September 15, 2026, 11:01:36 am
Bad Habit
Help me !!!
Topic: Help me !!! (Read 10612 times)
turtle racer
Best Et 12.84 at 171 km/h
Help me !!!
June 16, 2009, 13:55:10 pm »
I have a problem of driving regulation, I do not manage to make take the maximum of tours minutes has my engine 1776 cc.
I have 48 IDA gone up on short pipes with the following regulations 175 in gasoline and 200 in air. My buzzards are in 40.
The use of the engine strip only.
Thank you for your help.
I love the racer, gasser nostalgia.
http://turtleracer.skynetblogs.be/
roland
lates are the new splits...
Re: Help me !!!
June 17, 2009, 10:42:49 am »
I think you should write that in French, then one of us will translate it in English.. right now it's a little hard to get what you mean...
turtle racer
Re: Help me !!!
June 17, 2009, 11:11:53 am »
Merci Roland, j'utilise un traducteur sur le nett donc bien galére parfois.
J'ai en faite un problème de réglage moteur.
Je n'arrive pas à trouver le régime max de mon 1776.
Je voudrais savoir quel type de gicleurs de doit mettre dans mes 48 IDA. Actuellement j'ai des buses en 40; des gicleurs d'air en 200 et en essence 175.
L'utilisation sera que pour la piste.
Re: Help me !!!
June 17, 2009, 12:37:31 pm »
Roland will see if my translation is ok, but basically are you wondering if the jets you have are ok for maximum performance?
1776cc drag race motor,
48IDAs on short manifolds,
40mm Venturies,
175 fuel jets,
200 air jets.
Jim Ratto will probably be able to help! Other useful information would be cam, rockers compression ratio, heads and valve sizes, rpm. I can't help any more than that!
roland
Re: Help me !!!
June 17, 2009, 13:51:37 pm »
Quote from: turtle racer on June 17, 2009, 11:11:53 am
Qu'est ce que tu veux dire par la, trouver le régime max? ton moteur ne monte pas dans les tours?
Other than that Neil you're right, sorry for the french aparté people
turtle racer
Re: Help me !!!
June 17, 2009, 17:56:14 pm »
Oui c cela Roland, il ne monte pas dans les tours.
Neil, you all understood.
Last Edit: June 17, 2009, 17:59:17 pm by turtle racer
Christofe
Re: Help me !!!
June 17, 2009, 20:57:34 pm »
et quel arbre a cames ?
msd / rupteur ?
pompe a essence ? quel type ? regulateur de pression ?
Bien à toi
Christofe
roland
Re: Help me !!!
June 17, 2009, 23:22:46 pm »
So the problem is that the engine won't go to high rpms... with more info, should be easier to figure out
turtle racer
Re: Help me !!!
June 18, 2009, 08:39:04 am »
Arbre a came FK 45
MSD complet avec boitier 6AL
pompe a essence Holley bleu avec régulateur a 4psi
Last Edit: June 18, 2009, 17:58:51 pm by turtle racer
Frank LUX
Back...Soon...hopefully!!!
Re: Help me !!!
June 18, 2009, 09:10:13 am »
Quote from: turtle racer on June 18, 2009, 08:39:04 am
Tree has cams FK 45
MSD complete with boitier 6AL
Gas pump HOLLEY Blue regulating in 4psi
I think would better write in French, or learn English or get a better Online Translater....
Sorry Turtel but most the stuff you "wrote" does not make sense....
Frank
Frank LUX
Re: Help me !!!
June 18, 2009, 09:11:06 am »
Quote from: Frank LUX on June 18, 2009, 09:10:13 am
Tree has cams FK 45
Frank LUX
Re: Help me !!!
June 18, 2009, 09:12:18 am »
Quote from: Frank LUX on June 18, 2009, 09:11:06 am
Tree has cams FK 45
I think it would easier for you to write in French, or learn English or get a better Online Translater....
Frank
Re: Help me !!!
June 18, 2009, 09:20:02 am »
Tree has cams FK 45
Frank
We'll get there! It's funny that looking at some of the first postings on here how much better some of the regular posters english has got over the last couple of years!
Whou would have thought that you can learn English through a Norwegian forum about a German car...
turtle racer
Re: Help me !!!
June 18, 2009, 18:02:49 pm »
Sorry Frank like lot of people !!!
My translater online is not good.
Last Edit: June 18, 2009, 18:06:51 pm by turtle racer
Fasterbrit
Re: Help me !!!
June 18, 2009, 23:54:20 pm »
I blame the 40 buzzards. Pesky creatures at the best of times
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
pughdog
www.Jagerbug.com
Re: Help me !!!
June 19, 2009, 07:42:57 am »
www.Jagerbug.com
