September 24, 2026, 07:11:37 am
| | |-+  Size of breather hose for stock oil filler without the down tube.
Author Topic: Size of breather hose for stock oil filler without the down tube.  (Read 4896 times)
Brandon Sinclair
« on: June 26, 2009, 16:51:02 pm »
I am getting rid of the nasty looking screw in aluminum oil filler/breather and going back to the more traditional looking stock filler-the one without the down tube.  Now the breather tube on this thing is much larger (whcih I want) then the one with the down tube and I have seen modification where people weld in AN fittings and use braided hose or even use some clear hose from the hardware store.  I want to go with the more traditional cloth braided hose like the original German hose but was wondering what size I needed and if someone can point me in the right direction to find it.  The regular cloth breather hose that I have in my stash is too small in diameter.  Thanks.
« Reply #1 on: June 26, 2009, 17:06:06 pm »
There were two sizes, normal and massive!
« Reply #2 on: June 27, 2009, 03:26:26 am »
You need 12mm hose.
volksnut
« Reply #3 on: June 28, 2009, 13:40:40 pm »
Brandon, I found this old 80's Bugpack unit (looks like a beehive) and works/looks pretty well....sometimes you have to be different Cheesy
I was installing my CSP linkage here that's why there is none, oh and the air cleaners are gone now too so be nice....
« Last Edit: June 28, 2009, 13:43:21 pm by volksnut » Logged
« Reply #4 on: July 01, 2009, 20:42:08 pm »
you might have the 1974 oil filler with the big outlet. I forget the diam of that hose, but it was not a "bulk" hose it was a formed breather hose VW # 113129651... think it was 15 or 17mm.
