October 13, 2026, 04:49:04 am
VDO shift light ?
Topic: VDO shift light ? (Read 6209 times)
Black Sheep
less is more
VDO shift light ?
May 27, 2009, 18:01:35 pm »
Anyone know how " if possible " to set up a shift light for my VDO tacho ?
I don't know what hard ware I'll need , cant find any imfo on the net . A little help please
P.S I know it dont rev too high , Im looking for a higher one
Last Edit: May 27, 2009, 18:03:13 pm by 49-rag
13.03 @ 98mph
Bernard Newbury
9.50 @ 141 MPH
Re: VDO shift light ?
May 27, 2009, 18:04:38 pm »
What ignition sytem are you using?
Black Sheep
less is more
May 27, 2009, 18:07:25 pm »
Bosch Blue coil coupled up to a 010 dizzy . Tacho pics up on the nutral off the coil
13.03 @ 98mph
Bernard Newbury
9.50 @ 141 MPH
May 27, 2009, 18:10:52 pm »
Quote from: 49-rag on May 27, 2009, 18:07:25 pm
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/8952_-_LED_Shift_Light.aspx
Black Sheep
less is more
May 27, 2009, 18:18:51 pm »
Thanks for the link Bernie may go with that , want to try and get something that just leave's a shift light I can fit into one of my dash pods with the hardware hidden behind the dash .
13.03 @ 98mph
Turtle001
May 27, 2009, 18:28:18 pm »
i wanna do the same thing -- but i'm on a 6V circuit -- with a 6V VDO tach -- any ideas for that?
http://turtle.skynetblogs.be
Wünderwolff
aka Dr. Jeckill
May 27, 2009, 19:35:28 pm »
@ 49 rag, why not look at an autometer shift light with pill. Check their website, it is just the light and then a small yellow fuse like thing below, with the rpm you want it to flash depending on what "fuse" you use.
@ turtle, why not go 12 volt?
Wünderwaffe are Go!
Black Sheep
less is more
May 27, 2009, 21:04:48 pm »
Thanks for that Doctor , had a quick look aroun dhe autometer web site and will pop back there later for a ib of a read
13.03 @ 98mph
