November 04, 2026, 15:16:36 pm
| | |-+  IDA idle jet holders?
Author Topic: IDA idle jet holders?  (Read 4718 times)
JS
« on: June 21, 2009, 22:15:24 pm »
What size are you guys using on your engines? And more importantly: Are they available for purchase anywhere in different sizes? Or do you have to solder and drill your own?
Thanks, Johnny.
Signature.
« Reply #1 on: June 22, 2009, 01:51:25 am »
They are available in different sizes. It's been 205 years since I messed with them but I think they were available as .080 .100 & .120
I'm sure someone will catch any errors!  Wink
« Reply #2 on: June 22, 2009, 06:58:59 am »
.080 .100 & .120
Are those inches?
Rasser
« Reply #3 on: June 22, 2009, 20:39:20 pm »
I soldered mine and drilled them to size.
What you really will notice when making them smaller is that throttle response at low rpm, will be a lot better (realy noticeable when cruising below 2000rpm and trying to increase speed a little). Well, at least thats my experience.
I have emailed a lot with Bud Hauge from redlind weber, and he has really helped me a lot with the understanding of the idle circuit on the 48´s. He was right about EVERYTHING he told me to do to my carbs. That guy knows his shit!
I have saved all the emails from him. If you wan´t a copy, send me a mail on rasmusthomzen@hotmail.com
1955 type1
1966 type2 13w deluxe
JS
« Reply #4 on: June 22, 2009, 21:34:17 pm »
Rasser, you have mail!  Wink
Signature.
Rasser
« Reply #5 on: June 24, 2009, 19:53:12 pm »
Mail is sent to those that wanted the emails.
Quote, Bud Hauge:
"the air jets both main air and idle air have huge affects on two functions stringth of signal and entry timing and high rpm change
it is a balance between the low range band width and the over lap of the high range.
Example if you go to a 90 or 100 idle air the low range will have a stronger signal at initial responce but run out sooner on the top end a narrow band if you will. but more responsive. So with that you might have a need to bring the mains in sooner which means we might take the main air and shrink it to get main entry to come in sooner
i know I may be confusing this some but its something you learn to balance the over lap of two arches or bubbles."
1955 type1
« Reply #6 on: June 24, 2009, 20:27:05 pm »
I had a set of 060's that I bought 15 years ago that I never did anything with, re drilled them and .... well I posted about it somewhere else before. Car runs better all around.
