September 24, 2026, 04:33:55 am
Newbie saying Hi
Topic: Newbie saying Hi (Read 6947 times)
RUSS74GHIA
VWSP163
Newbie saying Hi
May 07, 2009, 11:16:00 am »
Hi guys & girls.
Just thought I'd say a quick hello and introduce myself. I'm Russ Weir from Kent in the UK
Here's my ride, a Cali-import '74 Ghia Coupe
2009 is my second season racing in the VWDRC in VW Sportsman class, last year was with a 1641 motor. So far so good this year, Qualified 1st at both meetings, won the first and came runner-up in the second
She's got a 1914cc motor built by RNJ Motorsport; Kennedy 1 cover, Pro-Grip disc, 12lb flywheel, full dynamic balance, match weighted rods, Engle W120 cam, hi-rev lifters, 1.25:1 rockers, 35.5x40 valves in reworked heads, hi-rev single springs, 8:1 CR, remote oli filter. Currently running a single 40DRLA with 32 vents, as my twin 40DRLAs are going through a rebuild. 1.25" merged header with twin quietpack/swivel stinger
The rear is IRS, stock height and features KYB gas shocks, type 2 bump-stops and 5mm wheel spacer. The front is balljoint/disc and features a 3" narrowed beam built by myself, and currently a 5" drop on adjusters (shock tower seams are 40mm from the ground) Empi short oil shocks, anti bump-steer bushes and 1 set of castor shims.
Wheels are early 4-stud 5x15 thin-lip Rivieras with 145/65 Bridgestones up front and 205/60 Federals out back
Best run is 16.16s @ 81.79, but that's with the single carb, hoping for a mid to low 15 when the twins are bolted on.
Last Edit: May 07, 2009, 14:00:15 pm by RUSS74GHIA
Re: Newbie saying Hi
May 07, 2009, 11:33:37 am »
cool! and welcome
looks like good fun there.
now sorry to highjack your first post allready, but how come everyone is running 16's, 15's and even 14's with a 1776 or 1914 and i am stuck with mid 17's in my fastback with a 1776. the combo doesn't look much different then the one mentioned above and a ghia can't be that much lighter.
oh, and don't mention me getting out the car half way down the track
jamiep_jamiep
May 07, 2009, 11:45:35 am »
Hi Russ, good to see you over here on the lounge!
Seeya soon buddy
Jamie
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
RUSS74GHIA
VWSP163
May 07, 2009, 11:54:14 am »
Quote from: nicolas on May 07, 2009, 11:33:37 am
cool! and welcome
Well, sorry to disappoint you, but a Ghia is heavier than both a Bug and a Fasty - she weighs in at 2090lb, and that's
before
I get in! Perhaps you simply need a visit to a dyno. Or it might be you're not launching/hooking up too well.
RUSS74GHIA
VWSP163
May 07, 2009, 11:55:28 am »
Quote from: kaferboy on May 07, 2009, 11:45:35 am
Seeya soon buddy
Jamie
#waves smilie#
May 07, 2009, 12:52:06 pm »
Welcome to the Lounge Russ!
May 07, 2009, 12:58:51 pm »
Quote from: RUSS74GHIA on May 07, 2009, 11:54:14 am
before
well i checked the manual and a fastback weighs 1100kg or something off 2400lbs. so i am fatter.
what hp does your car have. mine has 115hp on the dyno, but alas i can't remove the belt.
about the launching and hooking up that can indeed be a problem as i am still learning a lot. and hopefully improve
so what numbers (hp/ torque) are you running?
RUSS74GHIA
VWSP163
May 07, 2009, 13:43:54 pm »
Quote from: nicolas on May 07, 2009, 12:58:51 pm
Oops, I stand corrected on the weight then.
I've not had her dyno'd yet, but judging by the weight and times I would guess about 105bhp @ flywheel, no idea about torque. She's going to be dyno'd when the new carbs go on as I really want to make the best of them.
As for the launch, and I'm no expert, this is my drill. Rear tyres 14psi.
Handbrake on (button held down), 1st gear engaged, clutch up as much as the brake will hold, 5000RPM on the tacho, then let everything go when the lights drop. Best 60ft 2.08s
May 07, 2009, 13:54:04 pm »
cool! and welcome
why not? i wanted to talk about adjusting your accelerator cable and then doing a 105s pass
May 07, 2009, 14:20:07 pm »
welcome to the lounge Russ
May 07, 2009, 18:53:41 pm »
Quote from: lids_2001 on May 07, 2009, 13:54:04 pm
cool! and welcome
, because i have bought runningshoes now and can actually run to the back and fix it faster. that's a couple off 0.10's right there
Quote from: RUSS74GHIA on May 07, 2009, 13:43:54 pm
thanks for the help. i'll see what i can do.
May 07, 2009, 19:09:31 pm »
Hi Russ, nice car !
johnl
May 07, 2009, 19:13:35 pm »
Hi Russ and welcome to the MADNESS
I hope you have as much fun here as I do.
John
tikimadness
May 07, 2009, 19:57:20 pm »
cool! and welcome
Check your handbrake is of
Michael
GASSER GARAGE a few friends creating history.
NIDGAFWYT
