October 12, 2026, 11:15:35 am
One Piece window's
Topic: One Piece window's (Read 13910 times)
Black Sheep
less is more
One Piece window's
May 22, 2009, 08:11:11 am »
I know this topic has come up before but ... Im in the process of fitting 67 twin lifter's into the 49 .
My question is this , who make the best scraper seals ? Ive bought some all rubber split ones for mine a while back and altho they are a fine seal once you operate the window they bind and fold in
Where can I get some top quality scrapers with a felt backing to the glass ?
13.03 @ 98mph
Re: One Piece window's
May 22, 2009, 13:05:18 pm »
Can't you put some silicon spray onto the rubber?
Black Sheep
less is more
May 22, 2009, 16:40:02 pm »
Tried it , ended up with messy widow's
13.03 @ 98mph
May 22, 2009, 16:59:59 pm »
Quote from: 49-rag on May 22, 2009, 16:40:02 pm
Use Baby Powder on the seals they wont stick to the glass or flip when you roll them up or down you will have to pull the seal back from the glass to get it in there might take a few times to get it coated but it works great once done you will only need to do this once
Black Sheep
less is more
May 22, 2009, 17:50:35 pm »
Cheers Gary , will give it a go
13.03 @ 98mph
Adele AW
May 22, 2009, 21:57:46 pm »
We got ours from Heritage, a tip if it helps, not sure but i cut them down slightly as i found them too long, just about an inch off each side, much easier to clip in too
HTH
Adele
O/FF 621
Black Sheep
less is more
May 22, 2009, 23:04:27 pm »
Cheers Adele , how you doin , you take care of my homie now ya here
13.03 @ 98mph
Adele AW
May 22, 2009, 23:40:26 pm »
Quote from: 49-rag on May 22, 2009, 23:04:27 pm
No Probs! Im good thanks, we now have a horn, wiring, lights and everything!
Your Homie is doing good... bit hot after his curry but there settling down in the garage for the night
O/FF 621
Black Sheep
less is more
May 22, 2009, 23:51:48 pm »
Good to here Adele , see ya next weekend , Im gonna sit back and watch you go to work on the strip with that new ride of your's
13.03 @ 98mph
Adele AW
May 22, 2009, 23:53:47 pm »
Quote from: 49-rag on May 22, 2009, 23:51:48 pm
IF and a big IF Mr.Allman can fit it in after the photoshoot on Wednesday! and get it done in time.. If not we wont be able to race
Then it will be the peak performance day and Summer Nationals
O/FF 621
Black Sheep
less is more
May 22, 2009, 23:56:43 pm »
Ill keep a seat warm beside's me then
13.03 @ 98mph
