September 22, 2026, 13:30:39 pm
| |-+  For sale!
| | |-+  "turtle racer too" nostalgia racer
Author Topic: "turtle racer too" nostalgia racer  (Read 12624 times)
« on: August 25, 2009, 18:59:19 pm »
gasser for sale
TURTLE RACER TOO
Specificity of the car :
MODEL:1200
FIRST REGISTRATION : 71
fully restored in 95 (floorpan & body) painted in mauve  and  then new paint this year
BODY PARTS : fiberglass front decklid ,EMPI fiberglass rear decklid ,fiberglass fenders/wings same as the MOUSE TRAP
COLOR .gold & green from lamborghini
CAR PAINTED BY : bugs are us  , 45h painting , 6 days of sanding
STRIPPING & DRAWING BY : el flameur/ludo  42H
INSIDE:
SHIFTER : csp/ebi#1 shifter n°4
SEAT ; kerkey bucket seat
DASHBOARD ; alu panel
DOOR PANEL : alu
ROLLCAGE : modifying 6 points
HARNESS : simpson
UPHOLSTERY  : kerkey cover
GAUGES : autometer
ENGINE/type 1
DISPLACEMENT : 1776 cc /196hp
BUILDER : slide performance
CRANK :CB 69mm counterweight
RODS :CB I (put in the weight)
PISTONS &CYLINDERS : 90.5 mm mahle
CAM : engle FK-46
OIL PUMP : shadek /berg cover plate
OIL SUMP : berg
HEADS : berg reworked by SLIDE PERFORMANCE
VALVE SIZE: 42mm intake & 37.5mm exhaust   dual springs
COMPRESSION RATIO :12.2 : 1
ROCKERS ARMS : CB 1.4:1
IGNITION : msd
PULLEY : racing/small diameter
CARBURATION ; dual 48IDA webers , 40mm venturis
LINKAGE : csp
INTAKE MANIFOLD : CB  , match-ported , Cut and shortened
EXHAUST SYSTEM :1-5/8inch magnaflow
CLUTCH/KEP : stage 1 , 200mm disc
HOLLEY BLUE pump
TRANSAXLE/swingaxle
BUILDER : charlie 48
RING & PINION : german NOS 3.88
GEAR RATIOS : 4.11:1 1st ,2.46:1 2nd , 1.74:1 3rd ,1.37:1 4th
SWINGAXLE : hd
STARTER : hi torque 12v
other modifications :
BRAKES ; vw brakes drums (4)
REAR SUSPENSION ; adjustable beam & strap to limit the clearance , csp torque bars
FRONT  BEAM : vw with sway a way
Modification of the nose  to give some hunting(caster shims) and a better stability to high speed by cutting a piece to raise  4cm the nose
WHEELS/TYRES : centerlines 3.5" with firestone at front & 6" with M&H 26/6/15  at rear
the car can do in the low 12s and high 11s
price  is 20.000€
contact damien at : damien.coireau@sfr.fr or by phone +33684517783
turtle racer
Best Et 12.84 at 171 km/h
« Reply #1 on: September 01, 2009, 19:19:02 pm »
Up !!!!
I love the racer, gasser nostalgia.
http://turtleracer.skynetblogs.be/
« Reply #2 on: September 02, 2009, 08:14:38 am »
cool car, and i love the fact it runs a 1776cc.
good luck with the sale!
turtle racer
« Reply #3 on: September 03, 2009, 12:35:14 pm »
Thanks dude !!
« Reply #4 on: September 03, 2009, 17:38:56 pm »
I see it's on the cover of"Super VW magazine",and like said above,good luck with the sale.(beautiful car btw )
 Wink
turtle racer
« Reply #5 on: September 04, 2009, 08:02:00 am »
I knew not ??
Thanks for information Wink
« Reply #6 on: September 04, 2009, 10:55:18 am »
 Wink
peter on wich cover Huh the last super vw was the new meyers manx
TiDi
« Reply #7 on: September 04, 2009, 11:06:08 am »
N.242  Grin Grin Grin
4 Wheel Ripperz - http://cal-look.tumblr.com/
charlie
« Reply #8 on: September 09, 2009, 20:10:29 pm »
Hi
Quaife inside   Wink
turtle racer
« Reply #9 on: September 11, 2009, 12:05:39 pm »
Thanks charlie  Wink
turtle racer
« Reply #10 on: September 21, 2009, 19:16:27 pm »
Big up !!!!!  Grin Grin Grin Grin Grin Grin
turtle racer
« Reply #11 on: October 12, 2009, 07:27:32 am »
New price 18.000€  Wink
turtle racer
« Reply #12 on: November 21, 2009, 20:10:35 pm »
New price 16500€[/color]
turtle racer
« Reply #13 on: December 19, 2009, 12:53:36 pm »
I sell my turtle without the motor for 8000€.
With the motor it will be 16000€
You still have the possibility of withdrawing attachments.
turtle racer
« Reply #14 on: January 02, 2010, 10:36:55 am »
Big Up
I sell my turtle without the motor for 7000€.
With the motor it will be 14000
turtle racer
« Reply #15 on: January 22, 2010, 22:44:39 pm »
SOLD !!!!!
« Reply #16 on: January 22, 2010, 23:47:41 pm »
SOLD !!!!!
it's cool to see the car soon in belgium  Wink
« Reply #17 on: January 22, 2010, 23:51:14 pm »
Do you know who bought it Fabs?
