October 15, 2026, 13:09:42 pm
| | |-+  emulsion tubes for DRLA's
Author Topic: emulsion tubes for DRLA's  (Read 3861 times)
« on: June 02, 2009, 10:43:59 am »
what emusion tubes do you need for a set off 40 DRLA's. i have a set right now, but the tubes are incorrect. but i can't find which ones i do need for these.
Mick Geraghty
« Reply #1 on: June 03, 2009, 09:07:29 am »
Usually for a NA car 9164.2. Or if you already have them 9164.3 (I cant tell the difference between the two tubes on the street with my LM1).
If they are alfa carbs from the factory they will have 9164.1 or 9164.4 fitted. You can solder the extra holes these tubes have to make the same pattern as the tubes above. Personally id just buy a set of reproduction .2's from Eurocarb (£44 for a set of 4). Ive tried them and they work fine.
Mick
« Reply #2 on: June 03, 2009, 09:12:12 am »
thanks.
i indeed have the alfa tubes as i expected.
