September 21, 2026, 17:41:40 pm
Off Topic
If you had a full on Porsche 912 engine for sale?
Topic: If you had a full on Porsche 912 engine for sale? (Read 7364 times)
January 20, 2007, 01:36:24 am »
Where would you sell it?
We got this fully built TURBO 912 engine in our workshop, and we want to sell it on. Its a 1720 with all the bells and whistles, won best engine at BugRun in 99 and used only at special occasions since. Its fully, and I DO mean FULLY documented, and if the receipts is anything to go by, most of the parts must be made of gold!!
Who needs such a engine? Could be sold without the turbo stuff as a long-block.
This is the basics:
1720 ccm
86.04mm bore (original cylinders)
74mm stroke
Counterweighted crankshaft (balanced with flywheel and pressure-plate)
Rods are rebuilt and lightly polished
Camshaft is grinded for turbo use
Flywheel original is 180mm, but has been milled up to 200mm and lightened to SC spec.
7.93:1 compression
Shasta design/JE forged pistons (street version)
Rebuilt heads and internals
All new Elring gaskets
Everything that has been done is documented: bearing numbers, tolerances and calculations
Comes with the engine plate from the car
Engine data:
Engine number: 48989215
Case 616/xx number: 616/33-1
Case casting number: 120511
Case matching number: 743
Literature used:
Harry Pellow: Secrets of the inner circle + The Maestro`s Workshop Manual / The ABC of porsche engines.
Duane Spencer: 356 Performance Handbook
Autobooks: Porsche 356 Owners manual
Frank LUX
Back...Soon...hopefully!!!
Re: If you had a full on Porsche 912 engine for sale?
January 20, 2007, 11:16:49 am »
Put it on the Samba...
Frank
March 31, 2007, 13:03:41 pm »
Sold the long block yesterday... $2300 someone got a CHEAP engine!
