October 13, 2026, 04:37:45 am
Two Cylinders, One Casting
Topic: Two Cylinders, One Casting (Read 11120 times)
Steve DKK
August 27, 2009, 16:25:51 pm »
I have a hair brained idea to manufacture a single casting that would house both cylinders for a type one.
Trying to get away from long springy head studs. Has this been tried?
One pattern holding the cylinger to case another pattern bolting the head to the cylinder.
Increasing torque, bolt size, number of bolts and reducing the bolt length seems to be a huge advantage?
Thoughts?
Go fast, don't turn
Re: Two Cylinders, One Casting
August 27, 2009, 16:54:33 pm »
I think Pauter has done this before. I know I have seen it some where. Maybe in Keith S. interchange manual.
jamiep_jamiep
August 28, 2009, 08:59:32 am »
Sounds overly complex to me.... but???
I think ARPM also did some.
I think if the guys running quick times with lots of boost on here can get away with it I would be surprised if there was a need for a set of bolts for the cylinders and a set for the heads, but I'm in the KISS camp (keep it simple stoopid) of engineering so who knows.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Griebel
August 28, 2009, 13:49:57 pm »
ARPM...
Instagram: c.griebel
"BEYOND 4 INCHES"
MIB,DENMARK
Roman
August 28, 2009, 19:53:23 pm »
It is called Siamese cylinders.
Last Edit: August 29, 2009, 08:46:28 am by Roman
August 28, 2009, 19:54:15 pm »
Quote from: Roman on August 28, 2009, 19:53:23 pm
It is called Siemese cylinders.
Siamese
Roman
August 29, 2009, 08:46:51 am »
Yes, it was a typo..
Steve DKK
August 30, 2009, 17:43:30 pm »
Agree this not a mass market item.
But in understand the cylinder to head seal is still a problem when cranking the boost up.
Go fast, don't turn
August 30, 2009, 19:37:07 pm »
Quote from: Steve DKK on August 27, 2009, 16:25:51 pm
Presumably you were looking at M10 studs. If you thought they were weak or stretchy, have you thought about 7/16" studs? M12?
Martin
Cash Converter....
August 30, 2009, 22:11:10 pm »
never had any issues with mine leaking under boost.
Martin
www.taylormachine.co.uk
OFF/500
Steve DKK
August 31, 2009, 00:52:06 am »
Hector Urias is a good friend and he had a leaker at Sacramento last month and torched a head. Had to scramble to get it welded and machined to run the next day.
7/16... Yea bigger is sometimes better but anying additional stress to the case scares me. assuming using a larger diameter stud would allow additional torque.
Were there problems with the siamese cylinders?
Go fast, don't turn
September 01, 2009, 10:02:29 am »
The stress on the case would be the same, but more bolts will spread the forces more evenly.
Steve DKK
September 10, 2009, 12:23:21 pm »
Agree, My thought was using the std head bolts to attach the cylinders to the case but shorter larger bolts to attach the head to the cylinder. Allowing for more bolt torque and the use of a real head gasket not just a copper washer.
Go fast, don't turn
