November 02, 2026, 22:15:44 pm
| | |-+  problem connect empi
Author Topic: problem connect empi  (Read 9794 times)
63RACER
« on: May 28, 2009, 09:50:47 am »
i have gauges empi but i have a problem !
i have the + and - but how to connect the probe ?
1963 oldschool 1776cc
1964 sunroof vintage
1967 project cal-look
Sam K
« Reply #1 on: May 28, 2009, 13:12:27 pm »
The two "studs" that attach the gauge to the car are also the terminals where the gauge gets it's signal. You need to insulate them from the chassis and each other using washers made of platsic, rubber or some other non-conductive material.
« Reply #2 on: May 28, 2009, 18:00:15 pm »
Just waht I was gonna say  Wink Empi originally provided some plastic bushes that slipped between the termial and the clamp Smiley
63RACER
« Reply #3 on: May 28, 2009, 22:10:00 pm »
the two "studs" is + and - , it's ok , but where connect the probe ?  Undecided
excuse me , but i'm lost ...
SlingShot
« Reply #4 on: May 28, 2009, 22:15:22 pm »
Is it a oil Temp Gauge or a Oil Pressure Gauge?
Will Race For Beer !!!
63RACER
« Reply #5 on: May 28, 2009, 22:17:08 pm »
two , temp and pressure oil !
roland
lates are the new splits...
« Reply #6 on: May 28, 2009, 22:19:38 pm »
If i got it right:
SlingShot
« Reply #7 on: May 28, 2009, 22:23:27 pm »
This should help....
63RACER
« Reply #8 on: May 29, 2009, 08:50:57 am »
ouaahh  Grin
it's exactly what i need !!
thank you SlingShot and Roland !! Wink
Antoine
« Reply #9 on: May 29, 2009, 20:07:37 pm »
I have the same problem as 63RACER and this diagram will help me a lot !   Thanks Slingshot !
( and don't forget to send me my hubcaps ...  Wink  )
... and thank you 63 RACER for this request  Smiley
SlingShot
« Reply #10 on: May 30, 2009, 01:29:57 am »
No Problem, The caps are on their way.  Smiley
vwxtc4free
« Reply #11 on: May 30, 2009, 23:56:31 pm »
What are you guys using for a temp sender ? Will a VDO unit work ?
63RACER
« Reply #12 on: June 02, 2009, 16:59:46 pm »
assembly , to be continued......
I have connected my gauge T° oil, but it gets stuck on 140°  that I met the contact   Undecided
why ?
