September 22, 2026, 21:22:13 pm
| | |-+  Drysump pumps
Author Topic: Drysump pumps  (Read 7227 times)
cassa
« on: May 27, 2009, 11:08:54 am »
Hi!
Does anybody know if any shops has the Autocraft 3 stage pump in stock? I have looked at the online shops that i know, and dont find anybody that has them on their site.  Need one FAST :-) for one fast vw....
Also interrested to know if anybody has experienced execive wear on the Pauter Gerotor pumps?
regards Carsten
Tobi/DFL
« Reply #1 on: May 27, 2009, 12:06:59 pm »
Hi cassa,
I think that CSP in germany should have the pumps in stock. But you could also send an email to my clubmate Helge who should have a nearly new Autocraft dry sump pump for sale: helge.ohmes@t-online.de
Bye,
Tobi
Martin
Cash Converter....
« Reply #2 on: May 27, 2009, 12:14:52 pm »
I use the Peterson gerator pump on mine, found it much better than the Autocraft unit. The scavange is better and the internal regulator is spot on.
as for the Pauter unit, Russ is running one and has not had any problems with it at all, his has done 2000 - 3000 miles on it.
Sorry i sold my old autocraft pump a long time ago.
hope this helps
 Martin
Martin
www.taylormachine.co.uk
OFF/500
cassa
« Reply #3 on: May 27, 2009, 14:19:49 pm »
Thanks for the replys.
Going backwards to a Autocraft is not ideal.
But the Pauter pump has worked itself sideways 0,5mm on the pressure stage. This is due to bad engineering. The engine this is for har earlier had problems with this pump, this has been solved by Pauter.
Is the Peterson pump a VW bolt on pump, or have you used a generic pump and made it fit?
reg
Martin
Cash Converter....
« Reply #4 on: May 27, 2009, 14:26:21 pm »
I got my peterson from Autocraft, aparently they make a VW adapter. funny its ended up on a Pauter block! lol
Martin
OFF/500
« Reply #5 on: May 27, 2009, 14:46:49 pm »
Since I really want to see this car on the road;
http://www.aircoolers.com/Ads_Single.asp?ID=8639
Roman
« Reply #6 on: May 27, 2009, 21:42:55 pm »
Ola is a good guy. BTW he is building a pro stocker that he hope will be ready to SCC.
cassa
« Reply #7 on: May 27, 2009, 22:25:13 pm »
Thanks Kalle!!
I have given the number to T.Ø . I think he has called Ola.  Im just the internet guy for him  :-)
Been working on my own car today..  installed waterpipes...    Grin
cassa
« Reply #8 on: May 28, 2009, 10:13:51 am »
It looks like the problems will be solved.
T. Ø. Skinne bought the pump from Ola.
He also is in the prossess of redesigning the pressure stage of the Pauter pump he has. The pumps wear down the housing due to too high internat pressure in the pressure stage. He will do a "50% fix" on the pump he has now, and when he gets the pump from Ola, make a 100% fix with this pump.
Thanks again for the input and link!
« Reply #9 on: May 28, 2009, 10:18:22 am »
The pleasure is all mine. Glad it worked out and please let the rest of us know more about the Pauter pumps and his modifications. Why is Skinne seeing these problems and nobody else? Lots of cars use these pumps with succes (as far as I know)
cassa
« Reply #10 on: May 28, 2009, 10:40:41 am »
The pump works even if its worn, so maybe people think its ok, but have wear that they dont know of.
Skinne only use the pump to.... pump oil.  nothing fancy.
