September 24, 2026, 07:11:37 am
| | |-+  door jammed
Author Topic: door jammed  (Read 10925 times)
« on: July 16, 2009, 17:33:13 pm »
something strange happend two days ago. i was able to open and close the door just fine and now it is stuck. i shut the door and am not able to open it anymore.
so how can i open it. it won't give anything and the access to the mechanism is really hard and nothing seems to give there as well. i have thought off taking off the hinges, but the seem to be seized solid as well and i don't have a special tool to get them out.
this is not a mindgame, this is real.  Embarrassed
« Reply #1 on: July 16, 2009, 18:10:08 pm »
 Cool
Black Sheep
less is more
« Reply #2 on: July 16, 2009, 19:03:53 pm »
Sounds like a job for the big hammer again  Roll Eyes
13.03 @ 98mph
beetletom
« Reply #3 on: July 16, 2009, 19:05:42 pm »
not sure if this is possiable...
take off the door card, and try and have a play around (ooh er) with the catch? from inside??
« Reply #4 on: July 16, 2009, 19:15:07 pm »
Are you stuck inside the car?  Try rolling down a window and climb out.
« Reply #5 on: July 16, 2009, 19:39:35 pm »
screwdriver from the inside to push open the catch!
yvre
Der Autobahn Scrapers
« Reply #6 on: July 16, 2009, 19:54:29 pm »
Cheesy yeah with a laptop and a wifi connection  Cheesy
Black Sheep
less is more
« Reply #7 on: July 16, 2009, 20:19:10 pm »
Cheesy Cheesy Cheesy Ace
13.03 @ 98mph
« Reply #8 on: July 16, 2009, 21:00:18 pm »
right and i would seek help on the Lounge...  Roll Eyes
anyway.
things haven't improved. i have been able to take out the screws that hold the door, but it didn't come out. it's still stuck on the doorstop... so i may follow Jims idea or Glenns, but if someone, anyone, has a idea that still saves the door/car that would be nice.
Black Sheep
less is more
« Reply #9 on: July 16, 2009, 21:29:44 pm »
Im a bit confused here Nicolas , how on earth did you get the screws out that hold the door in place with it closed Huh?
Do you mean the hinge pin's ? is this on your type 3 ? think we need some pix here !  Wink
13.03 @ 98mph
Felix/DFL
« Reply #10 on: July 16, 2009, 22:35:23 pm »
Hi Nicolas,
I have the same issue for a long time (maybe to long...)
The drivers door won`t open when you don`t do a trick:
Open the other door and get inside then rattle at the door opener AND the Pin that shows you if it is locked at the same time.
That opens my door now about 5 or lmore years.Some day I will fix it´for sure...  Wink
If this doesn`t help get out the sidewindow with it`s frame.The back frame covers the closing mechanism
Good luck,
Felix
beetletom
« Reply #11 on: July 17, 2009, 09:18:25 am »
probably means the screws that hold on a type 3 door card!
or he had a set of screw drivers that can go around corners!  Grin
Critter1
« Reply #12 on: July 17, 2009, 15:31:37 pm »
X2
I had this same issue with my drivers door on my 67 fastback. I was able to get the door to open with a long screwdriver form the inside. The bitch was getting around the window channel guide with all the little sheet metal bits spot welded to it. I think I removed it first. I took out the latch mechanism and compared it to a good 67 Type-1 mechanism I had (they're the same as T3 for 67). Turned out I was missing a spring and a small piece of the mechanism was broke which caused that piece to rotate down and jam the whole thing. Oh and that window channel guide.... I ground the spot welds to remove all the excess sheet metal "safety" pieces. It makes it much easier to reinstall, IMO.
« Last Edit: July 17, 2009, 15:34:43 pm by Critter1 » Logged
« Reply #13 on: July 17, 2009, 20:12:54 pm »
wel i have, kinda sorta...
i took off the front wing and made little slots in the back off the screws holding the door and then i screwed them out. so that worked great, but now the door is still stuck on the catch and the doorstop...
but i am still looking at the screwdriver option there, but i am not sure what to do with it. i think it slips inside the door and pushes the latch from the inside, but i could be wrong.
Critter1
« Reply #14 on: July 17, 2009, 22:09:50 pm »
If I was at home, I would take a picture of a latch mechanism for you. Maybe someone can post a pic and point out where / what you need to do to open it.
Critter1
« Reply #15 on: July 17, 2009, 22:14:29 pm »
Found this picture over on the Samba. Its a 67 latch. Wait, is this issue with your 67 Square, or 66 Fasty? I'm pretty sure they're different. Anyway, without actually fiddling with a latch mechanism in my hands, I would only be able to guess at what part of the latch to move to get it to open. At least we have a picture up for you, or someone to take a whak at...
« Reply #16 on: July 17, 2009, 23:34:12 pm »
Can you tell if it's the door handle that's not working or is it the latch?
I'm surprised no one has suggested a slim jim.
« Reply #17 on: July 18, 2009, 14:50:19 pm »
both... the doorknob somethings feels like it has some resistance and wants to open, but it doesn't. it seems to slip. the innerdoorlatch doesn't do anything.
thanks for the pictures Critter, that should help me a bit to know what does what.
btw it's a 67 squareback causing all the commotion.
« Reply #18 on: July 18, 2009, 20:48:06 pm »
OK the door is out. just some minor scratches on the door and pillar, it could have been much uglier if i lost it completely  Roll Eyes
so i was able to take it out by twisting the locking mechanism on the door and slide it eventually over the stub on the pillarplate. now i need a new mechanism. it was broken. so i did understand what to do with the screwdriver and i was indeed fiddling the right parts  Grin, but it was just useless as the part that catches into the part actually moving the lock was missing. it was broken off and i found it at the bottom off the door after i got the mechanism out.
so like i said, if anyone has a spare mechanism for a 67 (or later if that fits) i would like to buy one.
PM me if you have something and thanks for all the help and entertainment.
Black Sheep
less is more
« Reply #19 on: July 18, 2009, 22:10:27 pm »
I'll have a look down the shed , Broke a 64 more than a few years back think there's still some left  Smiley
13.03 @ 98mph
Critter1
« Reply #20 on: July 18, 2009, 23:55:33 pm »
67 Type-1 or Type-3 latch mechanisms are one year only.
Heres some for sale:
http://www.thesamba.com/vw/classifieds/detail.php?id=411493
http://www.thesamba.com/vw/classifieds/detail.php?id=806886
« Reply #21 on: July 19, 2009, 08:10:49 am »
off course it is one year only... just my luck again.  Roll Eyes
but thanks for the link. i'll have to look for one here in Belgium, if not i'll be ordering that one from the Samba
