November 02, 2026, 17:11:17 pm
| | |-+  Nitrous system for anti turbo lag advice needed?
Author Topic: Nitrous system for anti turbo lag advice needed?  (Read 10115 times)
mr horsepower
« on: August 30, 2009, 15:32:14 pm »
Hello i want to use a nitrous system for anti turbo lag on my smal enginebecause the turbo is a bit large
i only want to use it in the low boost area but i need to switch it of in  high boost .
whats the best way to connect the nitrous and how to use it .
can i best  use a boost switch  or an micro switch?
i hate backfires.
gr henri
« Reply #1 on: August 30, 2009, 17:17:57 pm »
You can use an adjustable pressure switch,they are used in  nitrous sytems to cut the power if the pressure drops to low so should be easily available,just wired so it cuts the power at your required boost level
cheers richie,uk
mr horsepower
« Reply #2 on: August 30, 2009, 18:26:28 pm »
Hi richie but how do i use it on the startline should i activate it on rpm or full throttle and when?
cheers richie,uk
« Reply #3 on: August 31, 2009, 01:38:17 am »
cheers richie,uk
Full throttle switch would be easiest
cheers richie,uk
