October 16, 2026, 23:56:02 pm
breather boxes, when do they pay off?
Topic: breather boxes, when do they pay off? (Read 20861 times)
January 15, 2007, 17:03:11 pm »
i am having a bit of a pondering afternoon
when does it pay off to use a breather box?
does it pay off with your dual carb 1600? or only with bigger than stock sized engines?
or is there no real need for it?
sometimes i see small engines that have them and large ones that don't...
cheers
DVK ~
Re: breather boxes, when do they pay off?
January 15, 2007, 19:30:16 pm »
If you want to keep the aircleaners dry it is better to use a breatherbox. I made special small boxes for use with the original fan shroud . And they look nice .
http://www.udobeckertuning.de/
Regards Udo
www.Udobeckertuning.de
January 15, 2007, 20:28:47 pm »
but that is for aircleaners, i was more or less thinking of the valve covers...
DVK ~
January 16, 2007, 15:03:15 pm »
do they have no use?
DVK ~
January 16, 2007, 16:12:28 pm »
I once put a breather box on a high reving 1600 (041 heads, 36 Dells, ratio rockers, cw crank) and noticed more seat of the pants power and extended revs. I feel it evacuated the crankcase pressure allowing less windage of the crankshaft, but I could be totally wrong on my hypothosis.
January 16, 2007, 16:16:22 pm »
sounds interesting, can anyone second that idea?
DVK ~
January 16, 2007, 17:05:26 pm »
That is the theory. Also, if you have oil coming out of the crankshaft pulley, a breather box can alleviate that problem.
January 16, 2007, 19:34:05 pm »
alright.
does anyone have good experience with a CB breather tower?
i've read they sometimes leak, but i like the looks of it
DVK ~
Steve D.
January 17, 2007, 01:07:15 am »
My last motor was an 1835 with an Engle 110 built with used up parts that my brother and I put together when we were 14 & 16 years old (respectively). It drove just fine all over the place and would cruise 80mph on the freeway all day long, but once you upped it to 85 you would have a column of white smoke following you down the road. Next time we had the motor out we popped a cheap buckpack breather box on the motor, hooked to each valve cover and the oil filler vent- bingo, no more smoking (take note Carney).
Point is, this was a terrifically obvious demonstration to me how larger displacement/higher rpm created extra crankcase pressure. This exess pressure would push oil out of the motor where it would be burped up on the exhaust and stink up the place. Adding a breather box gives all this air being pushed around a place to go without letting it take the oil with it on it's way out.
For what it's worth, I prefer the cheap bugpack breather boxes even for high performance motors because you can attatch it to the back of the shroud, and run the lines through the rear tin to the valve covers for a nice clean look- I usually open up the hole in the fittings a bit to help it breathe a little easier. Have fun!
Über Alles
10.77 avg. on pump fuel.
238I
si66
January 18, 2007, 17:02:00 pm »
yes i would agree.
In my last car a ran a 1776 without a breather box. You could drive all day sensibley (no fun), and there would be no oil coming from the front pulley, but as soon as you opened it up and really gave it some, the crankcase pressure would be too great and oil would leak out of the front pulley make a right mess. They're not the nicest looking things but in large engines that you give some, i'd recommend.
cheers
Si
January 18, 2007, 17:16:12 pm »
ok.
i can get a CB breather box tower for cheap, should i go for it?
DVK ~
January 19, 2007, 16:22:33 pm »
There was a thread on Cal-look.com about them. A couple people said they leak but could be fixed.
Frank LUX
Back...Soon...hopefully!!!
January 20, 2007, 11:10:20 am »
I use a Berg BreatherBox plus a BugPack one working as the T connection for the Lines that go to the Valve covers on my 2276cc...
Works great!!!
Frank
January 20, 2007, 15:18:34 pm »
Hi Frank
I think you have to get one of these ?
Frank LUX
January 20, 2007, 18:11:26 pm »
Quote from: Udo on January 20, 2007, 15:18:34 pm
Hi Frank
Nice one's Udo!!!
But i'm already running out of space on the Firewall with all the additional Stuff plus the Fuel & NOS Hoses...
Frank
January 20, 2007, 20:44:56 pm »
Frank, if you're already venting the valve covers through the bugpack, why do you need the berg?
for the looks of it?
DVK ~
Frank LUX
January 21, 2007, 13:31:28 pm »
Quote from: 67-indeed on January 20, 2007, 20:44:56 pm
No, Not for the Looks...
The Berg Breather Box is connected with -8AN Hose to the Engine Case via the Fuel Pump Block off plate, from the Berg Box goes a -8AN Hose to the small Bugpack Box which is the connected with -8AN Hose to the Valve Covers!!!
The Small Bugpack Box is way to small for a big CC motor and in my opinion should only be use a "T" connection...
Frank
January 21, 2007, 15:45:12 pm »
Ok, thanks for the explanation
I suppose by adding the berg box you allow the engine to breathe even more?
I've always wondered why you connect it to the case via the fuel pump cover? Isn't connected to the case already via the oil inlet?
DVK ~
