July 01, 2026, 22:32:27 pm
Latest Member: bigsiembowski
| | |-+  Does Anyone Run One Of these In there Hot Vw Engine and is It worth it?
Author Topic: Does Anyone Run One Of these In there Hot Vw Engine and is It worth it?  (Read 6051 times)
peach_
« on: May 27, 2009, 20:04:59 pm »
Does Anyone Run a After-Market "Windich Tray" In the High Hp Vw engine?
Or are they not really worth it?
Iv heard that a "Windich Tray" is built into a type-1 case anyway, but was just wondering if anyone could shed anymore light on the subject?
cheers
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
« Reply #1 on: May 27, 2009, 20:11:22 pm »
I actually have one that I got in a trade a long time ago.  I never used it.  Heard they can cause oil starvation and don't work that well.  I used to use windage pushrod tubes from CB.  They I believe worked pretty well.  Just run a big sump, that works.
« Reply #2 on: May 27, 2009, 20:13:46 pm »
I tried to use one when I was 16 and it did not clear the cam.
« Reply #3 on: May 28, 2009, 05:10:56 am »
I've got one in my 2919 -- keeps the oil from the crank and helps it from "foaming"
V8's say it worth about 1% HP gain by keeping the crank from having to slice through the oil
marc1951
« Reply #4 on: May 28, 2009, 05:21:09 am »
Toss it!
I tried one years ago and the only thing it did was break loose and rattle a lot.
I've built scores of high performance VW engines and what has always worked for me is to
use a sump and run your oil level a bit low on the dipstick to keep the crank out of the oil and churning through it.
Marc Buehler
DRA
The legendary DRA car club
(Der Rennmeister Association)
« Reply #5 on: May 28, 2009, 07:15:43 am »
Wow, people still make windage trays?
Haven't heard that word in 25 years. Thought they left with the early '80s. Never used one and don't really plan to. But... to each their own.
« Reply #6 on: May 28, 2009, 15:44:46 pm »
How do you know that?
