October 12, 2026, 19:17:20 pm
| | |-+  Quick turbo question
Author Topic: Quick turbo question  (Read 6350 times)
airstuff
« on: April 16, 2009, 07:38:27 am »
Can this tubocharger be used on VW aircooled engines
It is a Garrett T3 0.63A/R trim 60
It can be water or oil cooled as I am told,I just need to block one of the options
« Reply #1 on: April 16, 2009, 09:28:50 am »
It has to have oil to it whatever else you do,you just leave the water ports blank,I see no reason why it cant be used Smiley I ran a turbonetics t04 for 3 years with a watercooled center section without connecting anything to it
JamieL
« Reply #2 on: April 16, 2009, 22:25:46 pm »
Ditto what Richie said - I ran an oil+water cooled Mitsubishi TE05-12B (originally fitted to a Saab 900 Turbo) with oil only and it was fine...
Just remember not to switch the motor off immediately after sustained hot / high load running - let it idle for a minute or so to allow the oil and turbo bearings to cool a bit...
airstuff
« Reply #3 on: April 17, 2009, 13:56:35 pm »
Is this turbo good for draw throug turbo system,or does it need any special bearings?
JamieL
« Reply #4 on: April 17, 2009, 19:23:58 pm »
Hi,
AFAIK it doesn't have a carbon seal, therefore no good for draw-thru, but happily corrected
 I didn't take the chance as I ran a hybrid scrap-yard-special mechanical fuel injection system using various VW + Saab K-jet bits...
