Re: Cal Look Engine Combos and HP
Reply #60 on:
June 11, 2009, 23:45:36 pm »
Fred,
I love the ICTs with single ports. The run so much better than on a dual port motor.
The ICTs and the Kadrons have a similar problem as the mixture screw is located on one side of the carb thus favoring one cylinder per head on a dual port motor during idle and the transiitiion out of idle.
Bad design...
Go fast, don't turn
rebel
Reply #61 on:
June 16, 2009, 14:04:42 pm »
Another sub-2 liter:
1914cc
Crank: 69mm German 8 dowelled
P/B: Mahle 94mm A + truarc clips
Rods: Scat I-beam
Heads: VW040 mod. 40x37
Cam: Scat C35 + VW 1.1:1 rockers on solid shafts
Carbs: dual DRLA40s venturi 36(custom)
Sump: CB wide sump 1.7 Qt + full flow thru Fram HP-1 + bugpack breather(modified)
Ignition: Mallory with points + blue coil + taylor leads
Exhaust: 1 5/8 merged + Mondo
Clutch: Kennedy stage 1 + stock plate
Gearbox: AM (Still stock)
I wonder how it's gonna go now with theese 36 vents. I had 28s before and it was very,very flexible - pulled well from the bottom to 6000RPM quite well.
Things will be more specific after our club(SSVWF) Dyno Day in September.
Hot VWs RULE!
my site:
http://cal-look.pl
my club:
http://cal-look.pl/ssvwf.htm
my blog:
http://www.california-look.blog.pl
my car:
http://cal-look.no/lounge/index.php/topic,6104.0.html
Reply #62 on:
June 16, 2009, 14:32:58 pm »
Quote from: Steve DKK on June 11, 2009, 23:45:36 pm
Fred,
Bad design...
Sorry, Steve... just now saw your reply. The ICT makes perfect sense for a single port engine, in my opinion. They're a great way for me to deal with a temporary engine while I wait to build the 1.9 liter. So far, so good. I couldn't imagine having those carbs on a dual port setup... but maybe they work.
glenn
Reply #63 on:
June 16, 2009, 15:06:49 pm »
CC and HP 2180cc (92x82) around 180hp
Crank Chromoly 82mm with Buick journals
Rods Eagle 5.4 H beams, ARP bolts
P/B AA Thick Wall 92s
Cam Engle FK-8
Heads Steve Tims Stage 2 42x37.5 dual springs 56cc
Rockers Scat 1.4 chromolly push rods Wizemann lifters w/ SLR treatment
C/R 9.31:1 running 93 octane
Ignition Bosch 010, 01016 (Porsche 911) points, Bosch 7mm copper silicone wires, Bosch (German) Blue coil
Carbs Italian 48 IDA's rebuilt by Art Thraen
Exhaust Gene Berg 1-5/8" ceramic coated with a Berg dual QP mufflers
Flywheel Chromoly 12.5 lb 8 dowel
Clutch Kennedy stage 1, ACE Copperhead
Oil pump Shadek 26mm Berg pump cover
Sump Berg 1-1/2, Canton Mecca remote oil filter
Pulleys Berg 3.5lb
Cooling Type 181 shroud, all factory tin, Berg welded fan, Type 181 lower heat shields.
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
fish
Reply #64 on:
June 16, 2009, 16:20:03 pm »
man, thats a sweet combo, always loved the 181 shroud idea.
Reply #65 on:
June 16, 2009, 16:32:54 pm »
Quote from: 67-indeed/DVK on April 20, 2009, 15:39:56 pm
you're joking, how you never built a fast non-turbo type 1 engine?
how come there's only a few sub-2 litre engine posted in this thread?
are the owners a bit shy about their HP numbers? i liked to see a few more just for the sake of comparison...
Why would you build anything else than a turbo engine LOL
http://www.youtube.com/v/dNtTvd5Qrcw
Unless it was something like this at 2919
crap lost the picture of my big ARP MOTOR
http://selvedgeyard.com/
Reply #66 on:
June 17, 2009, 00:50:28 am »
Glenn, I never get tired of seeing your car and/or engine. Well done and it must drive just beautifully.
glenn
Reply #67 on:
June 17, 2009, 01:06:22 am »
Quote from: DKK_Fred on June 17, 2009, 00:50:28 am
Thanks... it's real nice around town and will press you in the seat when you put your foot into it.
And with the Berg 5 it cruises all day at 80mph.
Glenn
74 Beetle Specs
2180cc Engine
www.DasVolks.com
Reply #68 on:
June 17, 2009, 04:36:04 am »
...Gotta love the Berg 5! I know I do...
fish
Reply #69 on:
June 19, 2009, 07:29:42 am »
Quote from: Fiatdude on June 16, 2009, 16:32:54 pm
Mate, each to their own I personally like both NA + forced T1 but I love a turbo T4, look, in the end as long as its Aircooled VW I dont care.
You would love what a mate of mine has done with his little Fiat, Abarth heads, To#¤ta S/Charger, Twin Mikuni TBs, EFI, etc etc. crazy.
Reply #70 on:
June 19, 2009, 16:31:37 pm »
Did someone say BIG type 4?
Last Edit: June 19, 2009, 16:47:08 pm by Fiatdude
Reply #71 on:
June 19, 2009, 16:33:50 pm »
Did someone say 2919?
Wait that was me LOL
Last Edit: June 19, 2009, 16:42:15 pm by Fiatdude
Brian Silva
Reply #72 on:
April 03, 2014, 07:15:32 am »
Figure I would revive the post as more engines have come along since then.
CC and HP 2332cc 181hp at the wheels on dyno jet with work left to do at 6800 rpm. Next pull will be 7850 with a few changes on pump gas. Should be in the 190 range with belt and 200 without.
Crank DMS 84mm Porsche journal
Rods Porsche LRE rods 5.34
P/B Mahle 94's
Cam Webcam 86C
Heads Old school autocraft stage 3 heads welded 42x37.5
Rockers Scat 1.4 rockers
C/R 10.5:1 pump gas 92
Ignition Joe Hunt Mag 26 deg advance
Exhaust A-1 1 3/4 sidewinder
Sump Berg 3 1/2 qt sump
Pulleys Jaycee 7 in street pulley
Cooling Type 4 cooler with doghouse
Mated to a berg 5 speed..
peejke
Keep it simple...
Reply #73 on:
April 03, 2014, 13:57:47 pm »
Not as impressive as many here, but runs like hell on the Belgium streets
1776
Gene Berg counterweight 8 doweled crank
balanced lightened flywheel , 8 doweled
GB 297 Cam
CB 044 CNC round ported heads 40x35.5 , dual springs
2x Weber 40 IDF with very old berg linkage (want to upgrade to 45dell)
autocraft rockers (needle bearings)
009 distributor with compufire ignition
santana pulley
denso irridium plugs
KEP stage 1 clutch
CSP phyton exhaust
fram HP1 filter
Rancho pro street trans
no idea about the hp facts , still not dyno'd
Last Edit: April 03, 2014, 14:10:18 pm by peejke
way to much old shit at home, ...
'57 single cab, 1776 powered
'71 baywindow westy , 1835 powered
'54 oval ragtop , texas brown , stock as hell
flandria sport moped collection, other old mopeds, BSA A65 cafe racer, yamaha SR500 dirt tracker
chez2165
Reply #74 on:
April 03, 2014, 20:21:39 pm »
CC and HP 2165cc 185hp on the dyno
Crank Bugpack 78mm Vw journal
Rods CB H beams 5.5"
P/B Mahle 94's
Cam Engle FK 89
Heads CB 044 fully ported with 42x37.5 valves
C/R 9:1 on pump gas
Ignition Berg Stinger ignition
Carbs Italian 48 IDA's with 3rd progression hole mod
Exhaust Berg 1 5/8 header with A1 muffler
Clutch Kennedy stage 2, Berg disc
Oil pump Berg 26mm Berg pump cover
Pulleys Berg achiever pulley
Cooling Type 1 cooling with doghouse and external fan assisted cooler.
Reply #75 on:
April 04, 2014, 04:16:12 am »
84x94 Street Turbo
84MM CRANK WITH CHEVY ROD JOURNALS
TOTAL SEAL RINGS
5.7 INCH H-BEAM RODS
044 THICK FLANGE COMPLETE CYLINDER HEAD - 42MM X 37MM BORED 94MM
Webcam custom 1.4 cam and lifters ordered .455 Lift @ 1.1, 242 degrees@.050 ad 280 degrees, 114 degrees Lobe Centers.
Case: Type 1 mag Brazil case originally from GBE bought in 1992 and used until 2007 as 1776.
Full port and polish on 044 heads with matched cc'd chambers.
Chambers opened up for 8.5:1 compression.
Intake ports enlarged, with stock port size at manifold for stock style turbo intake manifolds.
High squish wedge port design with flame port.
Pistons dished .050" in bathtub shape to match combustion chamber.
Custom cromo 11mm cylinder spacers with fins machined matched <.001" to each other.
10mm cheapo crmo head studs.
Cylinder head fins drilled around perimeter for extra cooling.
Exhaust manifold port area drilled for cooling.
AJ Sims turbo adapted to blow thru EFI with Electromotive ECU ignition and fuel.
AJ Sims small turbo kit header 1-3/8" with stock heater boxes and no muffler.
Throttle body from late VW Bus welded to Turbo.
Full cooling system with thermostat and flaps and decklid that closes and locks.
Berg full flow kit with sump.
Berg 26mm oil pump.
009 distributor converted to crank position sensor for sequential EFI.
NGK D9 plugs.
Chassis dyno'd when first built in 2011 at Berlin Klassic in Kitchener, ON Canada (formerly Berlin) with rpm limited to 5500 (break-in)and boost limited to 3psi.
194hp 240tq.
Going into its fourth season as a daily driver (when there's no winter salt on the roads) and going strong!
Next mod: More boost and possibly Porsche oil to water cooler with small rad
Brian Silva
Reply #76 on:
April 04, 2014, 04:43:55 am »
Nice combo guys! Let's keep them coming. Always intriguing and eye opening to hear about and see certain combos work.
Brian Rogers
Reply #77 on:
April 04, 2014, 22:54:33 pm »
The more I see and hear of the type IV the more I'm intreged by them. Now I could just find a 2.0 ltr that would be great.
neil68
Reply #78 on:
April 04, 2014, 23:08:19 pm »
CC and HP: 2332 cc 180+HP on the chassis dyno; 200+ at flywheel
Crankshaft: CB 84 mm Buick journal
Rods: CB H beams 5.5"
P/B: Mahle 94's
Camshaft: JPM Raptor #06908, 274 degrees @ 1.27 mm/0.050", 10.8 mm/0.425" lift, JPM lifters
Heads: JPM MS230 with 48x37.5 valves (flycut/guides by K-Roc), CB VW650 springs
Rockers: Scat 1.4 rockers
C/R: 10:1 on 94/98 octane pump gas
Ignition: MSD 6AL, distributor, coil and leads
Carbs: Italian Weber 48 IDA's, 3rd progression hole, enlarged float bowls, JPM Raptor 44 mm venturies
Exhaust: Bugpack 1.75" header with A1 Magnaflow muffler
Flywheel: EMPI Chromoly 12.5 lb, 8 dowel, Bugpack gland nut at 405 ft lb
Clutch: Kennedy stage 2, Berg dual friction disc
Oil pump: Berg 26mm O-ring, Berg pump cover
Sump: Berg 3 1/2 quart
Pulley: Vintage Santana
Cooling: Type 1 FI doghouse and OEM German tin & shroud
ET: 12.6 seconds at 106+ MPH/170 KMH (2,025 lb/920 kg with driver)
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
Jeff68
Reply #79 on:
April 07, 2014, 13:34:18 pm »
Neil - Did you have additional port work done to your MS 230 Heads? Big intake valves too 48mm? I know you've been having great results with your combination so I was curious.
Thanks!
neil68
Reply #80 on:
April 08, 2014, 01:24:49 am »
No port work done. Flycut for compression and exhaust guides trimmed, as they were chipping a bit...probably due to the previous Web 226 cam, which I've since learned is not a good cam.
Neil
Dynojet Test:
Reply #81 on:
April 08, 2014, 03:48:51 am »
Neil, what trans are you running? I can't turn up the boost or dump the clutch on my motor until I upgrade the trans from stock.
Reply #82 on:
April 08, 2014, 03:50:58 am »
Fred,
Bad design...
We tested out a larger diameter crossover tube and it cured that problem with the Kads! Steve said it was the only engine with Kads that idled on all cylinders
The crossover pipe he used was off a 72 bus which is the correct size for the job.
neil68
Reply #83 on:
April 08, 2014, 05:52:36 am »
Quote from: Martin S. on April 08, 2014, 03:48:51 am
Rancho Pro Comp with close 3rd/4th gears. I don't do a burnout, and I also keep the tire pressure up around 22 lb...this probably preserves the gearbox!
Neil
Dynojet Test:
Reply #84 on:
April 09, 2014, 20:06:36 pm »
For me the 90,5x82 are the best cal look engines :-) reliable and make power
www.Udobeckertuning.de
Richierich56
Reply #85 on:
August 01, 2016, 15:29:06 pm »
Nothing here
Last Edit: May 02, 2017, 02:03:02 am by Richierich56
Richierich56
Reply #86 on:
January 16, 2017, 21:12:01 pm »
Nothing here
Last Edit: May 02, 2017, 02:02:11 am by Richierich56
