August 13, 2026, 11:34:09 am
| | |-+  Set-up for 40 Dells on a 1914
Author Topic: Set-up for 40 Dells on a 1914  (Read 8482 times)
RUSS74GHIA
VWSP163
« on: June 28, 2009, 17:38:45 pm »
I'm about to fit my recently refurbed 40s to my motor.
The parts I have for the build are as follows;
Venturis 32
Mains 142
Idles 52
Air Corrector 180
Main emulsion tube 4
Starter jet 80
Starter emulsion tube 3.
Should this set up be ok to fit & run to the rolling road? Just for further info I have W120 cam, 35.5x40 valves, 1.25:1 ratio rockers
OK, own up, who edited my sig?
« Reply #1 on: June 29, 2009, 09:02:21 am »
Elevation?
Get some 9164.2 emulsion tubes.  You are wasting your time with any others.
RUSS74GHIA
VWSP163
« Reply #2 on: June 29, 2009, 12:51:37 pm »
Elevation?
Ok, thanks for the advice - the parts I had were from an Alfa.
Excuse my ignorance, what's Elevation? The only other info I can offer is the CR which is 8:1
Type1/DVK
« Reply #3 on: June 29, 2009, 14:05:49 pm »
I have a 1776:
W120 x 40x35.5/044ers @ 9:1
Vents 30's
Mains 135
Idles 60
Air 200
Emuls F11
Furter stock rockers etc.
Runs great! sideways al the way Wink
Elevation is the height your living, near sealevel or 1000ft up?
« Reply #4 on: June 29, 2009, 15:59:31 pm »
Emuls F11
This means you have Webers.  You should delete this irrelevant info from this topic on Dellortos, it only confuses things.
Elevation = Altitude where you live.
RUSS74GHIA
VWSP163
« Reply #5 on: June 29, 2009, 17:14:05 pm »
25 metres above sea level
« Reply #6 on: June 30, 2009, 04:27:33 am »
Venturis 32
Mains 142
Idles 52
Air Corrector 180
The 52 idle jet will not work.  A 60 is the most likely.  57 is possible.
I think you will find the 142 main to be rich.  But only if you use the right emulsion tubes (9164.2).  Do not waste your time with any other tubes when this one is known to work perfectly in a VW.
Type1/DVK
« Reply #7 on: June 30, 2009, 08:54:23 am »
Quote
Sry, didn't see the 'dell's' in the topicheader  Embarrassed
« Reply #8 on: June 30, 2009, 15:53:34 pm »
You should delete your previous post.  It is confusing to have that in this topic.
Mick Geraghty
« Reply #9 on: June 30, 2009, 23:48:19 pm »
I cant tell the difference on my 2110 between 9164.2 and 9164.3's using a LM1 to measure Air fuel ratio. With something mroe accurate you may see a difference
I think start with 55's and a 142main, 34mm chokes, 180 airs, .2 or .3 emulsion tubes. I know this combo wont be far off at the pod on a 1914. Mail me your 52's and 32mm chokes and i can ream you some 55's or 60's and send you the 34mm chokes.
.2's will cost you  Tongue
Mick
« Last Edit: June 30, 2009, 23:49:54 pm by Mick Geraghty » Logged
RUSS74GHIA
VWSP163
« Reply #10 on: July 01, 2009, 02:08:20 am »
Cheers Mick.
I'll bring my set up to Bug Jam, I should have a decent amount of track time to see what works & what doesn't
If you could bring your 34's, reamers & tubes that would be great
