September 30, 2026, 14:41:40 pm
| | |-+  66 Driver Status
Pages: 1 [2] 3 4 Print
Author Topic: 66 Driver Status  (Read 90317 times)
« Reply #30 on: August 13, 2009, 04:26:22 am »
That seat material is TOO COOL with the colored door cards.  Bet'cha that was a beauty when it was new.  Not that it looks bad now...you know what I mean...
OgCalLook
Straight outa Riverside!
« Reply #31 on: August 13, 2009, 04:47:40 am »
Yeah - I'm always amazed with Volkswagen's color combos.
It'll pop with a fresh Interior, someday $$$
Tom Hewitson
Bahama Blau Kafer
Zach Gomulka: "California Look is walking softly and carrying a big fucking stick."
« Reply #32 on: August 13, 2009, 06:39:06 am »
I agree with Mike on your interior, Tom.. VERY unique/cool/and factory. Two thumbs up. It's gonna look really nice when you freshen it up.
Sam K
« Reply #33 on: August 13, 2009, 14:54:54 pm »
I think that I have a set of merged daul QP's in the garage if you're interested.
I'm gonna be using a Bugpack merged - 1 clock flange - Is it at home or the shop?
It's at home. I think I had them on my Bugpack 1 5/8 system.
OgCalLook
« Reply #34 on: August 13, 2009, 15:28:10 pm »
Thanks Mark, I was thinking about straight green vinyl, but like you said its a "unique" interior, so it will get done OEM.
Tom Hewitson
Bahama Blau Kafer
beetletom
« Reply #35 on: August 13, 2009, 18:12:23 pm »
seriously cool!!  Cool
are you going to keep the green vinyl, but just replace the material?
lawrence
« Reply #36 on: August 13, 2009, 20:44:37 pm »
I love the color combinations that VW had then; especially the all the cloth interior stuff that is not common in US delivered cars.
"Happiness is a Hot VW!"
OgCalLook
« Reply #37 on: August 14, 2009, 14:56:28 pm »
If we can, For sure, but I'll leave that up to the trim guy.
The door panels are nice, maybe just re-glue the driver door.
New Headliner, and new square weave rugs.
Tom Hewitson
Bahama Blau Kafer
OgCalLook
« Reply #38 on: September 27, 2009, 17:38:17 pm »
Busy with other shit  Angry Now back to work on the 66  Grin
1915 ready to assemble. Hung the rods, Crank is ready to go.
Gonna set the cam thrust and short block it Today!
I'll post some more pics tomorrow......
Tom Hewitson
Bahama Blau Kafer
OgCalLook
« Reply #39 on: September 29, 2009, 00:10:27 am »
69mm DeMello crank/Engle 120
Tom Hewitson
Bahama Blau Kafer
lawrence
« Reply #40 on: October 01, 2009, 01:17:14 am »
1914 is a great engine, Tom. I have one in my car and its a blast to drive. So what are your complete engine specs?
OgCalLook
« Reply #41 on: October 01, 2009, 06:54:00 am »
DMS C/W crank
120 cam
CB straight cut cam gears
26mm Shadeck pump
311b VW rods torqued to 30lbs
M12 Case studs torqued to 30lbs
12lb 6 volt 200mm flywheel
10mm stock head studs
Rotating assembly dynamically balanced
94mm Mahle P&C
Tims stage 2 ported 043s Heads (42x37.5) 53cc
Big Beef match ported intakes
.050" deck 9.0 to 1 CR
Manton cm pushrods
CB solid rocker shafts
Stock 1.1 rockers (for now)
Berg Full flow & 1.5 sump
Berg breather, Vented Valve Covers
Berg carb linkage
ALL GERMAN COOLING TIN...!!
1-5/8 ceramic coated merged header
48 IDAs 37mm vents
Not too worried about top end with the tims' heads, (Intakes flow 190CFM @ 25")
but I do want decent torque, so I went with non-welded ports, tall manifolds and 37mm chokes, It should make good port velocity.
Its short blocked now, gonna set the deck height next Smiley
Tom Hewitson
Bahama Blau Kafer
« Reply #42 on: October 01, 2009, 16:51:50 pm »
If you plan on upgrading to 1.25's, just do it now. No sense in doing geometry twice! Looks exactly like AssHull's motor, except your heads are better. Should be a runner!
Fritter
« Reply #43 on: October 01, 2009, 18:18:01 pm »
Nice motor specs ogcallook
Mike F.
'64 Indigo Blue sunroof Bug
OgCalLook
« Reply #44 on: October 02, 2009, 03:39:33 am »
Your right Zach - just more $$$$ oh well Smiley
120 w/1.25s will give me .496" lift
1/2" of lift - that'll work!!
Tom Hewitson
Bahama Blau Kafer
58vw
« Reply #45 on: October 16, 2009, 05:48:08 am »
lookin good...love  the colors Grin
www.4inbore.com
Angleflows...order them now
OgCalLook
« Reply #46 on: October 18, 2009, 19:26:03 pm »
Thanks man!!
Tom Hewitson
Bahama Blau Kafer
Fritter
« Reply #47 on: October 18, 2009, 20:18:47 pm »
What tire sizes are you running?
Looks great. Love the interior.
Mike F.
OgCalLook
« Reply #48 on: October 18, 2009, 21:05:03 pm »
Thanks Mike! 145/165 on 4.5" 356s.
Thinking about 155/60s on the front  & 185/65s on the rear - something a little stiffer - I tend to drive a little fast Grin
Tom Hewitson
Bahama Blau Kafer
Fritter
« Reply #49 on: October 18, 2009, 21:33:40 pm »
Cool. What brand and model of tires are they? I had 145 and 165 coker xzx's on my old '65 and they were great but I'm looking for a cheaper option for the same sizes for my current '64 project.
Mike F.
OgCalLook
« Reply #50 on: October 18, 2009, 21:47:16 pm »
the 165s are old XZXs from the 80s-90s (good tread but a little weather checked) - which reminds me I need to swap them, before I kill myself.
the 145s are run of the mill nankangs.
I'm seriously considering the Conti's
Tom Hewitson
Bahama Blau Kafer
lawrence
« Reply #51 on: October 19, 2009, 18:51:43 pm »
I like the 185/65 Contiprocontacts that i have on my car. Tom, I bet the 155/60s would not look good because they have a small diameter and are more suited to the hoodride/airbag cars. 175/65s would probably look much better as they are almost identical to 145s but wider.
OgCalLook
« Reply #52 on: October 19, 2009, 21:18:11 pm »
I hear ya, I still like the big and little setup. Do your 185/65s fit the 4.5 rim ok? bulge?
155/60s are 22.3" according to - http://www.rims-n-tires.com/rt_specs.jsp - and I would have to lower the front some more.
I think I'll start with 185/65s on the back since the ZXZs have seen better days, and keep it open for the fronts.
Heres follow Lounger "allmenplayon10"s car with 145/65s but he's sitting pretty low, this is why I was thinking 155s might fit "straight" on the 4.5 with no bulge.
« Last Edit: October 19, 2009, 21:20:01 pm by OgCalLook » Logged
Tom Hewitson
Bahama Blau Kafer
« Reply #53 on: October 19, 2009, 22:15:50 pm »
How about the Vredesteins in 155's for the front, and 185/70 for the rear? The 185/65 is a bit short, IMO, and the 185/70 is about the same height as a 165. I normally don't like the look of those tires, but I think the sizes would work perfectly on your car, and the tread would match front to rear. They would fit 4.5's and 5.5's beautifully.
OgCalLook
« Reply #54 on: October 19, 2009, 22:55:07 pm »
Yeah 185/70s would be my preference, (rear wheels are 4.5s - they have 1" more offset than the fronts ) so I think a 185 is as large as I should go.
Is this where you were thinking? (Nice but pricey) http://www.lucasclassictires.com/RADIALS070609.htm
Tom Hewitson
Bahama Blau Kafer
« Reply #55 on: October 20, 2009, 00:48:42 am »
That's not too bad... comes out to $452 for all four. Cheaper than a set of XZX's.
OgCalLook
« Reply #56 on: November 29, 2010, 08:07:26 am »
Wow - Its been over a year since I posted last......
I'm in Commercial construction, so 2009 was dead (no $$) This year we're slammed (no time) Grin
As the thread title says "Driver Status" so I drove it all last year, hit all the local shows.
Got the funds now, so with winter here, its time to get the new motor running.
« Last Edit: November 29, 2010, 08:09:07 am by OgCalLook » Logged
Tom Hewitson
Bahama Blau Kafer
OgCalLook
« Reply #57 on: November 29, 2010, 08:13:59 am »
Just got the motor in tonight, still have to hook up everything..... but Im stoked to have it installed.
Couple of evenings this week and It'll be ready to fire.
« Last Edit: November 29, 2010, 15:16:27 pm by OgCalLook » Logged
Tom Hewitson
Bahama Blau Kafer
« Reply #58 on: November 29, 2010, 14:35:14 pm »
Lookin' good, Tom.  As if that car isn't cool enough...  Cool
« Reply #59 on: November 29, 2010, 17:38:46 pm »
Damn that looks great!! Shocked
