September 02, 2026, 01:03:50 am
| |-+  For sale!
| | |-+  Clear out time again
Author Topic: Clear out time again  (Read 6924 times)
Black Sheep
less is more
« on: July 11, 2009, 11:31:55 am »
Ok here we go need to get some stuff gone to give me some more funds for more go faster goodie's  Wink
First up is this bolt in mid mount  . Simply bolts on to the gearbox casing and presses against the underside of the framehorns via 2 urethane bushes. Reduces gearbox twist and nose lift.No welding is required, but longer studs or bolts (not supplied) need fitting to the gearbox. £30
Set of machined out 44mm venturi's for 48 ida's , these have been done well as they start out at the thinest point 44mm and fan out to 46 at the base £40
Good pair of used 135 ZX Michelin with a good 4 to 5 mm of even tread £85
A 7000 rpm VDO 115mm tacko from a 914 I think , the good thing about this is that it will fit steight into a  58 > speedo hole wire's up to the coil just needs a bit of a clean and detail £40
And once you have fitted the tacko you will need this 100mm 180 kph VDO trip speedo  Roll Eyes all good just need clean and detail £40
Continental 135 70 15 ( smart car tyres ) all good loads of tread perfect for the strip  Smiley£50
Can ship all of the above , more bits to follow
« Last Edit: July 11, 2009, 11:35:18 am by 49-rag » Logged
13.03 @ 98mph
Dokke/DFL
« Reply #1 on: July 13, 2009, 10:53:25 am »
Selling out Glenn ?
Black Sheep
less is more
« Reply #2 on: July 13, 2009, 19:37:15 pm »
Nah need to raise some funds for a proper gear box  Wink
13.03 @ 98mph
Black Sheep
less is more
« Reply #3 on: July 26, 2009, 14:47:18 pm »
Mid mount gone ,
 Cheers Diederick  Cool
13.03 @ 98mph
CHR!S/DVK
« Reply #4 on: July 27, 2009, 15:17:22 pm »
do you mean 67-indeed?
Member of DVK - Der Vollgas Kreuzers
deanosvws
OFF 24
« Reply #5 on: July 27, 2009, 15:25:54 pm »
hi glenn, ill have the vent's off you how do you want paying etc? cheers dean
OUTLAW FLAT FOUR
Black Sheep
less is more
« Reply #6 on: August 02, 2009, 17:52:10 pm »
You have a PM Deano  Wink
13.03 @ 98mph
Black Sheep
less is more
« Reply #7 on: August 17, 2009, 22:25:50 pm »
Pair of IDA K/N filters , fair condition , one has had a couple of cuts in the base ( pictured)
£50
Glass pack style small flange mufler , bought this at EBI as a quick fix when my back box fouled the traction bar I fitted there , no longer needed as ive just got a twin back box at the weekend
Done about a hundered miles with it so still it top condition , the tips bronzed off nicely £40
Pair of Scat roker covers , bit scabby on top from moisture but still very usable
£15
44mm vents are still avalible  Smiley
13.03 @ 98mph
Whiterag
« Reply #8 on: August 17, 2009, 23:08:30 pm »
Hi
slightly off topic but was your car at Beach Buggin Southsea?
Black Sheep
less is more
« Reply #9 on: August 18, 2009, 07:29:48 am »
Very slightly off topic  Smiley Yes and I was there too  Wink a nice day out  Cool
13.03 @ 98mph
Black Sheep
less is more
« Reply #10 on: August 18, 2009, 22:58:01 pm »
Rocker covers now sold  Smiley
13.03 @ 98mph
