September 22, 2026, 05:57:47 am
| | |-+  51 er Dragstyler Swissversion
Pages: 1 [2] 3 Print
Author Topic: 51 er Dragstyler Swissversion  (Read 75099 times)
TOM / EINHEIT 11
« Reply #30 on: June 01, 2010, 10:51:53 am »
ready to rumbbbbbbble  Tongue
brezel
« Reply #31 on: June 10, 2010, 10:04:40 am »
desaster of the weekend at Bitburg
before the first qualifying
is the motor died
probably too low backlash
last year at the drag day supply it better
« Last Edit: June 10, 2010, 10:07:23 am by brezel » Logged
13.331 June 2012 Bitburg / 13 B Rotary N/A
12.188 Sept 2012 Bitburg / 13 B Rotary N/A
11.599 Sept 2013 Bitburg / 13 B Bridge Port N/A
brezel
« Reply #32 on: September 08, 2010, 13:12:38 pm »
engine assemble for Bitburg at DD#8
1835 low cost engine
« Last Edit: September 08, 2010, 13:18:28 pm by brezel » Logged
brezel
« Reply #33 on: September 08, 2010, 13:14:19 pm »
more pics  Wink
brezel
« Reply #34 on: September 09, 2010, 06:53:49 am »
last night in the workshop
xbacax
« Reply #35 on: September 26, 2010, 13:09:47 pm »
and how the work is goin with the new engine ? Wink
I just love this car man Cheesy
brezel
« Reply #36 on: October 01, 2010, 08:54:24 am »
We had unfortunately an oil leaking that we could not repair in the event
Full flow port on the housing with mega oil pressure
work until 2011 bitbug must
but a 17 082 mile to the 1 / 4 with the 1192 cc race motor
« Last Edit: October 01, 2010, 08:57:26 am by brezel » Logged
brezel
« Reply #37 on: May 26, 2011, 08:12:31 am »
a new season comes
bitbug on 3-5 June
many new things at SBJ
fiberglass fenders, fiberglass front hood
lexan windows @ all  Cool
urethane rear axle bearing
bolts whit nuts and 20 mm spacers
215/65-15 M & H dot slicks
Transmission:
Built by Kenneth Chunning:
Rhino Case of VW bus Brasil
Erco + FTC "gears,
synchronizer rings welded,
chromoly pinion retainer ring,
steel shift fork,
Alu side cover,
Jaycee aluminum spool 100%
Diff 4125
1.G 3.78
2.G 2:21
3.G 1:56
4.G 1:16
Engine: 1835 cc
AS drilled 41 housing, full flow
69  original crankshaft
92  forged Mahle graphite coated piston a zyl.
Connecting rod from Formula V Polished and only 550 gr. wight
Racing gr. 58 gr. witzemann
Engle W 130 with strait cut gears
Original pushrods polised
VW heads 040 with 40 x 35.5 valves,
Ampcoloy seat inserts with 3 angle cut,
Manley valves,
scat springs,
lightwihgt Titanium Retainer,
Comp.  10.5:1 with 1.3 PR
Custom intake manifolds
40 Empi mphx / 48 Ida Soon  Grin
AJ Sims 1 3 / 4 headers with O2 sensor connection and vacuum connection
123 Ignition Distributor / or 009 with compufire
Relieved and polished original rocker arm bolted to shaft
we test on June 4 - 5 in the bitbug bitburg
and hope for a 15 s / 1 / 4 mile;-)
ttp://www.1on1-motorsports.de
« Last Edit: May 26, 2011, 08:30:47 am by brezel » Logged
Type1/DVK
« Reply #38 on: May 26, 2011, 17:40:01 pm »
15'sec is 100% possible with that setup, i've ran a 14,7sec with stock floor and 1776cc IDA engine.
brezel
« Reply #39 on: May 31, 2011, 09:07:16 am »
I am working hard for the 15 s
the first 400 km the engine now running on the streets and this has survived without problems
in the 1302's by my woman   Grin
with a nice 34 mm single carburetor and 35 mm  bugpack header
but has served to destroy the gearbox bearing   Cool Cool
« Last Edit: May 31, 2011, 09:14:18 am by brezel » Logged
brezel
« Reply #40 on: June 07, 2011, 10:43:56 am »
already destroyed something  Angry
test run on Friday in Bitburg  Embarrassed
Zack and pulled down the drive shaft  Undecided
then in the slalom on the strip and at the 1 / 4 meter photocell still 72.82 mph  Shocked
still a cool weekend
I'll be back
At DDD#9 in Bitburg Sept. 2011
« Last Edit: June 07, 2011, 10:59:27 am by brezel » Logged
brezel
« Reply #41 on: June 17, 2011, 08:44:04 am »
New parts from USA  Grin
nice to see
I hope that now everything is strong enough
for my 50 hp +   Cool
brezel
« Reply #42 on: September 15, 2011, 09:49:54 am »
New parts on the styler ;-)
afther destroyed the flywheel during test runs
with a new flywheel and stronger starter
48 ida copies of Empi
hop to das drag day # 9 Bitburg  Huh
and the car has the first 15 sec pass   fingercross    Cool
« Last Edit: September 15, 2011, 09:53:47 am by brezel » Logged
SPRasmussen
ET 10,54 - 197,65 at SCC 2011
« Reply #43 on: September 15, 2011, 10:17:22 am »
Where is the fiberglas hood from ? :-)
Søren Rasmussen
Owner of The Ultra Rat
www.TeamAngoraRacing.dk
brezel
« Reply #44 on: September 15, 2011, 14:21:56 pm »
The fiberglass hood is homemade and has 3 kg
« Last Edit: September 15, 2011, 14:28:08 pm by brezel » Logged
Mirco Jufer
« Reply #45 on: September 17, 2011, 07:05:33 am »
Do you also make decklids?
Best regards  Wink
SPRasmussen
« Reply #46 on: September 17, 2011, 10:19:16 am »
How much do you what for one of those :-)
Søren Rasmussen
brezel
« Reply #47 on: September 21, 2011, 08:12:09 am »
material cost about 100 € (from fiberglass boat builder)
time about 1 hr
almost everything is possible
everyone can
it's not as nice as the photos  Grin  see it yourself in Bitburg
brezel
« Reply #48 on: September 26, 2011, 20:58:47 pm »
a great we in bitburg
a new pers best et
R/T 0.170
60 ft 1.743
594 ` 7.986
1/8 ET 8.552
1/8 MPH 79.51
1000 ` 11.227
1254 ` 13.065
1/4 ET 13.532
1/4 MPH 96.36
1835 ccm
60 ft     1.797    1.906    1.843    1.881
1/8       8.550   8.674     8.552    8.575
1/4      13.575   13.758   13.532   13.554
rollout i.o. :-)
« Last Edit: October 03, 2011, 11:25:07 am by brezel » Logged
Richyrich
« Reply #49 on: October 11, 2011, 03:28:37 am »
Just Loving this buildup, so cool....
brezel
« Reply #50 on: October 11, 2011, 06:55:28 am »
thx
it can just be built only if there is money again  Embarrassed Angry
I have so many ideas
Richyrich
« Reply #51 on: October 12, 2011, 00:20:31 am »
Yes mine is only in my Head at the moment, Waiting on the Money, Will do it in one, not a long Build. But your car is what is in my head, But manly on the road, as my good friend BlackSheep said, Less is more....  Grin
johnbitch
« Reply #52 on: October 12, 2011, 20:30:20 pm »
Michi, you know what?
Love your car & love your sick thoughts.
One day we will stand side by side in Gadermoen, if we pass tech spec Wink
« Last Edit: October 12, 2011, 21:07:16 pm by johnbitch » Logged
love speed - hate people
brezel
« Reply #53 on: October 13, 2011, 10:02:21 am »
hi friend bitchi  Wink
Gardemon is a big target  Cheesy I want to watch in 2012
dream is there to be even with a fast car   Cool      a really fast car      Grin Grin
brezel
« Reply #54 on: August 16, 2012, 09:10:34 am »
June 2012 Bitbug in Bitburg
R/T -.154
60 ft 1.089
594 ` 7.901
1/8 ET 8.443
1/8 MPH 83.03
1000 ` 11.068
1254 ` 12.863
1/4 ET 13.331
1/4 MPH 96.15
brezel
« Reply #55 on: August 16, 2012, 09:22:14 am »
R/T -.154
60 ft 1.089
594 ` 7.901
1/8 ET 8.443
1/8 MPH 83.03
1000 ` 11.068
1254 ` 12.863
1/4 ET 13.331
1/4 MPH 96.15
« Reply #56 on: August 16, 2012, 10:05:05 am »
R/T -.154
60 ft 1.089
594 ` 7.901
1/8 ET 8.443
1/8 MPH 83.03
1000 ` 11.068
1254 ` 12.863
1/4 ET 13.331
1/4 MPH 96.15
Sorry, but I highly doubt the 1.089 60ft.
brezel
« Reply #57 on: August 16, 2012, 10:31:20 am »
I think it's not too
 only as read
« Last Edit: August 16, 2012, 10:50:55 am by brezel » Logged
magic
« Reply #58 on: August 16, 2012, 12:21:03 pm »
Hey Brezel.
Really dig your car! Cool.... and lever. Have wondered whether I should buy one myself. It seems to be a serious piece of German engineering! ...
 how is it to use? Have you extended it? Please, give us a review!?  Smiley
cheers, magic.
brezel
« Reply #59 on: September 25, 2012, 07:01:50 am »
a good weekend is over
a best personal ET
unfortunately, after about 350 meters the battery passed and I had to roll out without ignition
the 11 is almost possible
Sep 2012 Das Drag Day No. 10 Bitburg
R/T 0.257
60 ft 1.619
594 ` 7.145
1/8 ET 7.642
1/8 MPH 90.54
1000 ` 10.068
1254 ` 11.757
1/4 ET 12.188
1/4 MPH 104.41
