November 04, 2026, 16:15:23 pm
352339 Posts in 28963 Topics by 6931 Members
| | |-+  New oil leak
Author Topic: New oil leak  (Read 11370 times)
Tony M
« on: June 22, 2009, 22:45:57 pm »
This one just started up, but i cant figure why? I now have oil comming up between my dist and case - not inside my dist. but right under the clamp. i have pulled my dist. out, replaced the o-ring and put a bead of silicone around the dist clamp to the case. I did find a good amount of oil on top of the dist drive. I let it dry for a day or two, the go out for a buzz and oil pumping out again. This is one area where there is no real pressure problems. Has any one ever seen a case crack into the dist/drive area ? Any info would be a help.
 Thanks Tony
« Reply #1 on: June 22, 2009, 23:11:20 pm »
Is it still doing it after replacing the o-ring.  What kind of breather system do you have?  Perhaps it is building crankcase pressure that is causing that.  Does oil show up anywhere else like around the dip stick?
« Reply #2 on: June 22, 2009, 23:50:04 pm »
 Thanks Tony
give me a call buddy....
Jim
Tony M
« Reply #3 on: June 22, 2009, 23:50:40 pm »
Nope - dry on the dip stick - using an empi breather from v/covers and oil filler - had all 3 off last time driving - was thinking the same thing - made no diffenence.
« Reply #4 on: June 23, 2009, 06:32:21 am »
you are sure its vented to the atmosphere?  Had a friend who fitted all the breather tubes but not an air filter so the crankcase pressure just built up and oil came out of the dizzy.
Tony M
« Reply #5 on: June 23, 2009, 15:44:09 pm »
Have been using the same breather system for years now with no problems - This just came out of the blue.
Brandon Sinclair
« Reply #6 on: June 23, 2009, 16:59:55 pm »
It sounds like it is coming from behind the pulley or maybe the fuel pump or fuel pump block off.  Hit the case with brake cleaner and try investigating some more.  Keep us posted.
Tony M
« Reply #7 on: June 23, 2009, 20:41:59 pm »
 It is comming from under dist. clamp - have cleaned it many times and resealed many times - still from under dist clamp  Angry
Brandon Sinclair
« Reply #8 on: June 23, 2009, 22:42:12 pm »
If you know it is coming from that point then maybe it is the seal.  There are a few different seals out there-one with the "v" like the photos in the link and the other with the round sides
http://www.thesamba.com/vw/forum/viewtopic.php?t=307657&highlight=bosch+distributor+oring
It may be a good idea to get an OE or Bosch seal and give it a try.  Slide the clamp on the distributor first them the o-ring, then maybe grease the oring and install.
If that does not work maybe someone else may have a suggestion for you.
2muchjunk
« Reply #9 on: June 23, 2009, 22:47:36 pm »
Has the engine taken any kind of a hit to the distributor or front of the case?
There are a few oil galleys in the area, pull the distributor and inspect the inside bore for any cracks.
Thanks, I always appreciate unsolicited advice from ignorant bystanders!!
Tony M
« Reply #10 on: June 23, 2009, 22:58:45 pm »
Thats the seal i dont have - gone into all of my inventory - will get one of the v type seals
No hits to the case
Brandon Sinclair
« Reply #11 on: June 24, 2009, 00:57:34 am »
You may want to contact Glenn Ring who posted that photo to see if he has any for sale.  I had a hard time locating a non round one as well.  Good luck.
« Reply #12 on: June 24, 2009, 20:28:24 pm »
time to build the biggie.... stop pussyfooting around trying to fix your little motor and get to work... sheeez do I have to call Jerry?
"for what yer doin'..."
Tony M
« Reply #13 on: June 24, 2009, 23:18:32 pm »
Hey your GUMBY DAMIT - POKEY is looking for you( aka P&Z) You just go a head and call Jerry see if i care  Shocked No your right, it's time for Big Boy to get built. I have a kid the wants my little motor for a sand rail - call it sold - and then i will have some green - money not smoke.
« Reply #14 on: June 25, 2009, 00:05:41 am »
dude just read the bottom of your own posts....   now go build that fricking motor.
Calling Jerry now....  "hey Jerry.... Tony's only running 90.5's!!!!! ....hahaah" Can you guess his response to that?  Grin
Tony M
« Reply #15 on: June 25, 2009, 02:00:31 am »
Never said my car was slow for a baja Grin
« Reply #16 on: June 25, 2009, 21:51:44 pm »
is that motor done yet?
