October 25, 2026, 05:16:56 am
352327 Posts in 28959 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  Making an all German 36hp/Doghouse Fanshroud
Pages: 1 [2] Print
Author Topic: Making an all German 36hp/Doghouse Fanshroud  (Read 35480 times)
Black Sheep
less is more
« Reply #30 on: July 23, 2009, 22:18:29 pm »
Think Ive found another thing I want to do to my car now reading this  Roll Eyes Cool
13.03 @ 98mph
181
« Reply #31 on: July 26, 2009, 20:51:23 pm »
I started butching apart my spare shrouds this weekend  Grin
« Reply #32 on: May 14, 2010, 17:55:34 pm »
About Rune's last comment; I'm nearly done with the whole conversion but I noticed the early indention is deep enough for the most upper fins of the late shroud... I can't spot weld those. What did You do Gary and Wardvwracer?
« Reply #33 on: May 14, 2010, 18:10:35 pm »
Deano How Would you get the fan inside the shroud? Huh
Ah, the tricky part.... I have an idea how to pull that one off, but I want to see if anyone else is on the same page. I think it would be very cool to have the front face of the fan housing void of that large 4-bolt plate. I rather see a smooth face, with only the generator mounting holes in it....
Bolt it through the fan shroud and drill holes in fan to get to hardware is how I am makeing my next one.
« Reply #34 on: May 14, 2010, 18:14:49 pm »
O-YA the genarator will bolt to shroud and will not have the backing plate with the four bolts mounting it.
« Reply #35 on: May 17, 2010, 15:45:20 pm »
Here is the One I Made I uesd a Early 40 HP shroud (that way it dosent look like a Repop Scat/Empi Tiwann Copy) I like the early indention in the center plus its a great place to put my FF Heads Sticker  Grin I did it kind of like Rune but  bent a flange on the dog house part and spot welded back together now I can bolt up the Berg linkage without sloting everything just need to finish minor body work and paint now
Another good thing by using the early 40hp shroud is exactly that it allready has that indention.. I had to make a "fake" indention on the inside of mine as the dog house vane just behind it is shorter that the others..
the last post from my iPod didn't work out too well.
what i meant to say is that the indention on the top of my early 40hp shroud is NOT deep enough to touch the vanes of the 1600 doghouse rear half.
how did you solve this? or should that little open space not make a difference?
and rune, i assume you used body sealer all the way or did you spot weld the shroud too?
Rune
SCC Crew
Screwdrivers #7
« Reply #36 on: May 18, 2010, 16:24:16 pm »
Check your PMs Diederick.
deano
« Reply #37 on: May 18, 2010, 16:37:40 pm »
Buddy Hale just did one about two months ago for Eliot Vancil for his silver Oval. No front plate, no filler neck on the stand, totally off the hook. Should be at the Classis next month.
Anglia Obsolete Guru
'67 Heaven
j-dub
« Reply #38 on: May 21, 2010, 04:38:49 am »
Zach,
If you want to practice I have some shrouds you can use.
« Last Edit: May 21, 2010, 04:40:26 am by j-dub » Logged
« Reply #39 on: May 21, 2010, 06:28:30 am »
Zach,
Thanks, I already welded up the shroud for AssHull's car (well most of it, at least). It's a lot of work!
Pages: 1 [2] Print
