September 18, 2026, 21:11:01 pm
Bad Habit
I have a probem,what is a solution? :(
Topic: I have a probem,what is a solution? :( (Read 12018 times)
airstuff
April 16, 2009, 16:33:28 pm »
Today I received my CB equalizer pulley today,and tried how it goes on the crank.
it is a foged crankshaft,chinese forging like others 300 dollar cranks out there
Withouth the woodrof key on the crankshaft,I tried how it goes on,and it only slides on the crank.Now is this good or bad
It is supposed to be tight on the crank,and is supposed to be tapped on the crank right?
Please let me know what you guys think,and what is solution for curing this problem if there is any.I wouldn't want to change my crank again
Last Edit: April 16, 2009, 17:00:15 pm by cal-look
Re: I have a probem,what is a solution? :(
April 16, 2009, 17:18:35 pm »
that's a CB pulley? Wow... looks just like a Gen_ B_r_
the pulley must be a tight press on crank, or once running and warm, it will begin to wallow on nose of crank and take out ID of case.
sorry
airstuff
April 16, 2009, 17:25:47 pm »
so what should I do,buy another crank ???no solution to repair it
maybe add material to the pulley,and machine the id of the pulley down again?
April 16, 2009, 17:36:56 pm »
Could Loctite flange sealer be a solution?
SlingShot
April 16, 2009, 17:52:39 pm »
Quote from: JS on April 16, 2009, 17:36:56 pm
Yes. I'm thinking Loctite 620 will work for you. I would use a very small amount, and see how that works. If you use too much, you might have yourself a 1 piece unit
http://tds.loctite.com/tds5/docs/620-EN.PDF
Will Race For Beer !!!
April 16, 2009, 18:01:46 pm »
Quote from: cal-look on April 16, 2009, 16:33:28 pm
Can you post a picture of how far it goes onto the crank? so we have a better idea of how bad it is,i have to heat the real pulleys that they are a copy of to get them on properly,
Oh its the pulley not the crank that is the problem usually with those
April 16, 2009, 18:07:49 pm »
That is a copy of a Gene Berg pulley. The Berg pulleys are a very close tolerance fit to a stock VW crank. Did you try it on a stock crank to see how it fit. The pulley ID could be oversize or the crank could be slightly undersize. See how it fits on a stock VW crank.
airstuff
April 16, 2009, 18:25:04 pm »
Quote from: Donny B. on April 16, 2009, 18:07:49 pm
Yes I have tried to fit it to my old 69mm german crank,and it needs to be tapped to go on,doesen't want to go on easy
airstuff
April 16, 2009, 18:28:38 pm »
Guys here are some pictures
airstuff
April 16, 2009, 18:31:38 pm »
one more
April 16, 2009, 18:50:26 pm »
the nose of crank can be knurled by a machine shop
A bugpack 88 had to be knurled (by Berg's) at timing gear area back about 15 years.
airstuff
April 16, 2009, 18:55:25 pm »
Quote from: Jim Ratto on April 16, 2009, 18:50:26 pm
i had to look up a word "knurled" in a dictionary
but what is done in the "knurling" process?
April 16, 2009, 19:01:36 pm »
http://en.wikipedia.org/wiki/Knurling
April 16, 2009, 19:03:05 pm »
Quote from: Jim Ratto on April 16, 2009, 19:01:36 pm
"Knurling may also be used as a repair method: because a rolled-in knurled surface has raised-up areas surrounding the depressed areas, these raised areas can make up for wear on the part. In the days when labor was cheap and parts expensive, this repair method was feasible on pistons of internal combustion engines, where the skirt of a worn piston was expanded back to the nominal size using a knurling process. As auto parts have become less expensive, knurling has become less prevalent than it once was, and is specifically recommended against by performance engine builders."
airstuff
April 16, 2009, 19:10:21 pm »
Thanks Mr. Jim for the explanation
So,If I get it knurled,It would be possible to get the pulley off only few times,before the knurling shatters,gets thinner
airstuff
April 16, 2009, 19:45:19 pm »
will try loctite first
Last Edit: April 16, 2009, 22:10:15 pm by cal-look
Doktor
April 17, 2009, 10:08:22 am »
Ah those chinese cranks...
dr.aircooled
airstuff
April 17, 2009, 10:10:53 am »
I have another Idea
a friend of mine used to get his crankshaft hard chrom plated,when his rod bearings burned the crank
It is an industrial chroming method,for crankshafts,to repair the journals,so it might as well repair the pulley snout on the crank.
Last Edit: April 17, 2009, 10:15:36 am by cal-look
sparkieben
April 17, 2009, 11:29:30 am »
I have the same pulley and have used it for two years,mine slides on quite easy too.Ive had no problems and the engine has been completely stripped twice for upgrades,as long as you put a little thread lock on the bolt it should be fine,
just to note once slid on mine has no freeplay side to side cheers ben
airstuff
April 17, 2009, 12:22:41 pm »
Quote from: sparkieben on April 17, 2009, 11:29:30 am
no,I don't have any side play
good to know
thanks
April 17, 2009, 13:34:56 pm »
Zvonimir, use a really large and quality beleville washer under the bolt, I removed mine from an industrial engine.
airstuff
April 17, 2009, 13:45:33 pm »
Quote from: 181 on April 17, 2009, 13:34:56 pm
Thanks Jan,
Will get one from VW Parts or elswhere.
I see that the stock one looks kind'a small
Thanks for the info.
April 17, 2009, 14:09:28 pm »
VW used BIG washers in their industrial engines with dual pulleys (for second generator etc) to take an additional weight and loat of this dual pulley syystem I believe. It is like 60 mm dia.
April 17, 2009, 15:44:18 pm »
IMO, you don't have a problem.
I take sandpaper to all my pulleys so they slip on and off by hand without tools. Just make sure the bolt is tight.
Although, I don't use those heavy boat anchor pulleys.
April 17, 2009, 15:56:01 pm »
Cal look,
i had exactly the same problem:
bought a scat pulley and this was tight...
http://cal-look.no/lounge/index.php/topic,1374.30.html
at the time, i didnt want to take the risk..
cheers, Peter
April 17, 2009, 16:38:39 pm »
Quote from: Bruce on April 17, 2009, 15:44:18 pm
I do the same, but I wouldn´t do that on the boat anchor style pulleys because of the added weight and strain in the key....
airstuff
April 17, 2009, 17:09:12 pm »
Quote from: ruff on April 17, 2009, 15:56:01 pm
Cal look,
cheers, Peter
before this one I had a scat pulley,and it also went withouth tools on the crank.
I will find a way withouth spending too much money to fix this problem
Thanks guys,
