September 19, 2026, 06:03:23 am
352309 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  The 4" Bore Thread
Pages: 1 ... 8 9 [10] 11 12 ... 17 Print
Author Topic: The 4" Bore Thread  (Read 598262 times)
58vw
« Reply #270 on: December 24, 2012, 04:32:55 am »
for me?
sure!! i take paypal!! lol
www.4inbore.com
Angleflows...order them now
« Reply #271 on: December 24, 2012, 04:51:12 am »
what barrels are they fiatdude?
Those are the old ARPM Siamese barrels ---- Bugpak has the castings and several examples setting on the shelves
« Reply #272 on: December 24, 2012, 12:22:57 pm »
I think Kalle had angles in his NA engine?
That is correct. Very high compression in combination with special JE pistons made the engine extremely narrow even with 5.7" rods. I used a 2"  stepped custom exhaust based on a Berg system as well. It fitted without cutting in my old 65. Very fun engine, especially between 5000 and 10000 rpms  Smiley
Have a nice Xmas evening.
-BB-
Tobi/DFL
« Reply #273 on: December 25, 2012, 21:35:54 pm »
Hi,
reading all your experiences about those 4" engines I decided to build such an engine sometime as well so I bought an Limbach (aircraft) oxyboxer case some time ago. Nothing happened for a long time but recently I started collecting parts for that engine and started with modifying the crankcase. The plan is to do as much of the machine work by myself as I recently bought a milling machine and a lathe and want to learn machining engine parts.
Two weeks ago I started to clean the crankcase, remove the studs, drill and tap the oil galleries and bore the case for 4" AA cylinders.
I machined the case to 104.6/105.1mm and turned the cylinders down to 105.0mm at the case side.
At the moment I do not have all necessary parts to trial assemble the engine, yet but as soon as everything is here I will know how much to shorten the cylinders and will finish them.
As some of you asked for different engine combos, here is mine:
- late oxyboxer case
- DPR 86mm WBX crank
- 228mm flywheel
- 4" bore Wink using AA cylinders and 4" Keith Black Icon flat top pistons (1.09" compression height, lateral gas ports, 0.927 pin)
- rebushed CB H-beam rods, 5.6" length
- Thorsten Pieper tool steel lifters, 56gr. in modified aluminium bushings
- dual tapered aluminium pushrods
- custom grind camshaft with Magnum straight cut gears
- Thorsten Pieper CNC cylinder heads with lots of cooling fins
- stainless steel inlet valve 49-50mm (not quite sure, yet)
- exhaust valve 39.5mm, natrium (translation?) filled
- Crower valve springs/titanium retainers
- 50.5mm IDAs at first, fuel injection later
- header size probably 1 7/8", but thatīs not defined, yet
- dry sump
That engine will hopefully be very streetable with lots of torque as iīm sick of trailering my car to some quartermile races 2 or 3 times a year. Letīs see if I will achive my goal... Cool
Attached some pics of the parts and machine work so far. The pics donīt show my own heads but some with 46/39.5mm valves.
Tobi
« Last Edit: December 25, 2012, 21:50:13 pm by Tobi/DFL » Logged
Tobi/DFL
« Reply #274 on: December 25, 2012, 21:40:27 pm »
More pics...
Tobi
Tobi/DFL
« Reply #275 on: December 25, 2012, 21:46:01 pm »
More pics. Wink
Tobi
MeXX
« Reply #276 on: December 25, 2012, 23:56:45 pm »
Hi
Just found some pix from my version of a 4 inch street engine
Engine in the car
completed engine
Line bore after welding
cylinder instalation
Keep on 4 inching
MeXX
« Last Edit: December 26, 2012, 22:43:58 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #277 on: December 26, 2012, 00:03:20 am »
Some further pix
Inside the engine
OKRASA made in Germany
Crank modification
Roller cam cleared for rods
MeXX
« Last Edit: December 26, 2012, 22:44:27 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #278 on: December 26, 2012, 00:15:53 am »
Oil squirters
EFI meets NOS
Modified competition eliminators
Dry sump pump
MeXX
« Last Edit: December 26, 2012, 00:18:48 am by MeXX » Logged
Drag or Die
58vw
« Reply #279 on: December 26, 2012, 00:32:36 am »
nice stuff guys..
www.4inbore.com
Eddie DVK
« Reply #280 on: December 26, 2012, 02:59:39 am »
Hi
Keep on 4 inching
MeXX
Looks like those are 100mm porsche cilinders.
Are they
Very nice engine
Regards Edgar
Regards Edgar
MeXX
« Reply #281 on: December 26, 2012, 08:10:48 am »
Are they
Very nice engine
Regards Edgar
THX Edgar
The cylinders are OEM Porsche 993 GT3
the pistons are OEM Porsche 993 GT2 (Bi turbo)
The crank has 82,6mm stroke resulting in a displacement from 2595 ccm.
MeXX
« Last Edit: December 26, 2012, 09:16:09 am by MeXX » Logged
Drag or Die
MeXX
« Reply #282 on: December 26, 2012, 08:50:31 am »
Hi to all 4 inchers
Autolinea case prepaired for 4 inch & 6 studs
MeXX
Drag or Die
dangerous
« Reply #283 on: December 26, 2012, 08:59:19 am »
Very nice to see a good radii in the Autolinea case conversion.
Also very good idea with the roller conversion, and how you retained the roll pin that prevents the lifter from turning.
I also like the large radii in the inlet ports of the comp eliminators.
Thank you for sharing your work!
MeXX
« Reply #284 on: December 26, 2012, 09:02:25 am »
Hi
My kind of a 4 inch race engine
MeXX
Drag or Die
MeXX
« Reply #285 on: December 26, 2012, 09:06:28 am »
Hi
If you like my competition eliminators you will defenitely like my Autocraft 910.
BTY big THX to Mike from Autocraft.
MeXX
« Last Edit: December 26, 2012, 09:14:00 am by MeXX » Logged
Drag or Die
« Reply #286 on: December 26, 2012, 10:36:35 am »
- 228mm flywheel
- dry sump
Tobi
Thank you for sharing Tobi.
Have you done some calculations with regards to HP or have you bought and collected parts that you hope and think will work together and keep your fingers crossed that you will reach a certain goal? Is anyone for example using EA when building their 4" monsters?
Best rgs
BB
Eddie DVK
« Reply #287 on: December 26, 2012, 11:22:48 am »
Are they
Very nice engine
Regards Edgar
THX Edgar
MeXX
Ok cool, they are not cheap these days.
Regards Edgar
Regards Edgar
« Reply #288 on: December 26, 2012, 11:46:17 am »
Hi
MeXX
Hi mexx,
thats some very nice parts you have there,and the machine work looks real good,are you doing all your own machining? and is the head work all done by you?[porting etc? ] are those autocraft heads the same casting as CBs strip dominator?
cheers richie
Tobi/DFL
« Reply #289 on: December 26, 2012, 17:36:19 pm »
Best rgs
BB
Hi Kalle,
no certain hp goals to achieve. I hope to be able to run mid 12s and still have a very streetable engine.
That combination of parts will be trial and error.;-)
Tobi
Andy Sykes
« Reply #290 on: December 26, 2012, 18:28:36 pm »
Some very cool engines  Grin
MeXX
« Reply #291 on: December 26, 2012, 19:15:36 pm »
Hi mexx,
cheers richie
Hi Richie
THX for the more than kind words. I'm doing everything myself from concept to reality. I also do all the machining myself.
The heads were bare castings from Autocraft an were handported by me. Yes it took some time.
It is basically the same casting as CB strip dominator
MeXX
Drag or Die
MeXX
« Reply #292 on: December 26, 2012, 19:24:32 pm »
Hi
Some pix of my kind of valvetrain:
check out the straight push rods
left side
right side
MeXX
Drag or Die
Shag55
Shag Leone, SL-1racing
« Reply #293 on: December 26, 2012, 19:26:57 pm »
Very nice Mexx. I'd like to see your rocker set up.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
MeXX
« Reply #294 on: December 26, 2012, 19:32:56 pm »
Hi Shag
The rocker are Jesel one of J2K MoHawk 1.6 ratio
with home made individual stands made from 4340 CrMo.
MeXX
Drag or Die
MeXX
« Reply #295 on: December 26, 2012, 20:57:36 pm »
Tobi
Hi Tobi
I see that your things are coming together. Grin Grin
Are you happy with the KB pistons you got from Summit.
Post some pix .
I would be interested how you made your dry sump set up ??
what size are scavenge and pressure pump
how is the routing ?
mine is:
Stock pickup tube -  scavenge pump - oil filter - thermostat - oil cooler - dry sump tank - pressure pump - oil gallery
MeXX
« Last Edit: December 26, 2012, 21:00:09 pm by MeXX » Logged
Drag or Die
lecid
« Reply #296 on: December 26, 2012, 20:59:30 pm »
Waouw...Amazing job MeXX... Shocked
I'm a huge FAN of your job and project !!!
RedMamba Racing
MeXX
« Reply #297 on: December 26, 2012, 21:02:31 pm »
THX a lot
MeXX
Drag or Die
MeXX
« Reply #298 on: December 26, 2012, 21:05:39 pm »
Hi
Just started to built another 4 inch mill
MeXX
« Last Edit: December 26, 2012, 21:10:48 pm by MeXX » Logged
Drag or Die
Tobi/DFL
« Reply #299 on: December 26, 2012, 21:41:23 pm »
Hi Tobi
Post some pix .
mine is:
MeXX
Hi MeXX,
I could continue because of your parts, so thanks alot for your help!
The pistons are still in the USA at a friend of Mine who will bring them to Germany in his luggage when he will be on a business trip by the end of january. I will send some pics as soon as I have them here.
The TP dry sump pump usually has 26mm pressure and 38mm scavange gears but mine will be modified for 30mm pressure gears because I plan to install oil squirters as well and I'm afraid that the 26mm gears wouldn't be enough.
My dry sump system will be plumbed the same as yours but I will try to use the stock oil filter location with a short filter....maybe that will clear the header?!
BTW: your (machine) work is great and really very inspiring to me! It seems that you have a lot of experience in building 4" engines. Which engine case (WBX or Autolinea) do you prefer and why?
Tobi
