September 23, 2026, 22:26:01 pm
| | |-+  thermostat or not?
Author Topic: thermostat or not?  (Read 12941 times)
« on: May 29, 2009, 12:47:12 pm »
just another query off the top of my head. i have most of the queries with regard to my engine build solved by now, but this one is still a mystery.
i will be running a nice 181 fanhouse and i have all the internals. but no thermostat yet. i have heard about welding the "flaps" open and leaving them out, which seem like easy options. but other people vouch for a thermostat as it's the way it was meant to be so why not run it in a hipo VW engine, too. all i know is it will allow for a quicker warmup of the engine...
i'd like to hear some opinions on this. mind you, i haven't got a thermostat yet and they can't be bought new as far as i know...
thanks in advance!
181
« Reply #1 on: May 29, 2009, 13:47:20 pm »
lookie: http://www.thesamba.com/vw/classifieds/detail.php?id=666175
I plan to run the thermostat on my 2276 IF the sidewinder J-tubes will be in a safe distance from it. If they will be close there´s no point of having a thermostat I think.
« Reply #2 on: May 29, 2009, 13:52:07 pm »
i know, did a search after posting and i will get that one i suppose.
just wondering what the general consensus is.
my proformance header should run under the cylinder heads as far as i know. my last BP header ran under the cylinders, well then i get your point... Wink
« Reply #3 on: May 29, 2009, 17:05:49 pm »
There is a complete nos set up on the samba, in general parts on page 5-6. they could'nt hurt  haveing them .
« Reply #4 on: May 29, 2009, 17:32:03 pm »
I think a thermostat is the way to go, but like mentioned you need to make sure the header runs under the heads like it did with the heater boxes. Also using (or making) some shields for the 1 & 3 pipes like a Thing had would be a good idea as well.
youngnstudly
« Reply #5 on: May 29, 2009, 17:45:15 pm »
Your concern was my concern a few days ago (as I am completing my 2276 right now). If you read some of the posts further down, some of the guys give me input on using the flaps and thermostat.
http://www.cal-look.com/forum/index.php/topic,30268.0.html
-Andy
John Rayburn
« Reply #6 on: May 29, 2009, 20:18:03 pm »
I know two people that had disasters when the thermostat failed and didn't open. I leave it off.
I also park at Nick's.
« Reply #7 on: May 29, 2009, 20:19:02 pm »
weld it open if you are planning not to run a thermostat
« Reply #8 on: May 29, 2009, 20:44:02 pm »
It is designed to fail in the open position. When I was 16 I was driving my Dad's Beetle around town on a hot Fourth of July when the motor started running abnormally hot. Seems something had wedged itself behind the shroud and prevented the flaps from opening. Could have been a disaster if it wasn't for the gauges warning me.
youngnstudly
« Reply #9 on: May 30, 2009, 00:34:53 am »
The old thermostats fail in the open position but the new (replacement) bellow-type ones don't and that's what John is talking about. That's why I am leaning towards no thermostat (unless I can find an old one that is in good condition-not too likely though Sad).
Steve DKK
« Reply #10 on: May 30, 2009, 02:45:14 am »
Unless you are experiencing sub zero German winters I would lose the thermostat.
Go fast, don't turn
Dave Rosique
nobodyouno
« Reply #11 on: May 30, 2009, 03:06:02 am »
I vote lose the thermostat, keep the flaps & linkage secured in the open position.
Horsepower=heat... I've never had a problem warming up an air cooled VW Wink
I think they call 'em Hot VW's for a reason...        ok, I'll stop now Grin
~DR.
« Reply #12 on: May 30, 2009, 08:55:44 am »
ok, different opinions here. but thanks!
so, how could i secure the flaps since i cannot weld...
that thermostat posted posted by 181 is the one i meant, it's NOS so should fail like VW meant it to fail too.
« Reply #13 on: May 30, 2009, 16:51:30 pm »
..., how could i secure the flaps since i cannot weld...
Just install them with the stock spring.  They'll stay wide open.
I did a test with my car.  I have a pair of flaps that are welded wide open.  In or out, they make no difference.  I think Jake's test showed the same.
« Reply #14 on: May 30, 2009, 19:00:55 pm »
hi bruce, thanks for the post. which spring do you mean? my flaps don't have a spring.
and do you mean jake raby? what did he test?
« Reply #15 on: May 30, 2009, 22:38:51 pm »
There is a spring that works "against" the thermostat, you can see it here behind the linkage that connects the flaps:
« Reply #16 on: May 30, 2009, 23:56:45 pm »
ok, thanks zach!
so if i mount it this way and not hook up the thermostat it'll work fine?
Dave Rosique
nobodyouno
« Reply #17 on: May 31, 2009, 02:33:11 am »
ok, thanks zach!
Correct Deid, the spring will keep the flaps open.
I've never welded the flaps in place, but I've replaced the spring with mechanics wire many times with no problems.
~DR.
Steve DKK
« Reply #18 on: May 31, 2009, 04:04:05 am »
Why not just remove them?
Go fast, don't turn
Jesse/DVK
'64 2176cc
« Reply #19 on: May 31, 2009, 10:41:56 am »
I believe they direct the air more to the heads.
« Reply #20 on: May 31, 2009, 10:43:54 am »
jesse, will you be using a spring like shown above too?
have you fitted the flaps already?  Wink
p.s. good luck building today!
« Reply #21 on: May 31, 2009, 17:55:31 pm »
That's what Gene said.  But the tests Jake did (Raby) showed otherwise.  I saw no difference when I removed them.  Cooling fan speed has a much bigger effect.  A bigger pulley at the bottom cools way better.
« Reply #22 on: May 31, 2009, 19:12:38 pm »
Or a smaller 356/912 at the top! Or both! Either way you better have a welded fan!
« Reply #23 on: May 31, 2009, 20:34:55 pm »
I always like to run the flaps and also the thermo whenever possible. But, clearance issues with merged headers and aftermarket fan shrouds often stand in the way.
On the other hand, thermostats do little work on 100+ degree Texas afternoons and 80 degree mornings! Roll Eyes
SlingShot
« Reply #24 on: May 31, 2009, 22:29:32 pm »
~DR.
Horsepower=heat... This is true, but a Thermostat will allow the engine to get up to proper temp quicker.
Will Race For Beer !!!
Jesse/DVK
'64 2176cc
« Reply #25 on: May 31, 2009, 23:35:18 pm »
Is this test available somewhere? I have a Bugpack 36hp fanshroud in which flaps are hard to install. If removing them should make no difference that should be nice.
Warming up a high perf engine is always a must with the big sumps etc..
Jesse/DVK
'64 2176cc
« Reply #26 on: June 02, 2009, 13:59:39 pm »
Anybody knows where I can find the test?
Type1/DVK
« Reply #27 on: June 02, 2009, 14:47:04 pm »
i'll secure mine with mechanics wire, or just a plain weld.. we'll see when i'm at it tomorrow.
edit: http://www.thesamba.com/vw/forum/viewtopic.php?t=139668&highlight=jake+raby+thermostat
« Last Edit: June 02, 2009, 14:48:49 pm by Type1/DVK » Logged
