October 13, 2026, 06:22:12 am
| | |-+  Rear suspention questions ???
Author Topic: Rear suspention questions ???  (Read 8704 times)
Christofe
« on: June 17, 2009, 21:28:49 pm »
Hi Guys,
After my gearbox breakdown(ring /pinion at Gary's picnic I have to solve a suspention issue.
When I launch, the car almost grinds on the floor and then bangs on the other way.
My actual setup
- original shokcs
- all urethane rubber mount
- Berg rubber mid-mount
- HD 29mm torsion bars
- original spring plates
- bus rubbers (not on the car at garys picnic)
My plans are :
- solid mounts allround
- harder shoks (red koni's ?)
- straps retainer
- weld a metal piece under the spingplate to avoid it to travel all the way back after the launch.
So all advice WELCOME
Christofe
D.A.S
Tekken
www.proturbovw.com
« Reply #1 on: June 17, 2009, 21:56:57 pm »
Hi Christofe.
Put on limit straps to avoid a bad positive camber,also get shocks with adjustable rebound-you want to limit the travel back up.Don't know how your engine and rpm's are at launch,but a softer clutch may be a thing to look at.
Stian
Christofe
« Reply #2 on: June 18, 2009, 22:07:50 pm »
Thx Teken !
Any other advice Huh
Christofe
flatfire
« Reply #3 on: June 18, 2009, 22:24:39 pm »
I agree on the limit straps. Are you using the bug on the street? I have solid mounts and they will be coming off in the winter.
On the back of the bug I now have the shocks off my racecar (betelgeuse) which launches well, they are called gas adjust. SSP sells them.
What size is your rear tyre?
Christofe
« Reply #4 on: July 28, 2009, 20:40:26 pm »
Guys,
where can I buy those straps ?
Anyone having experience with the ACE clutch disc ?
I have a stage 2 with a 4 puk disc, any experience with the black magic ?
Any use of putting harder spring plates ?
THX
Paul Bate
« Reply #5 on: July 28, 2009, 20:45:10 pm »
Guys,
THX
Hello Christofe,
Email me @ vwfastorange@aol.com and I'll help you with a good set up!!
See you next year at Gary's Picnic next year !! Cool
Paul
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
Squirmn German
Quickest Street Legal VW East Coast USA
« Reply #6 on: July 29, 2009, 03:27:40 am »
What engine? N/A or turbo? HP?
9.66 @ 142...NO NITROUS!
Mean Gene Cook
Cooker's V-Dubs, Clear Spring, Maryland, USA
Christofe
« Reply #7 on: July 29, 2009, 22:51:38 pm »
NA 1915 CC ,IDA, 170 HP and 210 NM
Regards
Squirmn German
« Reply #8 on: July 29, 2009, 23:24:56 pm »
Oh, and what does she weigh with you in?
Mean Gene Cook
Christofe
« Reply #9 on: August 03, 2009, 17:08:08 pm »
Don't know exactly but the car is stock and I'n not light neither (95kg), all metal, rear seat removed, front seat are light 914 type.
Christofe
