September 29, 2026, 15:33:14 pm
good start ???
Topic: good start ??? (Read 75166 times)
Re: good start ???
Reply #30 on:
December 07, 2009, 15:28:12 pm »
Quote from: speedwell on December 06, 2009, 23:07:31 pm
Quote from: Zach Gomulka on July 30, 2009, 22:21:26 pm
92x74 (1968cc) would be different. Lot's of those built back in the day
yes thinking about that displacement , what do you think about the NPR /deano 92mm kit , i've just buy an NOS set of those one
Hi Fabs I noticed the Box On your Pistons says 40 HP Only?? NPR/Deano did make 92's for a 40 Hp I think the Difference is the Wrist Pin Size or the Placement of the wrist pin hole in the Piston if so they wont fit a 1600 up Rod Anyone Else know for sure?
Re: good start ???
Reply #31 on:
December 07, 2009, 15:42:59 pm »
Quote from: Shubee2 (DSK) on December 07, 2009, 15:28:12 pm
gary ,the Pins are 20mm
Re: good start ???
Reply #32 on:
December 07, 2009, 15:48:08 pm »
Quote from: 63 ripper on December 07, 2009, 11:44:51 am
Quote from: speedwell on September 24, 2009, 13:16:15 pm
with that kind of fan shroud , the 48 touch the fanhousing is normal
, i will use the 30 hp fan housing , and as it's describe in another tread to modify this one , and also the sheet steels cylinder , will be modify too, where the manifold goes on the heads
thx
fabs
Hi Fabs. it looks like your short manifolds are causing the carbs to touch the fanshroud. if you keep your carbs the way they are facing then i think it will be a real pain to set the mixture screws at the back. but it looks from the photos that if you reverse the carbs then the float bowl and fuel banjo will get in the way....the 30 hp shroud does give you a lot more room....
hy max
i will go with a 30hp fan shroud , and for reversing the carbs it's iimpossible with those manifold same as the dds , the mixture screw are inside with those , and i've watching several pictures with those manifold , and all are the same
fabs
63 ripper
Re: good start ???
Reply #33 on:
December 07, 2009, 17:40:10 pm »
that's cool. i have never really looked at any period manifolds so something new learned there
p.s i vote for 2007cc
JG54
Re: good start ???
Reply #34 on:
December 07, 2009, 17:45:30 pm »
no off the shelf parts
same issue here fabs, had a look this morning and a 30hp shroud gives some nice clearance.
DVK ~
63 ripper
Re: good start ???
Reply #35 on:
December 07, 2009, 17:56:30 pm »
Quote from: 67-indeed/DVK on December 07, 2009, 17:45:30 pm
quick ! hide the torkers
JG54
Re: good start ???
Reply #36 on:
December 07, 2009, 18:26:30 pm »
hehe
DVK ~
Re: good start ???
Reply #37 on:
December 07, 2009, 18:41:47 pm »
those NPR 92's leak down out of the box new. Nice to look @ but I wouldn't run them.
I'd suggest a 94 x 78 fabs, simple to build, fast, nobdy can "see" what size the motor is. use an OEM stale air 40HP fan housing, like Jim Edmiston's.
Re: good start ???
Reply #38 on:
December 07, 2009, 20:54:30 pm »
Quote from: The Other One on December 07, 2009, 18:41:47 pm
why
thx
not the same as an 30hp
there's a dog house isn the 40hp
jim 've a30hp with 40hp dog house
Last Edit: December 07, 2009, 21:02:49 pm by speedwell
Re: good start ???
Reply #39 on:
December 07, 2009, 21:00:06 pm »
Quote from: speedwell on December 07, 2009, 20:54:30 pm
why
anobody here doesn't know how to say why
thx
they do not seal rings to wall very well. Use Mahle 94mm
Re: good start ???
Reply #40 on:
December 07, 2009, 21:59:17 pm »
Quote from: The Other One on December 07, 2009, 21:00:06 pm
Why is that? Can it be corrected with a good hone/cross hatch? Or different rings? I've got a set of NOS Biral NPR 92's that I'm planning to use... someday
Re: good start ???
Reply #41 on:
December 07, 2009, 22:05:11 pm »
to late jim , now i've buy them
i will use them , the engine will be for a street use ,and " may be" sometime on dragstrip
Re: good start ???
Reply #42 on:
December 07, 2009, 22:12:50 pm »
Quote from: speedwell on December 07, 2009, 22:05:11 pm
sorry, bro, but they'd be better for a short lived drag motor, but not for a streeter you need long term power from. The cylinders do not stay round. MAYBE in a real mild, low-state-of-tune (read: low CR, generous overlap, low lift) motor they might live a bit.
Lots of horror stories from old days @ Buggy House about those. Big Frank tried
giving
me a set for my street car, I said "no thank you"
xavier
Re: good start ???
Reply #43 on:
December 08, 2009, 12:58:55 pm »
Is it true for all NPR kits? Or just 92's?
I was thinking of purchasing a set of 90's...
Thank you.
xavier
Re: good start ???
Reply #44 on:
December 08, 2009, 23:34:47 pm »
Jim didnt they also make a thick wall 92 back in the day ? Or was it just low grade casting material from npr cylinders ?
jimi323
Re: good start ???
Reply #45 on:
December 09, 2009, 13:32:22 pm »
Good work fab...
i like your early berg linkage...mine is just ready to be paint..
and i'm tring to re-make the gene berg sticker..
ps i like your" performing paper heads" in photo
Re: good start ???
Reply #46 on:
December 09, 2009, 16:39:30 pm »
Carsten
Re: good start ???
Reply #47 on:
December 10, 2009, 08:35:31 am »
Quote from: speedwell on December 09, 2009, 16:39:30 pm
Mounting the IDA`s that way is no problem ! I used early short Berg manifolds and had to work only a little at the fanhousing... Any more questions... Just ask ;-)
Greets , Carsten
1969 IRS bug
kingsburgphil
Re: good start ???
Reply #48 on:
December 10, 2009, 10:36:38 am »
Quote from: The Other One on December 07, 2009, 22:12:50 pm
giving
The ISS 92's were even worse, as I recall. If you wanted reliable
p&c then, you used 88's, the variety depended on your budget. 89's were reserved for the go fast guys and when 90's came out you went looking for a sponsor.
Re: good start ???
Reply #49 on:
December 10, 2009, 19:37:55 pm »
Quote from: speedwell on December 07, 2009, 15:42:59 pm
Gary ,the Pins are 20mm
try the pin in a 1600 rod!! I also Agree with Jim they are better Left On the Shelf, I would use a Cima or Mahle's and build something fast that will last why build something that know will puke oil to start with add them to your collection and use the good stuff you will be glad you did.
Last Edit: December 10, 2009, 19:47:13 pm by Shubee2 (DSK)
Re: good start ???
Reply #50 on:
December 11, 2009, 17:00:58 pm »
Quote from: Shubee2 (DSK) on December 10, 2009, 19:37:55 pm
don't want something to put on a shelf
, i want something to put on my engine without future problems
, no problem i will sell those one in a swap meet may be some one would add a nice set of npr on is shelf
Re: good start ???
Reply #51 on:
December 11, 2009, 17:28:22 pm »
cylinder wall to ring seal is one of the most important facotrs in a good motor, Fabs. Just trying to be helpful, like the blue Honda commercial guy.
Re: good start ???
Reply #52 on:
August 08, 2010, 12:20:19 pm »
new parts for the future engine
Re: good start ???
Reply #53 on:
August 08, 2010, 12:27:09 pm »
what about this displacement 2110 cc
90.5 BORE 82 MM STROKE
CHEVY ROD JOURNALS
SCAT CHROMOLY 3/8" BOLTS
FOR THE STREET USE A 120 CAM LIKE BUNCH HAS
FOR A LITTLE MORE POWER USE A 130 CAM
8.5:1
40 X 35.5 VALVE SIZE
STOCK ROCKERS WITH 911S ADJUSTER SCREWS
DUAL VALVE SPRINGS
CRANK BY BUGPACK OR SCAT
TYPE 4 MAINS WITH BMW BEARINGS
THATS ALL FOR NOW
RON
Last Edit: August 08, 2010, 12:29:01 pm by speedwell
Re: good start ???
Reply #54 on:
August 08, 2010, 12:44:09 pm »
yesterday i checked my 48 ida n ad would like to know what kind of idle jet and other stuff there's into the carb
can some one describe me what parts is/name
sorry for my ignorance
But I made the effort to look at every part, and to note the references of those one
this how my 48 where jetting when i 've buy them 10 years ago
Last Edit: August 08, 2010, 12:46:39 pm by speedwell
Re: good start ???
Reply #55 on:
August 08, 2010, 12:50:32 pm »
can we change those parts too
Re: good start ???
Reply #56 on:
August 13, 2010, 21:04:29 pm »
no one can help me to named the parts from the 48 ida
Re: good start ???
Reply #57 on:
August 13, 2010, 21:10:15 pm »
i suppose that my idles are this
but what 're the mains and air correctors on this pictures
thx for my education
Last Edit: August 13, 2010, 21:13:46 pm by speedwell
Brother Lovedub
Re: good start ???
Reply #58 on:
August 13, 2010, 23:41:51 pm »
50ew - Pump jets
F9 emulsion tubes
175 mains
160 air correctors
50 f8 idles
120 Idle airs
Good exploded diagram here.....
http://www.dellorto.co.uk/editor/uploads/images/ida48.pdf
Brother Lovedub
Re: good start ???
Reply #59 on:
August 13, 2010, 23:45:59 pm »
Check your venturis as well, you'll see a number when you look down the throat of the intake - with your spec you should be running 37mm, anything bigger will run like a bugger
