September 19, 2026, 02:06:50 am
Bad Habit
The 4" Bore Thread
Topic: The 4" Bore Thread (Read 598005 times)
The 4" Bore Thread
August 25, 2009, 17:48:50 pm »
Looks like the last topic I posted was a victim of the forum crash, so here we go again...
All this talk about 4" bore motors has got mine and a lot of other heads spinning, and I want some answers!
Do you
have
to use an aluminium case? What modifications are needed?
Are they truely streetable/highway-able? Not just good for a weekend plaything! I'm talking much more than just around town...
What heads can be used? Hopefully something with more than 6
thick
fins...
Can a normal fanshroud and cylinder tins be fitted? I hate those Porsche look-a-likes...
Where do you get pistons & cylinders? Are the pistons only available in one pin height? Slipper skirts? Cylinders in one length?
Who has a 4" bore motor out there? Please share your experiences!
Re: The 4" Bore Thread
August 25, 2009, 18:01:14 pm »
Quote from: Zach Gomulka on August 25, 2009, 17:48:50 pm
Do you
have
Not if you know somone that can weld a stock case.
thick
fins...
JPM' ms230 has 4" as a option... 9 machined (thin) fins...
Jesus
August 25, 2009, 18:16:40 pm »
i was told of a 4inchbore website but can't find it?
Thanks Alex
August 25, 2009, 18:32:49 pm »
Quote from: Jesus on August 25, 2009, 18:16:40 pm
Thanks Alex
http://4inbore.com/
71CALRIPPER
August 25, 2009, 19:18:29 pm »
Cant wait for mine
Roman
August 25, 2009, 19:30:33 pm »
The easiest way is just call CB and ask for a blank head stud case. They usually have a bunch on stock.
It is clearanced for stroke, but has stock bore and no head stud holes.
-When you recieve it, just pull out the dip stick tube, weld some on #3 cylinder behind the dip stick.
-Next step is to fill the oil passage between the #3 and #4. Bore it smooth and make a rod in a lathe and fill the hole with it.
It needs some kind of fixation for the rod. Use your welder, loctite or your imagination, whatever works best for you...
-Next step is to bore the holes for the case savers and installl them. I used Würth Time sert.
-Next step is to bore the holes for the cylinders.
The case is done!
I have AA cylinders that works alright in an N/A config, but I wouldn't use them with a turbo.
I have custom CP pistons of my own design. It is the third set now and it gets better every time, even though they weren't bad the first time. My own design is a lot lighter than a 94 mm Mahle, but yet rated for 350 hp/9000 rpm.
Chevy etc pistons might work, but they aren't that good for a VW as they have the wrong pin size etc.
Ford pistons have the valve reliefs on the wrong place.
There is two options for heads as far as I know: JPM and modified Angle flow.
JPM needs no modification, but on the other hand it is more expensive.
The JPM head has more cooling fins if you want to run on the street.
It is possible to use a mag case, with steel plates etc, but it is a LOT of work. You can also modify a Water boxer case, but it is a lot of work too.
Pitcures below:
Top: Welded case, machined flat
Second: Milling for case savers
Third: milling for cylinder holes. One to go!
Fourth: Done! 94 mm case to the left.
Last Edit: August 25, 2009, 19:34:38 pm by Roman
ugly duckling
August 26, 2009, 00:45:03 am »
here is one of my six stud cases zach . i had a nice little parigrf about my experiance but got kicked off becase im a slow typer so i will try later after dinner.JD .
Last Edit: August 26, 2009, 01:03:19 am by ugly duckling
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
ugly duckling
August 26, 2009, 01:31:53 am »
are they werthy of true street diving. yes sir. i will put my reputation on the line with out any doubts and say they are very very worthey. i would think that you and many others would already know this. they are worthey on even the crap gas you get at the pump. zach my original engine 3066cc i used the weaker case and crank (LOW DECK CASE AND 92 MM NON 411 MAIN CRANK) .after i toar the engine down for inspection i notice a hair line crack in it i wonder why ::)i new it was weak but hey somebodys got to try it right. so then i put a 411 90mm. still using the weaker low deck case. did i ever put 5000 miles on it like you ask? more i would say . but since the engine was in the infant state i couldent keep my hands off the thing so i would tear it down from time to time to see how things were wearing ( R D) and parts always looked great so it was back together. now that we have the better cases RASID DECK now the true relibility begins (THICKER). i drove my car in 100+heat in bumper to bumper traffic hiway freeway you name it. it was done .race and street worthy by far. i would not hesitate to even put another low deck 101 engine together for my self or a customer knowing what i have learend how to keep them alive .build one you wont be sorry that you did . UD .
Last Edit: August 26, 2009, 02:05:39 am by ugly duckling
www.dprmachine.com
www.4inbore.com
John Rayburn
August 26, 2009, 02:45:03 am »
I also park at Nick's.
ugly duckling
August 26, 2009, 04:12:03 am »
thanks for that Jhon boy.
www.dprmachine.com
www.4inbore.com
ugly duckling
August 26, 2009, 04:30:52 am »
steve dalton another guy that has the experience on the subject. he had a few speed bumps that he had to drive over but as far as i know his old blue is a relible STRONG runner and is drivin often . and another big bore fanatic is the one and only don pauter he has many street big bore miles under his belt. truly respectilble. and we cant forget rockey jennings. so yes there are many. UD .
www.dprmachine.com
www.4inbore.com
Steve D.
August 26, 2009, 07:47:26 am »
Yup, I had a few hoops I had to jump through, but only because I tried a funky crank setup that took a little different approach to figure out. As for the 4" bore part of the equation, it's been nothing but smooth sailing. Only an 86 stroke here, but loads of HP and TQ all down low on the tach. I actually had a friend in a reputable car club drive my car a few weeks ago and when he got into his fantastic running 94mm car at the end of the night "It felt like it was broken." I haven't put as many miles on the car as Jeff has, but I'm catching up quickly
To back up the legitimacy of Jeff's big block motors, I was driving next to him as he drove the car to Irwindale, and when he went on the 100+ degree 60+ mile Vegas drive, and the motor actually ran cooler than a few of the 90.5 and 94 bore cars that made the same drive- food for thought.
Just remember, it wasn't long ago that people were saying the same things about 94 bore...
Über Alles
10.77 avg. on pump fuel.
238I
August 26, 2009, 16:08:30 pm »
What sort of cost is required to buy the basics; case, heads, barrel and pistons?
What length rod is needed?
Thinking about 82 x 103.
Does the crank need to be flanged?
ugly duckling
August 26, 2009, 16:35:57 pm »
lids. 82 crank just your reg por lenght or vw lenght 22 mm pin. no the crank does not need a flange unless you want to do it .steve and i have had great sucsess with reg dowel crank 11/32 dowel mate no wedge. drag race with slicks in 2000 lb bettels. UD .
www.dprmachine.com
www.4inbore.com
August 26, 2009, 16:53:26 pm »
My next engine. But I got to wear out the set of heads UD made for me first.
August 26, 2009, 17:12:44 pm »
Thanks Jeff, what about a rough idea on component costs.
SlingShot
August 26, 2009, 17:51:00 pm »
Not long ago I purchased a set of vintage 100mm Empi Birals. They were originally designed for the 914/T IV Engine. I was contemplating building a type 1 engine with these, but I'm not sure if they will work because the cylinders are 3/8-1/2in
shorter
than a type 1 cylinder. I think the added deck to the Alum case could make it all work out, what do you guys think??
Sorry for the mild Hijack Zach
Will Race For Beer !!!
August 26, 2009, 17:55:56 pm »
Quote from: Steve D. on August 26, 2009, 07:47:26 am
I was thinking the same thing. 94's came out in the late 70's I believe, but it wasn't until many years later where they finally got "street cred"
Hopefully we can look back on 4" bore motors the same way someday
cassa
August 26, 2009, 19:19:50 pm »
Easiest way out is tu use the waserboxer case with JPM heads no welding needed. has T4 registerbore/depth.
And is VW quality.
ugly duckling
August 27, 2009, 01:03:50 am »
yes the wasser boxer case is vw quailty i agree with you there. but is limited on stroke yes it has trhe studs in the location already if you can find one that you can remove the old head studs with out breakedge WATER DAMEDGE then cutting off the water jacket milling down. then the crank and bearing combontion. when it all comes down to it its just as much work to convert if not more headake than the autolina. just my two bits .UD .
www.dprmachine.com
www.4inbore.com
ugly duckling
August 27, 2009, 01:29:34 am »
here is a low deck that i finished today. its for sale or i will build it for my own personal use or will sell the engine when done complete or long block state. it is limited on comp i have run as much as 10.2 comp with no problems.this one has the new gusset system on it for that extra muscle.makes a bitchen street case for the lower comp pump gas guy . UD .
www.dprmachine.com
www.4inbore.com
August 27, 2009, 01:52:44 am »
I wanna see some of you SoCal guys drive your 4" motors to Vegas, Phoenix, Sacto, ect....
Steve D.
August 27, 2009, 06:42:33 am »
What does it matter? How many people actually drove their 94 bore motors to Vegas, Phoenix, Sacto, etc...?
I did Vegas four times and Sacto once with my old 94 bore motor, Phoenix never because I don't like Arizona. Point is, it will come around and it probably won't be too far off- I guess 250hp on California pump gas at low rpm through IDA's driving non-stop for an hour and a half through 100+ degree heat and stop and go traffic isn't enough reason for people to start building...
Über Alles
238I
karl h
August 27, 2009, 07:05:59 am »
i did two bigbore wasserboxer engines, one 96 bore one 101.6 bore. removing the headstuds can be a pain, just like jeff said. dont forget you have to bush the lifterbores for type 1 lifters (has hydraulic type4 stock) AND: you cant run a sump. it does have more oil capacity stock, but not enough i think
dont forget it has a factory sandseal, so not every pulley will fit
i did fir stock sheetmetal, but it has to be modified extensively, the case is much wider
oh yes: it has a stock oilfilter that cant be used with a merged header without mods, no just hooking up the full flow
i just bought two pentroofcases, seems like less work
do i have to weld at the no 2 cylinder spigot? didnt have to on the wasser case. and is the oil routing roman talked about different than with the wasser case?
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
58vw
August 27, 2009, 07:10:08 am »
i think jeff already did vegas from orange county....then won real street.....then drove home......
www.4inbore.com
Angleflows...order them now
58vw
August 27, 2009, 07:11:47 am »
nice pic karl
www.4inbore.com
August 27, 2009, 12:24:00 pm »
Quote from: Zach Gomulka on August 27, 2009, 01:52:44 am
Zach
Jeff drove his to vegas and back under the strict Real street rules with the rest of the guys,filling up with pump gas along with everyone else,running it hard at the track then driving home again,thats good enough for me,I have 2 pairs of angle flows sitting here waiting for Jeff to get some time to work on them
cheers richie,uk
cassa
August 27, 2009, 12:29:58 pm »
Quote from: ugly duckling on August 27, 2009, 01:03:50 am
I run a 86mm VW rod crank in my WBX-oxy case almost NO clearance needed. Only on the bumps under the studs.
Headstuds can be difficult, but I have not had any big problems, and its easier to remove when the waterjacket is removed.
Waterjackets is a Angle grinder job. and kind of fun!
No need to mill it down, I leave a edge for strength.
The Crank and bearing combo is the benefit! run the 76,4 crank with 4" and you have a 2,5L blast.
or use 1mm oversized +1mm trust bearings on the main and wbx on the others for new T-1 cranks.
The reason I like it, is that it is dooable for common people to convert these. No need for big machining equipment. and ok 2,1 wbx engines are kind of cheap. Then one can use the case and crank++. For the money one save, buy some GOOD heads.
The oil capacity is like 4 liters, IIRC. what is a T1 with normal deep sump?
Its not trouble free, but not that hard to manage. Only machining I have needed is the honing of the lifter bores.
my 2 cents
August 27, 2009, 12:46:07 pm »
Quote from: cassa on August 27, 2009, 12:29:58 pm
Just to answer your question; 4,5 - 5,5 liters.
Jeff68
Reply #29 on:
August 27, 2009, 14:03:05 pm »
All right, now I feel like I'm in the dark ages with my 2110 :-( This is great information. Thanks Zach for starting this post and Jeff D. for taking the initiative to put it on the street and R & D it and put this out there. Thanks for all who shared their experiences with doing this. Too bad the economy isn't doing so well or I'd bet there would be many ready to try and do this, I know I would. Maybe I'll take my motor apart (only 150 miles on it) sell the mag case, pistons and cyl's heads etc and go 4 inch.......This is cool stuff. Jeff R
