November 03, 2026, 15:54:18 pm
| | |-+  What ignition are you running with your turbo efi
Author Topic: What ignition are you running with your turbo efi  (Read 9321 times)
Rocket Ron
It's old school for a reason
« on: June 16, 2009, 14:46:54 pm »
Just looking for advice as to what ignition to run with a second hand turbo efi kit I've bought
a list of parts or full kit would be great
thanks in advance
13.12 @ 101.84
Grooving out on life
Martin
Cash Converter....
« Reply #1 on: June 17, 2009, 12:32:44 pm »
is it a fuel only efi or is it a proper engine managment system, and if so, which one?
Martin
Martin
www.taylormachine.co.uk
OFF/500
Rocket Ron
« Reply #2 on: June 17, 2009, 15:03:55 pm »
It a stinger 4424 so a proper engine managment system
I've been reading up on this as I'm very new to EFI ecu etc and I think that I will need some sort of crank trigger ignition system with 24 teeth or less, it must be an even number, according to the manual.
It appears I will need also an external ignitor but for how may coil packs or what make are compatible has me stumped at the moment
It appears that you are able to by ignitors for 1 to 4 coils. Why would I need more than one coil pack?
as I'm a bit lost with this any help wold be great
Ta Ron
« Last Edit: June 17, 2009, 15:07:43 pm by rocket ron » Logged
13.12 @ 101.84
Martin
Cash Converter....
« Reply #3 on: June 17, 2009, 16:09:47 pm »
Hello Ron,
You'll need a toothed wheel on the crank, along with a crank triger sensor, i dont know how many teath as ive not yet read about the ecu (i've downloaded the manual).
You need a minimum of 2 coils. each coil has 2 output posts. one coil fires 1 & 3 and the other fires 2 & 4 (its a wasted spark system). or you can have one coil per cylinder.
the first option is the easyest. you can use a regular ford coil like this
http://www.dtafast.co.uk/accessories/acc%204+6%20cyl%20coils.jpg
I make a crank triger setup.
http://www.taylormachine.co.uk/Taylor_Machine_Services/Products.html
hope this helps
Martin
Martin
OFF/500
Rocket Ron
« Reply #4 on: June 17, 2009, 22:28:16 pm »
Martin
Thanks for taking the time with this to show me the way forward
I would be very interested in one of you crank fired systems could you pm me a cost for this?
also would the coil packs be the bosch 008 packs ? and would I need an external ignitor for these if I'm running the 4424 stinger, reading thought the manual it appears so.
What are the advantages of running one coil per cylinder as apposed to a pair?
thanks in advance and sorry I didn't get back to you sooner as I've been out on an appointment for work this evening, turns out the guy I met runs a skyline that does 7.6 quarters and has a new 350z that he will be running in pro mod later this year  thats run a 6.6 stateside Shocked
regards Ron
« Last Edit: June 18, 2009, 06:28:29 am by rocket ron » Logged
13.12 @ 101.84
Martin
Cash Converter....
« Reply #5 on: June 18, 2009, 07:06:30 am »
Morning Ron,
The valero coil packs as supplied to fords / Vauxhalls should just wire strait into the ecu.
The advantage of running coil on plug, is that they get longer to charge up between cycles so if your running say more than 25 psi boost and your spinning up to 8,000+ rpm the coil on plug set up has a better chance of lighting it all up!
anything other than that, then the twin coil deal is the best as easiest to set up. you'll be amazed how strong the spark is.
the guy in the skyline are doing a great job, I can't wait to see there 350z
I'll pm you on the trigger costing
Martin
Martin
OFF/500
Rocket Ron
« Reply #6 on: June 18, 2009, 12:00:12 pm »
Morning Ron,
Martin
Martin i've emailed you back
Ta Ron
13.12 @ 101.84
