September 23, 2026, 19:11:45 pm
| | |-+  Brand new efi for typ 1
Author Topic: Brand new efi for typ 1  (Read 11643 times)
old skool 51
« on: May 21, 2009, 09:11:55 am »
eugene
« Reply #1 on: May 21, 2009, 09:54:40 am »
 Shocked nice! ere the TB and manifold one piece? price?
« Reply #2 on: May 21, 2009, 10:22:41 am »
i am so tempted by this, scrap those horrible IDA's and upgrade.
Now running for cover as I wait for the abuse.
jamiep_jamiep
« Reply #3 on: May 21, 2009, 11:14:41 am »
Awesome setup and having seen them in the flesh can confirm that these things are the dogs bollox...
GreenTom
« Reply #4 on: May 21, 2009, 11:18:43 am »
Cheesy
confirm... really grate stuff...
a pice of art Grin
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
« Reply #5 on: May 21, 2009, 15:23:58 pm »
Looks similar to what the Bergs did years ago.  Tom Hansen had a set on his Bug.  They also had air cleaners that fit on top of the velocity stacks.
Worm
Whose stupid idea was that?
« Reply #6 on: May 21, 2009, 17:03:11 pm »
The linkage looks a little wimpy..... That so?
 "Pretending to know everything closes the door on whats really there"
old skool 51
« Reply #7 on: May 21, 2009, 18:32:14 pm »
The Berg system had throttle machined into the top of an IDA manifold with injectors outboard, those in the pic are purpose made die  cast manifolds with throttle bodies bolted on. Linkage uses 5mm  stainless steel rods like most of the better german centre pull linkages and compared to say a Berg linkage it does look slightly more compact.
GreenTom
« Reply #8 on: May 21, 2009, 19:42:03 pm »
linkage is really nice and smooth. I've got one on my engine Wink works just grate Smiley easy adjustment enoug. movement etc...
the EFI system is a work of art. Manifolds are cast with injector boses and threded holes for nos noozles (one on each cilinder).
the throttle bodies are small and really compact CNC machined from billet aly. No gaskets just orings all way around.
Most of all they fit with cone air cleanres under the deck (2 sizes of billet aly velocity stacks for filters plus very light tacks that You can see on the pick).
the sstem in work conditions you could see on Santa Pod on 17th may in Johnys bug and also in Craig grey oval Smiley.
hope to see some more of those beauties on Youre engines.
cheers Tom.
Martin
Cash Converter....
« Reply #9 on: May 21, 2009, 20:29:08 pm »
I really like this setup,
Well Done Paul,
proper job!
Martin
www.taylormachine.co.uk
OFF/500
« Reply #10 on: May 21, 2009, 21:25:51 pm »
cheers Tom.
I will say I saw that system on craigs oval and it did look pretty awsome shame I didn't get to see it run with rain and all Roll Eyes
Whats the "programability" like Huh
GreenTom
« Reply #11 on: May 21, 2009, 21:36:32 pm »
if You know what You're doing its really grate.
When You're buying the engine with one of the kits You got the map made for that engine (on the dyno and in road use) so You don't have to mess around the ECU Smiley.
old skool 51
« Reply #12 on: May 21, 2009, 22:28:17 pm »
Jonny walklett,s bahn stormer...............
http://i250.photobucket.com/albums/gg274/Turbomanefi/jwnos-s.jpg
63ragtop
« Reply #13 on: May 21, 2009, 22:40:00 pm »
Quite the opposite, I have this set up on my car and the linkage is very precise. The throttle bodies also have very good return springs. So you don't have problems with the throttle not shutting off like carbs and some cross bar set ups.
rick m
« Reply #14 on: May 22, 2009, 03:14:24 am »
Who is making this set up and what does it cost?
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
« Reply #15 on: May 22, 2009, 04:11:37 am »
A few questions:
How much?
Is the kit currently available?
I realize that the system is electronic (at least that's what the thread title suggests), but what else is further entailed? Examples would include; brain/computer, injector replacement availability, wiring, etc.
Is there a mechanical injection available?
What type of fuel pump and pressure are required?
Most importantly... how does it drive? Is the idle to primary circuit smooth throughout the range up to full throttle?
« Last Edit: May 22, 2009, 13:18:20 pm by DKK_Fred » Logged
« Reply #16 on: May 22, 2009, 06:14:59 am »
Here is the original thread: http://www.volkszone.com/VZi/showthread.php?t=432275
"It's about £2300 inc vat for the full kit with a DTA S40 -includes pulley with crank trigger, coil,leads,harness,fuel pump,regulator,linkage,injectors,stainless fuel rails,airfilters,tps,air and engine temp sensors.
Includes a dyno session with engine either in the car or out of the car."
GreenTom
« Reply #17 on: May 22, 2009, 08:01:36 am »
You can run all fuel you wont, 95, Optimax, race fuel, E85 etc... Cheesy
no mechanical injection jus EFI. the only "mechanical" things in there are the throttle shafts Cheesy and linkage Smiley
as I remember the other (smaller throttle bodies) kit (the old one mainly for bus, typ25 and turbo aplications) was over 1500 pounds.
« Last Edit: May 22, 2009, 08:04:13 am by GreenTom » Logged
« Reply #18 on: May 22, 2009, 09:59:46 am »
WOW, I just wet my pants Smiley
I read a nice quote somewhere some time ago:
"EFI, when IDA's are not enough"  Grin Grin
this is my setup for now (rebuilding)
cheers, Peter Cry
pest
« Reply #19 on: May 22, 2009, 15:07:14 pm »
cheers Tom.
yep thats was my car Grin......i wanted to move over to efi a while back but i knew this system was on the cards so hung on till it was ready.
Its as good as it looks, fantastic quality all the way through........can't fault the system or the setup on the dyno....... Grin
it was worth the wait.
cheers
Craig
63ragtop
« Reply #20 on: May 22, 2009, 16:21:35 pm »
 Grin
