September 22, 2026, 11:28:34 am
| | |-+  OIL Filter Mounting Question?
Author Topic: OIL Filter Mounting Question?  (Read 9163 times)
« on: July 02, 2009, 04:08:53 am »
OIL Filter Mounting Question?  I have a Question on a certain mounting Bracket See Picture  the Question is will it Clear an 1 3/4 header? it says it can be mounted inboard or outboard Is there enough room for this bracket mounted outboard between the header pipe and the inner body on a 67 sedan without modifing the body in any way? let me know Thanks Shubee Also how low dose it hang down with an HP1 on it?  anyone have one installed on there car or pictures of a installed one?
« Last Edit: July 02, 2009, 04:31:27 am by Shubee2 (DSK) » Logged
Chris W
« Reply #1 on: July 02, 2009, 04:41:24 am »
On my 66 with a similar bracket it does not clear the body. Brackets that drop it down around 2" had to be made. You can just see them in this picture. I plan on changing it and hanging it off the bumper bracket.
Here is a shot with how low it hangs-
« Last Edit: July 02, 2009, 04:43:23 am by Chris W » Logged
« Reply #2 on: July 02, 2009, 05:15:00 am »
Hi Chris thanks for the Picture what did it hit on the Body? I am Running a Berg 4 Qt Sump so the Filter dose not hang lower then the Sump.   I also have the Bumper Bracket mount But I dont like the way you have to route the hose's
« Last Edit: July 02, 2009, 05:23:07 am by Shubee2 (DSK) » Logged
Chris W
« Reply #3 on: July 02, 2009, 05:48:41 am »
Bad picture, but you get the idea. The top of the filter mount is to wide and hits the inner fender on the engine side. Make sense? I have not looked at the bumper mount much, just looked like it might be better than what I have.
« Last Edit: July 02, 2009, 05:51:06 am by Chris W » Logged
Hotrodvw
« Reply #4 on: July 02, 2009, 07:11:22 am »
Here's how I mounted mine off the bumper bracket, and how I routed my hoses.  I don't have any issues with how they're routed.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Dustin
« Reply #5 on: July 04, 2009, 04:16:58 am »
Hey Gary, Here are some pics of mine, albeit on a late model. If you look close at the second picture, you can see that the adapter is slightly clocked on the bracket. I enlarged the bracket-to-adapter holes so that the filter would have a little extra clearance to the 1 5/8 A-1 Sidewinder exhaust (ScottP has one on a 1 3/4 sidewinder). Because of that, you can see in the other photos that I needed to clearance the underbody just slightly. It also means that I have to drop it down off the studs to pull the motor. My lines don't touch the exhaust anywhere, one coming from the pump, the other going forward to the remote cooler. Because of the exhaust, I have to run the smaller K&N filter, but it is also rated to 500 lbs. pressure and has the handy bolt head on the bottom to make removal easy. The "Old School Purist"  Grin  may not approve of anything other than a HP1 hanging down far enough to intimidate american muscle from a distance, but I like that it's tucked away safe and still easily accessible for maintenance since this car is driven every single day, rain or shine.
Good luck,
Dustin
« Last Edit: July 04, 2009, 04:23:36 am by Dustin » Logged
Der Kleiner Panzers III
www.dkpcarclub.com
'69 Tangerine Orange Karmann Ghia- In progress
'66 Marina blue Chevy II Nova Hardtop- Project mothballed
« Reply #6 on: July 04, 2009, 04:48:20 am »
Good luck,
Dustin
Hi Dustin Damm that is Close to the header and the Body?  My 1 3/4 is the one that goes under the push rod tubes so should not  hit the exhaust with an HP 1 Grin if I only need to notch the Body a Tad I might go that Way But I will be Running an Old School HP 1  LMAO Is the Filter your using smaller  OD? or shorter?  Or Both?
« Reply #7 on: July 04, 2009, 05:26:12 am »
Dustin, I dig that installation. And I agree... screw the old "hey, look... I got an HP1" approach. I'd rather have it out of harm's way and also easy to change.
« Reply #8 on: July 04, 2009, 05:34:43 am »
Dustin, I dig that installation. And I agree...I like the Old School look of the HP 1 Grin  I'd rather have it out of harm's way and also easy to change.
I Agree with you Fred  Grin  For Once LMAO Grin Grin Grin
glenn
« Reply #9 on: July 04, 2009, 13:31:41 pm »
Mine is way up out of the way in the fender well.
You can sort of see it between the fender and the tire.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
Critter1
« Reply #10 on: July 04, 2009, 16:01:03 pm »
Here is a different perspective.... This is how it fits on my Type-3 motor with an 1 1/2" header. The header isn't as close as it appears...
« Reply #11 on: July 04, 2009, 16:27:59 pm »
Oh man... that's just wrong. You KNOW I don't use that term. I prefer the term Home Schooled.
 Grin
Glenn and Critter, good looking filter installations. Clean and functional.
GreenTom
« Reply #12 on: July 06, 2009, 09:53:41 am »
I have stainless one form VWSPEEDSHOP and it clears the ganuine body, but when the body was redone it hooks a little bit but we fixed that quickly Smiley
I've seen on one pisture that the filter on that kind of mounting clears the traction bar. I've got chormed Bug pack one (the old one that was ling @ Pauls for few years in reall old bug pack box probobly from VSM days...) and it has diferent mounting brackets (looks like they should be bolted to the bumper mounting brackets).
This traction bar doesnt clear the filter mount at all Sad I think its a TB problem not filter mount.
what You recon?
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
