September 19, 2026, 13:52:26 pm
Bad Habit
Dellorto 36 drla carbs, whats the word on the streets?
Topic: Dellorto 36 drla carbs, whats the word on the streets? (Read 27258 times)
Speed-Randy
August 31, 2009, 04:34:01 am »
anybody use these carbs on an 1835? how about parts availability? im thinking about putting a set on a ghia for my daughter but have never had any experience with them, good or bad.
www.vdubspeedshack.com
Dave Rosique
nobodyouno
Re: Dellorto 36 drla carbs, whats the word on the streets?
August 31, 2009, 05:12:32 am »
I've installed 36 Dell's on many VW's over the years with great success... Most recently on a mild 2176cc. The only problem (besides parts) is the dreaded mid-range whistle.
I used to run the thick rubber "anti whistle" base gaskets... not sure if they're around anymore.
~DR.
John Rayburn
August 31, 2009, 05:39:53 am »
Awsome carb! I never liked the rubber anti whistle gaskets, because you could never get the bolts tight. You can fill in the area that whistles on the base of the carb with silicone, though. Good luck getting parts!
I also park at Nick's.
ugly duckling
August 31, 2009, 06:18:35 am »
hey jhon thats what you are running now right ? DOUBEL DELLS UNDER THE DUCT
im looking for a set of 48 DELLS in bitchen shape if you know any body . parts have got to be had some were. UD .
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
qubek
August 31, 2009, 11:44:22 am »
I didn't know that you can cure the whistle! I didn't know that other people have that issue too. What is the source of this sound?
Apart from that - excellent street carbs. They're almost maintenance free.
181
August 31, 2009, 13:38:28 pm »
this part needs to be blocked somehow
i.e. with anti whistle gasket
Dave Rosique
nobodyouno
August 31, 2009, 14:15:40 pm »
Maybe you could block the port with some sort of epoxy... not sure, never really felt good about it, so I always opted for the rubber gaskets.
You have to use caution not to over tighten and warp the carb base.
Silicone may not work for long... gas eats it.
~DR.
Last Edit: September 01, 2009, 03:10:20 am by Dave Rosique
qubek
August 31, 2009, 15:40:24 pm »
Thx, I didn't know.
BTW is it only a question of sound or is it connected with some negative effects (performance wise)?
Dave Rosique
nobodyouno
August 31, 2009, 16:24:39 pm »
Quote from: qubek on August 31, 2009, 15:40:24 pm
Thx, I didn't know.
Off idle through mid-range sound only... otherwise a very smooth running carburetor.
(Remember-- parts are hard to find and expen$ive)
~DR.
September 01, 2009, 05:47:23 am »
Parts are that tough to find. CB Performance still has all the jets you need. They are my absolute favorite carb and I have owned many sets.
September 01, 2009, 06:34:05 am »
Randy, are you still going with these carbs for your daughter's car... even though the parts are not exactly plentiful? Looking forward to seeing the car, too.
September 01, 2009, 13:49:41 pm »
They are perfect even for small 1600 stock engine. In Europe we get most parts from Alfa1750 on Ebay or from Dellorto UK shop.
Speed-Randy
September 01, 2009, 17:09:30 pm »
Quote from: DKK_Fred on September 01, 2009, 06:34:05 am
After looking at prices for these carbs, most of them missing parts, I could buy a new set of webers and avoid the hassle, I guess you just need to stay away from the HPMX's
September 02, 2009, 00:38:40 am »
I hear ya, Randy. If you ever need and stuff for those, I have two carbs that look like they've never been bolted to anything. They're both different sizes, but if you needed parts... just sayin'.
V8Square
September 02, 2009, 16:13:37 pm »
Quote from: vdubdweeb on August 31, 2009, 04:34:01 am
I am using the 40's on my 2.0 914 powered bug. My complaint is that with this engine set up in my car, adjustment is almost non-existant. Contact Matt Cooper at Euro Carb Ltd in England for help and parts. Very knowledgeable person. Email is
sals@dellorto.co.uk
CB performasnce really is not too helpful, in my opinion.
V8Square
September 02, 2009, 16:17:37 pm »
Quote from: V8Square on September 02, 2009, 16:13:37 pm
sals@dellorto.co.uk
Sorry for the fat finger. It is
sales@dellorto.co.uk
rick m
September 02, 2009, 16:56:55 pm »
Great CARBS! I have run them on many engines, getting up to 34mpg on a 1776 with a stock cam. They are smooth all the way through the transition once you have your jetting correct. The 5 transition ports on DELLORTO's really make them a smooth running carb off idle and through the mid range. I drove one of my cars, a 1966 sedan, from Arizona, through Utah and into Colorado, going from 1100ft to over 11,000ft, never making a jet change and they ran terrific.
You can still get parts and I will use them over any of the new webers any day of the week when building a driver motor. I have a set I will be installing on a mileage motor I am assembling with a long stroke and small bore, near stock cam. It will be an interesting test of how much mileage I can get out of them.
Rick M
Picture of my 66 attached.
Rick Mortensen
Driving Hot VWs since 1970
von-dart
September 02, 2009, 20:46:14 pm »
Its good to see these carbs are getting praise from you all. I want to run either Dells or Weber 36 IDFs on a 1679 mouse engine,I think my mind is made up to use the drla's now.
rick m
September 03, 2009, 03:05:35 am »
Glad to help you with your decision. They are GREAT Carbs for small motors.
Rick Mortensen
Rick Mortensen
September 03, 2009, 03:55:43 am »
Shoot, they`re great carbs for any size motor. I ran 45`s on the 2176 that was in my old 67. Smooooooth.
rick m
September 05, 2009, 21:38:43 pm »
I meant the 36s were great for small motors. I run every size dellorto, including 40s, 45s on my turbo motor and 48s on my 2110. I wish I had never sold my 48s...I would buy them back if I could find them.
Rick M
Rick Mortensen
Hotrodvw
September 08, 2009, 06:00:09 am »
You guys all say that parts are hard to get? You just need to know where to look. Art Thraen and Mark Harney have sources, CB carries some parts, The Alpha dude on eBaY, and other dealers. For the whistle, you can use JB Weld to plug the port off. I have run 40's on my 1641, 1776 and 2007....they run like a top. Almost no maintenance is right! I love 'em.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
rick m
September 09, 2009, 05:45:43 am »
I've jetted the Dellorto's once, set them and never messed with them after that. Why would you need to? Keep the air cleaners clean and the fuel filters clean and you shouldn't have to be screwing with adjustments all the time.
Rick M
Rick Mortensen
September 09, 2009, 06:31:08 am »
I've ran a set of 36's on my bus on a small motor, the thing ran for ever and smooth. Great carb!
Kaferdog
September 09, 2009, 08:30:58 am »
I love Em ...!!......I've had them on my stock 1600 for 5 years and no real problems...! .....
Hey Rick...
I bought a case from you a few years a ago ( 3 or 4 maybe ?) I finally got it together with many thanks to Ted a.k.a. Racecraf ...!...now just waiting to dyno it .....Thanks for parting with it !!!
Last Edit: September 09, 2009, 08:37:53 am by Kaferdog
